What is the `ziti-controller-init-container` doing?
Can anyone explain what the ziti-controller-init-container container does? It appears to be necessary for the quickstart docker setup to work, but it runs and then exits. It executes a cli script, and that script creates two service-edge-router-policies for for what looks like public access.
What else does the init container do?
Is the init container idempotent?
Is it possible to eliminate the init container in the quick start compose setup?
Alternatively, is there a compose setup with non-quickstart images?
It runs run-with-ziti-cli.sh which subsequently runs access-control.sh. After it executes it leaves a marker file behind named access-control.init which controls subsequent runs from happening. Its purpose is to create the two policies needed by most 'quickstart' users found in access-control.sh. An edge router policy allowing all identities to access all edge routers with the #public attribute, and a service edge router policy allowing all services to use all edge routers.
It is not necessary for the compose environment to start (I just did it myself) but it is necessary if you want to use the environment without making an edge router policy and services edge router policy yourself. Alternatively, you can start just the controller and just the router and run the same commands specified in the access-control.sh script, it's just two ziti cli commands.
Not really. The first time you run it it has side effects. Every time after that it is so technically that's a 'no'.
Yep. As mentioned above.
Yep. There are plain, no frills, no helper containers that you can run which nothing but ziti inside them. You put the PKI in place, you put the config in place etc. @qrkourier uses them for kubernetes deployments. They are much more streamlined and slimmed down compared to the quickstart. You can find them at the root of the ziti repo https://github.com/openziti/ziti/tree/main/docker-images
Everytime I try to eliminate it, the controller container crashes with the message below. That's why I have been deleting the init file every start.
adding /var/openziti/ziti-bin to the path
controller initialized. unsetting ZITI_USER/ZITI_PWD from env
panic: controllerConfig must provide [db] or [raft]
Here is my whole docker-compose.yaml file.
version: '2.4'
services:
  #  rm-init:
  #    image: rm-init
  #    volumes:
  #      - ./ziti-fs:/persistent
  ziti-controller:
    env_file:
      - ./.env
    ports:
      - ${ZITI_CTRL_EDGE_ADVERTISED_PORT:-1280}:${ZITI_CTRL_EDGE_ADVERTISED_PORT:-1280}
      - ${ZITI_CTRL_ADVERTISED_PORT:-6262}:${ZITI_CTRL_ADVERTISED_PORT:-6262}
    environment:
      - ZITI_PWD=${ZITI_PWD}
    networks:
      ziti:
        aliases:
          - ziti-edge-controller
    volumes:
    entrypoint:
        #    depends_on:
        #      - rm-init
        #  ziti-controller-init-container:
        #    image: "${ZITI_IMAGE}:${ZITI_VERSION}"
        #    depends_on:
        #      - ziti-controller
        #    environment:
        #      - ZITI_CTRL_EDGE_ADVERTISED_ADDRESS=${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS:-ziti-edge-controller}
        #      - ZITI_CTRL_EDGE_ADVERTISED_PORT=${ZITI_CTRL_EDGE_ADVERTISED_PORT:-1280}
        #    env_file:
        #      - ./.env
        #    networks:
        #      ziti:
        #    volumes:
        #    entrypoint:
        #      - "/var/openziti/scripts/run-with-ziti-cli.sh"
        #    command:
        #      - "/var/openziti/scripts/access-control.sh"
  ziti-edge-router:
    env_file:
      - ./.env
    depends_on:
      - ziti-controller
    ports:
      - ${ZITI_ROUTER_PORT:-3022}:${ZITI_ROUTER_PORT:-3022}
      - ${ZITI_ROUTER_LISTENER_BIND_PORT:-10080}:${ZITI_ROUTER_LISTENER_BIND_PORT:-10080}
    environment:
      - ZITI_ROUTER_ROLES=public
    networks:
      - ziti
    volumes:
    entrypoint: /bin/bash
  ziti-console:
    image: openziti/zac
    working_dir: /usr/src/app
    environment:
      - ZAC_SERVER_CERT_CHAIN=/persistent/pki/${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS:-ziti-edge-controller}-intermediate/certs/${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS:-ziti-edge-controller}-server.cert
      - ZAC_SERVER_KEY=/persistent/pki/${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS:-ziti-edge-controller}-intermediate/keys/${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS:-ziti-edge-controller}-server.key
      - PORTTLS=8443
    depends_on:
      - ziti-controller
    ports:
      - 8443:8443
    volumes:
    networks:
      - ziti
  caddy:
    image: caddy:latest
    container_name: caddy
    depends_on:
      - ziti-console
    restart: unless-stopped
    ports:
      - "80:80"
      - "443:443"
        #    networks:
        #      - caddy-net
    volumes:
      - ./caddy/data/:/data/
      - ./caddy/config/:/config/
      - ./caddy/Caddyfile:/etc/caddy/Caddyfile
    networks:
      - ziti
networks:
  ziti:
Here is the environment when the init container runs OK
Thanks for the file. I just pruned docker and I'm giving it a try. It failed for me because the caddy file isn't found. I removed the caddy file, down'ed and up'ed and had a failure during startup.
