Visualizer shows errored state, but circuit works correctly
Hi team,
I'm really excited about this product and appreciate all the work that’s gone into it! I'm currently encountering a visual discrepancy in the Ziti Console that I’d like some help with.
In the Identity Service Path view for my homelab-service, the console displays:
  • homelab-router with a red (Errored) component status
  • The link from edge-router to homelab-router and the link from homelab-router to the service show as Errored
However, the service works perfectly — traffic flows from my device through the edge router and reaches the hosted service without issues.
  • The homelab-router is registered and online (ziti fabric list routers)
  • The fabric links are in Connected and up state (ziti fabric list links)
  • The service has an active terminator hosted on homelab-router
  • The circuit path correctly includes homelab-router and is in use
  • Policies (Dial/Bind) and configs (intercept.v1 and host.v1) are correctly applied
  • The Ziti Tunnel client on the iPhone is successfully connecting to the service
What I've verified:
  • No current errors in controller or router logs
  • All identities, services, policies, and routers are correctly configured
  • This visual state has remained even after restarts and refreshes
Is this a known issue or state sync problem in the Ziti Console (ZAC)?
Maybe I'm doing something wrong?
Thanks in advance!
Hi @shady2k, I'm happy to hear that you're enjoying OpenZiti so far!
Thanks for the detailed writeup, at a glance it looks like you are doing everything correctly.
While we dig in, please tell me the versions of the OpenZiti controller end Router you are running.
Of course! Controller/router: v1.5.4 ZAC: 3.12.2
Hi @shady2k
I'm experiencing the same issue with Controller v1.5.4 and ZAC v3.12.4. Everything is working fine otherwise, so it’s not a major concern for me—but it would be nice if it worked as expected.
I haven’t spent any time troubleshooting it yet, as this feature isn’t particularly important for my use case.
Exactly the same issue with my installation. Everything works fine except "visualizer". Controller: v1.5.4 ZAC: 3.12.4
I’m experiencing exactly the same issue. Everything works fine except for the Visualizer component.
With Controller v1.5.4 and ZAC 3.12.4, the visualizer fails to show properly.
However, when I downgrade to Controller v1.1.8 (while keeping ZAC 3.12.4), the visualizer works as expected.
This issue has been fixed in the new release of ZAC, version 3.12.5.
