Ziti Console installation issues
Hi All, just went to set up the web console today, and got the following error
> @openziti/ziti-sdk-nodejs@0.9.2 install /root/.ziti/quickstart/neo/ziti-console/node_modules/@openziti/ziti-sdk-nodejs
> node-pre-gyp install --fallback-to-build
node-pre-gyp ERR! install response status 403 Forbidden on https://ziti-npm.s3.amazonaws.com/ziti_sdk_nodejs/v0.9.2/Release/ziti_sdk_nodejs-v0.9.2-node-v64-linux-x64.tar.gz
node-pre-gyp WARN Pre-built binaries not installable for @openziti/ziti-sdk-nodejs@0.9.2 and node@10.23.1 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
node-pre-gyp WARN Hit error response status 403 Forbidden on https://ziti-npm.s3.amazonaws.com/ziti_sdk_nodejs/v0.9.2/Release/ziti_sdk_nodejs-v0.9.2-node-v64-linux-x64.tar.gz
make: Entering directory '/root/.ziti/quickstart/neo/ziti-console/node_modules/@openziti/ziti-sdk-nodejs/build'
  CC(target) Release/obj.target/ziti_sdk_nodejs/src/ziti-add-on.o
In file included from ../src/ziti-add-on.c:17:
../src/ziti-nodejs.h:23:10: fatal error: uv_mbed/uv_mbed.h: No such file or directory
 #include <uv_mbed/uv_mbed.h>
looks like aws is not allowing the download of sdk, and compiling it from source fails due to missing headers.
Thanks
@cjpit it looks like you are using NodeJS 10.23.1. Can you confirm? Meanwhile, the OpenZiti SDK for NodeJS supports NodeJS versions 12 through 18, so if you can try again using a newer version of NodeJS, you should succeed.
aha @curt thank you, I’ll give that a go