Tried a very minimally different docker compose file, down'ed and up'ed fine. pruned everything, made sure I had no docker volume's left around, ran your compose again... and your compose file failed again...
Tried mine again and it started fine... So maybe there's some kind of strange docker race condition around the volume that's causing issues? That's (after removing caddy) the only difference I see between yours and mine...
You're using:
    volumes:
Ours has:
    volumes:
      - ziti-fs:/persistent
and declares the volume at the end:
volumes:
  ziti-fs:
Compose file I used (from curl'ing it)
version: '2.4'
services:
  ziti-controller:
    env_file:
      - ./.env
    ports:
    environment:
    networks:
      ziti:
        aliases:
    volumes:
    entrypoint:
  ziti-edge-router:
    env_file:
      - ./.env
    depends_on:
      - ziti-controller
    ports:
    environment:
    networks:
      - ziti
    volumes:
  ziti-console:
    image: openziti/zac
    environment:
      - PORTTLS=8443
    depends_on:
      - ziti-controller
    ports:
      - 8443:8443
    volumes:
    networks:
      - ziti
networks:
  ziti:
volumes:
  ziti-fs:
Bizzare....
Ok, I will try changing that in the volumes. I prefer volume mounts over shared volumes for simplicity, but there could be just that. Thanks for confirming!
Yeah.... If that 'fixes it' there's something I just don't understand happening with docker with the volume mounts that's just unexpected.
tenor-227209086
Still breaks for me.
β”Œβ”€Logs - Stats - Env - Config - Top───────────────────────────────────────────────────────────────────────────────────────────────────────────────┐
β”‚NOT OVERRIDING: env var ZITI_ROUTER_PORT already set. using existing value        β–²
β”‚NOT OVERRIDING: env var ZITI_ROUTER_ROLES already set. using existing value        β”‚
β”‚NOT OVERRIDING: env var ZITI_SCRIPTS already set. using existing value        β”‚
β”‚NOT OVERRIDING: env var ZITI_SHARED already set. using existing value        β”‚
β”‚NOT OVERRIDING: env var ZITI_USER already set. using existing value        β”‚
β”‚NOT OVERRIDING: env var ZITI_VERSION already set. using existing value        β”‚
β”‚        β”‚
β”‚adding /var/openziti/ziti-bin to the path        β”‚
β”‚controller initialized. unsetting ZITI_USER/ZITI_PWD from env        β”‚
β”‚panic: controllerConfig must provide [db] or [raft]        β”‚
β”‚        β”‚
β”‚goroutine 1 [running]:        β”‚
β”‚github.com/openziti/fabric/controller.LoadConfig({0xffffe837557a?, 0x4000135318?})                                                               β”‚
