Hi there,
I encountered several of these logs in ZET running on a T3.small instance in AWS:
WARN ziti-sdk:channel.c:795 channel_alloc_cb() ch[0] can't alloc message
They appeared as soon as I started to upload a dummy-data 1GB file from my local machine (also using ZET in WSL) via scp.
Does this mean sth. is wrong with the traffic received or how should this log message be interpreted ?
I have found this topic SSH over ziti tunnel hangs often - #8 by TheLumberjack where you state that this is basically an informative message - at as I understood ![]()
As I just uploaded from a single endpoint, I'm wondering what would happen in a production like scenario several clients would upload files simultaneously. Does this warning message now say that the ec2 t3.small instance is too slow to handle one incoming stream of data or do I misunderstand ?
BR
Jan