β”‚    github.com/openziti/fabric@v0.24.2/controller/config.go:270 +0x2074        β–ˆ
β”‚github.com/openziti/ziti/ziti/controller.run(0x400098f200?, {0x4000a67780, 0x1, 0x1?})                                                           β–ˆ
β”‚    github.com/openziti/ziti/ziti/controller/run.go:53 +0x400        β–ˆ
β”‚github.com/spf13/cobra.(*Command).execute(0x400098f200, {0x4000a67750, 0x1, 0x1})        β–ˆ
β”‚    github.com/spf13/cobra@v1.7.0/command.go:944 +0x5ac        β–ˆ
β”‚github.com/spf13/cobra.(*Command).ExecuteC(0x506bca0)        β–ˆ
β”‚    github.com/spf13/cobra@v1.7.0/command.go:1068 +0x340        β–ˆ
β”‚github.com/spf13/cobra.(*Command).Execute(...)        β–ˆ
β”‚    github.com/spf13/cobra@v1.7.0/command.go:992        β–ˆ
β”‚github.com/openziti/ziti/ziti/cmd.Execute()        β–ˆ
β”‚    github.com/openziti/ziti/ziti/cmd/cmd.go:79 +0x24        β–ˆ
β”‚main.main()        β–ˆ
β”‚    github.com/openziti/ziti/ziti/main.go:51 +0x1c        β–ˆ
β”‚        β–Ό
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
I'll try it on a wholly different machine. Just for completeness sake, what version of docker are you using? and you're on MacOS or linux or other? Feels like something goofy....
docker version
Client: Docker Engine - Community
 Version:           23.0.3
 API version:       1.42
 Go version:        go1.19.7
 Git commit:        3e7cbfd
 Built:             Tue Apr  4 22:05:48 2023
 OS/Arch:           linux/amd64
 Context:           default
Server: Docker Engine - Community
 Engine:
  Version:          23.0.3
  API version:      1.42 (minimum version 1.12)
  Git commit:       59118bf
  Experimental:     false
 containerd:
  Version:          1.6.20
  GitCommit:        2806fc1057397dbaeefbea0e4e17bddfbd388f38
 runc:
  Version:          1.1.5
  GitCommit:        v1.1.5-0-gf19387a
 docker-init:
  Version:          0.19.0
  GitCommit:        de40ad0
@gberl002 can you try this out too so that we have another person giving it a go?
Edit: I reverted the template back to the default volume behavior. It crashed again. I then did the following:
$ history
  102  wget https://raw.githubusercontent.com/openziti/ziti/release-next/quickstart/docker/simplified-docker-compose.yml
  104  docker compose down -v --rmi all
  106  mv docker-compose.yaml docker-compose.yaml.bak
  107  mv simplified-docker-compose.yml docker-compose.yaml
  108  docker compose up -d
  113  vim docker-compose.yaml # commented out initi service
  117  docker compose down
  115  docker compose up -d --remove-orphans
Here is a diff of the downloaded compose file and my changes.
root@ziti:/opt/ziti# diff docker-compose.yaml simplified-docker-compose.yml
29,45c29,45
<         #  ziti-controller-init-container:
<         #    image: "${ZITI_IMAGE}:${ZITI_VERSION}"
<         #    depends_on:
<         #      - ziti-controller
<         #    environment:
<         #      - ZITI_CTRL_EDGE_ADVERTISED_ADDRESS=${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS:-ziti-edge-controller}
<         #      - ZITI_CTRL_EDGE_ADVERTISED_PORT=${ZITI_CTRL_EDGE_ADVERTISED_PORT:-1280}
<         #    env_file:
<         #      - ./.env
<         #    networks:
<         #      ziti:
<         #    volumes:
<         #      - ziti-fs:/persistent
<         #    entrypoint:
<         #      - "/var/openziti/scripts/run-with-ziti-cli.sh"
<         #    command:
<         #      - "/var/openziti/scripts/access-control.sh"
>     depends_on:
>       - ziti-controller
>     environment:
>     env_file:
>       - ./.env
>     networks:
>       ziti:
>     volumes:
>     entrypoint:
>     command:
Here is my .env file
root@ziti:/opt/ziti# cat .env
ZITI_USER=admin.redacted
ZITI_PWD=redacted
ZITI_VERSION=0.30.1
ZITI_CTRL_ADVERTISED_ADDRESS=ziti.redacted
ZITI_CTRL_ADVERTISED_PORT=8440
ZITI_CTRL_EDGE_ADVERTISED_ADDRESS=ziti.redacted
ZITI_CTRL_EDGE_ADVERTISED_PORT=8441
ZITI_CTRL_NAME=ziti.redacted
ZITI_ROUTER_ADVERTISED_HOST=ziti.redacted
ZITI_ROUTER_ADVERTISED_ADDRESS=ziti.redacted
ZITI_ROUTER_LISTENER_BIND_PORT=8444
ZITI_ROUTER_NAME=ziti.redacted
ZITI_ROUTER_PORT=8442
Here are my computer specs for the host
root@ziti:/opt/ziti# cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
Here are the docker details
root@ziti:/opt/ziti# docker version
 Version:           24.0.5
 API version:       1.43
 Go version:        go1.20.6
 Git commit:        ced0996
 Built:             Fri Jul 21 20:35:41 2023
 OS/Arch:           linux/arm64
 Context:           default
 Engine:
  Version:          24.0.5
  API version:      1.43 (minimum version 1.12)
  Git commit:       a61e2b4
  Experimental:     false
 containerd:
  Version:          1.6.22
  GitCommit:        8165feabfdfe38c65b599c4993d227328c231fca
 runc:
  Version:          1.1.8
  GitCommit:        v1.1.8-0-g82f18fe
 docker-init:
  Version:          0.19.0
  GitCommit:        de40ad0
Here is my memory
root@ziti:/opt/ziti# free -h
               total        used        free      shared  buff/cache   available
Mem:           935Mi       250Mi       497Mi       440Ki       258Mi       684Mi
Swap:             0B          0B          0B
Here is my Cloudformation template:
Parameters:
  Vpc:
    Type: String
    Default: vpc-066106109d72e076b
  KeyName:
    Type: String
    Default: ziti.mydomain.com-aws
  InstanceType:
    Type: String
    Default: t4g.micro
  ImageID:
    Description: ARM Debian12
    Type: String
  # arm-debian12
    Default: ami-0976ba1cd3f6173d8
  # amd64-debian12
  #   Default: ami-071175b60c818694f
  SSHLocation:
    Type: String
    Default: "redacted"
Resources:
  Ec2Instance:
    Type: AWS::EC2::Instance
    Properties:
      ImageId: !Ref ImageID
      InstanceType: !Ref InstanceType
      KeyName: !Ref KeyName
      NetworkInterfaces:
      - AssociatePublicIpAddress: 'true'
        DeviceIndex: '0'
        GroupSet:
          - !Ref Ec2SecurityGroup
        # SubnetId: !Ref Subnet
      UserData:
        Fn::Base64:
          !Sub |
            #!/bin/bash
            echo export EDITOR=vi >> /root/.bashrc
            echo set -o vi >> /root/.bashrc
            echo alias ll=\"ls -lah\" >> /root/.bashrc
            echo export EDITOR=vi >> /home/admin/.bashrc
            echo set -o vi >> /home/admin/.bashrc
            echo alias ll=\"ls -lah\" >> /home/admin/.bashrc
            source ~/.bashrc
            sudo apt update
            sudo apt upgrade -y
            sudo apt install -y vim yq gpg git pwgen
            curl -sSL https://get.docker.com/ | sh
            usermod -aG docker admin
            curl https://raw.githubusercontent.com/jesseduffield/lazydocker/master/scripts/install_update_linux.sh | bash
            sudo mv $HOME/.local/bin/lazydocker /usr/bin
            sudo git clone https://github.com/openziti/ziti.git /opt/ziti
            sudo reboot
      Tags:
      - Key: Name
        Value:
          Fn::Sub: "${AWS::StackName}-Ec2Instance"
      - Key: StackName
        Value:
          Fn::Sub: "${AWS::StackName}"
  Ec2SecurityGroup:
    Type: AWS::EC2::SecurityGroup
    Properties:
      GroupDescription: Security Group for Domain Joined Windows
      VpcId: !Ref Vpc
  Ec2SGIngressSSH:
    Type: AWS::EC2::SecurityGroupIngress
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      CidrIp: !Ref SSHLocation
      FromPort: 22
      ToPort: 22
  Ec2SGIngressHTTP:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      FromPort: 80
      ToPort: 80
  Ec2SGIngressHTTPS:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      FromPort: 443
      ToPort: 443
  Ec2SGIngress8440:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      FromPort: 8440
      ToPort: 8440
  Ec2SGIngress8441:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      FromPort: 8441
      ToPort: 8441
  Ec2SGIngress8442:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      FromPort: 8442
      ToPort: 8442
  Ec2SGIngress8443:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      FromPort: 8443
      ToPort: 8443
  Ec2SGIngress8444:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      FromPort: 8444
      ToPort: 8444
  Eip:
    Type: AWS::EC2::EIP
    Properties:
      Tags:
      - Key: Name
        Value:
          Fn::Sub: "${AWS::StackName}-Ec2InstanceEip"
      - Key: StackName
        Value:
  EipAssociation:
    Type: AWS::EC2::EIPAssociation
    Properties:
      EIP: !Ref Eip
      InstanceId: !Ref Ec2Instance
  zitiA:
    Type: 'AWS::Route53::RecordSet'
    Properties:
      HostedZoneId: redacted
      Type: A
      TTL: 60
      ResourceRecords:
        - !Ref Eip
This is quite frustrating. I tried it on an Ubuntu machine provisioned in AWS just now, using your exact steps (thank you) and it succeeded just fine. It's a t3a.small. I tried the experiment five full times and it started five full times.
I made a Debian 12 ARM image on AWS. I didn't use your full CF template, but did run your commands. I needed to add sudo to your usermod line for the admin user to get the docker user. Modified the 'addresseses' accordingly and compose up'ed... and the dang thing.... started! :rage:
I'm gonna try it on an m1mini... @qrkourier you have any thoughts on what might be going on here, maybe?
I'm seeing an issue with the caddy container but the controller and router are working for me on my M1 Mac running Ventura (13.4.1)
Darwin MacBook-Pro.local 22.5.0 Darwin Kernel Version 22.5.0: Thu Jun  8 22:22:20 PDT 2023; root:xnu-8796.121.3~7/RELEASE_ARM64_T6000 arm64
and the latest docker (24.0.5) with 5 CPUs and 7.9GB of memory allocated.
Client:
 Cloud integration: v1.0.35-desktop+001
 Version:           24.0.5
 API version:       1.43
 Git commit:        ced0996
 Built:             Fri Jul 21 20:32:30 2023
 OS/Arch:           darwin/arm64
 Context:           desktop-linux
Server: Docker Desktop 4.22.0 (117440)
 Engine:
  Version:          24.0.5
  Git commit:       a61e2b4
  Built:            Fri Jul 21 20:35:38 2023
  Experimental:     false
 containerd:
  Version:          1.6.21
  GitCommit:        3dce8eb055cbb6872793272b4f20ed16117344f8
 runc:
  Version:          1.1.7
  GitCommit:        v1.1.7-0-g860f061
 docker-init:
  Version:          0.19.0
  GitCommit:        de40ad0
@TheLumberjack I am DMing you a video. I rebuilt my stack, deleted the whole biz, rebuild it based on a t2.micro instead of the graviton instance. Same thing. It must be in my .env. I will send you my .env file as well.
Ok. I have created a slightly modified cloud formation script:
CloudFormation Script
Parameters:
  Vpc:
    Type: String
    Default: YOUR_VPC_ID
  SSHKeyName:
    Type: String
    Default: YOUR_SSH_KEYPAIR_NAME
  InstanceType:
    Type: String
    Default: t4g.micro
  ImageID:
    Type: String
    Default: ami-0e4e72a29ae8c13b3
    # Default: ami-0976ba1cd3f6173d8 DID NOT EXIST?
  # amd64-debian12
  #   Default: ami-071175b60c818694f DID NOT EXIST?
  #   Default: ami-0ddf7dfd13a83d8c8
  SSHLocation:
    Type: String
    Default: "YOUR_IP_ADDRESS/32"
  AllOtherServiceAccess:
    Type: String
    Default: "0.0.0.0/0"
  Route53ZoneId:
    Type: String
    Default: "YOUR_ROUTE53_ZONE_ID"
  DNSName:
    Type: String
    Default: your.external.address.here
  OpenZitiControllerPwd:
    Type: String
    Default: THE_PWD_YOU_WANT
Resources:
  Ec2Instance:
    Properties:
      KeyName: !Ref SSHKeyName
      NetworkInterfaces:
        DeviceIndex: '0'
        GroupSet:
      UserData:
        Fn::Base64:
          !Sub |
            #!/bin/bash
            source ~/.bashrc
            sudo apt update
            sudo apt upgrade -y
            sudo usermod -aG docker admin
            mkdir -p /home/admin/compose
            curl -so /home/admin/compose/docker-compose.yaml https://gist.githubusercontent.com/dovholuknf/db26b799d1fd1b2560864df067acb170/raw/bc3bd70185bd490f7ca70122443ae826c2ac2db5/gistfile1.txt
            curl -so /home/admin/compose/.env https://get.openziti.io/dock/.env
            sed -i -E "s/(ziti-edge-controller|ziti-edge-router|ziti-controller)/${DNSName}/g" /home/admin/compose/.env
            sed -i "s/\#ZITI_CTRL_EDGE_ADVERTISED_PORT/ZITI_CTRL_EDGE_ADVERTISED_PORT/g" /home/admin/compose/.env
            sed -i "s/\#ZITI_CTRL_ADVERTISED_PORT/ZITI_CTRL_ADVERTISED_PORT/g" /home/admin/compose/.env
            sed -i "s/\#ZITI_ROUTER_NAME/ZITI_ROUTER_NAME/g" /home/admin/compose/.env
            sed -i "s/\#ZITI_ROUTER_ADVERTISED_ADDRESS/ZITI_ROUTER_ADVERTISED_ADDRESS/g" /home/admin/compose/.env
            sed -i "s/\#ZITI_ROUTER_PORT/ZITI_ROUTER_PORT/g" /home/admin/compose/.env
            sed -i "s/\#ZITI_ROUTER_LISTENER_BIND_PORT/ZITI_ROUTER_LISTENER_BIND_PORT/g" /home/admin/compose/.env
            sed -i "s/\#ZITI_ROUTER_ROLES/ZITI_ROUTER_ROLES/g" /home/admin/compose/.env
            sed -i "s/\ZITI_PWD=/ZITI_PWD=${OpenZitiControllerPwd}/g" /home/admin/compose/.env
            sudo chown -R admin:admin /home/admin/compose
            sudo reboot
      Tags:
      - Key: Name
        Value:
      - Key: StackName
        Value:
  Ec2SecurityGroup:
    Properties:
      VpcId: !Ref Vpc
  Ec2SGIngressSSH:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      FromPort: 22
      ToPort: 22
  Ec2SGIngressHTTP:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      CidrIp: !Ref AllOtherServiceAccess
      FromPort: 80
      ToPort: 80
  Ec2SGIngressHTTPS:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      FromPort: 443
      ToPort: 443
  Ec2SGIngress8440:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      FromPort: 8440
      ToPort: 8440
  Ec2SGIngress8441:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      FromPort: 8441
      ToPort: 8441
  Ec2SGIngress8442:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      FromPort: 8442
      ToPort: 8442
  Ec2SGIngress8443:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      FromPort: 8443
      ToPort: 8443
  Ec2SGIngress8444:
    Properties:
      GroupId:
        Fn::GetAtt:
        - Ec2SecurityGroup
        - GroupId
      IpProtocol: tcp
      FromPort: 8444
      ToPort: 8444
  Eip:
    Type: AWS::EC2::EIP
    Properties:
      Tags:
      - Key: Name
        Value:
      - Key: StackName
        Value:
  EipAssociation:
    Properties:
      EIP: !Ref Eip
  OpenZitiDNSRecord:
    Properties:
      HostedZoneId: !Ref Route53ZoneId
      Type: A
      TTL: 30
      ResourceRecords:
        - !Ref Eip
  • It's fully parameterized
  • It now also curls down a modified docker compose file from a github gist I created that doesn't have an init container
  • It now curls down the .env file
  • It modifies the .env file using a bunch of sed commands
  • I used aws cli to deploy it to aws: aws cloudformation create-stack --stack-name ClintDiscourse1574 --template-body file://${PWD}/cf.template
After the dust settles (the t4g.micro isn't fast at all), you SHOULD be able to just run docker compose....
Here's a nine minute, narrated video of it "just working"... :slight_smile: I added chapter markers to skip all the boring stuff waiting for the speedy t4g.micro...
Oh, great, I will look at that tomorrow, thanks for all the work!!!
Ok, I can reproduce it now. This is probably the part I was doing you weren't. The quickstart, at least with pinned 0.30.1 cannot restart, if it does and the access-control.init file exists, the controller crashes. I will upload a video that demonstrates this.
The implications are pretty huge, IMO. This means that the compose setup CANNOT restart or it will crash. This would be a terrible first experience for someone giving this a go.
Ah ha! I definitely didn't try restarting it! That's a bug we'll definitely want fixed, for sure. I'll give that a go now...
I just curl'ed the compose file and .env and stopped/started it a bunch of times and sadly, it works fine for me...
curl -so docker-compose.yml https://get.openziti.io/dock/simplified-docker-compose.yml
curl -so .env https://get.openziti.io/dock/.env
then i did a docker compose up -d, docker compose down a bunch of times and every time... It seems fine. Are you maybe terminating the docker compose bring up 'early' and triggering the bug that way maybe?
I still can't reproduce it I'm sorry to report :frowning: I'll look for your follow-up.
Each time the init container shows me the expected message:
docker-aug31-ziti-controller-init-container-1  |
docker-aug31-ziti-controller-init-container-1  | *****************************************************************
docker-aug31-ziti-controller-init-container-1  |  docker-compose init file has been detected, the initialization
docker-aug31-ziti-controller-init-container-1  |  of the docker-compose environment has already happened. If you
docker-aug31-ziti-controller-init-container-1  |  wish to allow this volume to be re-initialized, delete the file
docker-aug31-ziti-controller-init-container-1  |  located at /persistent/access-control.init
Here is my video: 2023-08-31_15-02-11 - TechSmith Screencast - TechSmith Screencast
edit: I made a shorter one.
Can you capture docker compose logs ziti-controller into a file and DM it to me? I can see in your video at 1:57:
goroutine 1 [running] :
github. con/openziti/fabric/controller. Loadconfig( {ΓΈx7ffe1a5e9595?, ΓΈxcΓΈΓΈΓΈ84b33ΓΈ?})
github. con/openziti/fabricΓΆvΓΈ .24.2/controtler/config.go:27ΓΈ +0*265c
github.com/openziti/ziti/ziti/controller/run.go:53 +0x507
github. .execute(0xcΓΈΓΈΓΈ9152ΓΈΓΈ, {OxcΓΈΓΈΓΈ9eda9ΓΈ, ΓΈxl, ΓΈxl})
What caught my eye is the Loadconfig panic. I'm pretty sure that is indicating the controller isn't able to read the config file. I'd like to see the full logs to see if there's anything else useful in there. It almost feels like a race condition of the controller starting before the instance can read the volume...
I'm gonna try this all over again on a 'slower' machine like that t4g, even following your steps to the letter, I still can't reproduce it on my local (somewhat speedy, definitely speedier than a t4g machine)
