Yes. Now if you add on the extra bit you'll get the sans out... since you included the cert, i could do that and I see:
DNS:localhost, DNS:ubuntu, IP Address:127.0.0.1
If you restart your controller, create an identity, transfer the jwt to windows it should work now. You need to also verify this section shows the same "ubuntu:8441". should be around line 129 ish:
i checked the edge: configuration which is same as you mentioned. Now i did the same as you suggested to restart the controller and create the new identity and then tried to enrolled it with controller but got the same issue.
[2024-08-22T21:43:23.407Z] INFO ziti-sdk:ziti_enroll.c:88 ziti_enroll() Ziti C SDK version 1.0.6 @gee95018(HEAD) starting enrollment at (2024-08-22T21:43:23.407)
[2024-08-22T21:43:25.666Z] ERROR ziti-sdk:ziti_ctrl.c:164 ctrl_resp_cb() ctrl[ubuntu] request failed: -3008(unknown node or service)
[2024-08-22T21:43:25.666Z] ERROR ziti-sdk:ziti_enroll.c:222 well_known_certs_cb() D:/a/ziti-tunnel-sdk-c/ziti-tunnel-sdk-c/build/_deps/ziti-sdk-c-src/library/ziti_enroll.c:139 - ZITI_JWT_VERIFICATION_FAILED => -7 (JWT verification failed)
[2024-08-22T21:43:25.666Z] ERROR ziti-edge-tunnel:ziti-edge-tunnel.c:329 tunnel_enroll_cb() enrollment failed: CONTROLLER_UNAVAILABLE(-7)
[2024-08-22T21:43:25.666Z] INFO ziti-edge-tunnel:ziti-edge-tunnel.c:236 on_command_resp() resp[0,len=56] = {"Success":false,"Error":"enrollment failed","Code":500}
[2024-08-22T21:47:10.251Z] INFO ziti-edge-tunnel:ziti-edge-tunnel.c:673 on_cmd() received cmd <{"Data":{"JwtFileName":"New-Wind-user.jwt","JwtContent":"eyJhbGciOiJSUzI1NiIsImtpZCI6ImI2NTRjZWY1MmFlZTY2NTdmYWQ1MDhlMTIwZWQzYjA3ZThlNzFkYmUiLCJ0eXAiOiJKV1QifQ.eyJpc3MiOiJodHRwczovL3VidW50dTo4NDQxIiwic3ViIjoiRXloT1hvTkcuIiwiYXVkIjpbIiJdLCJleHAiOjE3MjQzNDg3ODgsImp0aSI6ImU1N2EyOTJmLTExN2YtNDg2NS1iY2RlLWEyODg3YTA5ZWNmNyIsImVtIjoib3R0IiwiY3RybHMiOm51bGx9.gEMIIWR3NoD1Kk_elGvKTtnvN1sa_5QSMDrELTNhSAgjI7Ok1u-Ck7nozANpV2NY2X9fUKXVUeLA9OyVZ4tWOXHWq2wzDQwXA1-5RylCQ9E2YWj8rDKoE_7dsQgFTbyEWx1RU6OeO-9W1Jrkw8nOEGZS7t_EJc-nakCMHOs-X13LOfWuwyNcJLujzqUPuIrwlKSaMVbxdu2HiBpfMIfrx8-owS85590DgfjtZH1C_COzbkPY-sPb4i02OZ8ruOHpyU_Z0fK8lKnjHVJRpwZqPJWkPN10aYCPMBW3aeTWbj6ZPkpk0G4K9xi8UbAm21idoed-ijT2SsD0mzpLi9BNvnNTj6099sORS-xLV4z88GKFMO6r1cHWrfxDfoOaIcUMladSuVoWoDuIWc09pOnRkXz3WfpQFA95tX5o6PB8SCXw-iqsqpuE0v0JADpXCfL4IGnBnqXUsmMA8WNpDe6VA5wF2qTP6KpUxl0sfeEQyUj7aELGe1sGUIRD1zJVrBYXeNbgv1Nl8ynn2e85bf6zOTwlgphshclaXpPnUYp9jbRH_5cm6XpfiWtkmesRlwPNYrX77FCGgO1aFj-MtrO1h_sZZs-mzadAgzrQpkiwBZt9eUiOD-yOeD3UA56_lCMQbv0k_dCycJ4maKNx
[2024-08-22T21:47:10.251Z] INFO ziti-edge-tunnel:ziti-edge-tunnel.c:673 on_cmd() received cmd <1w8Twq6gWDRo"},"Command":"AddIdentity"}
[2024-08-22T21:47:10.251Z] INFO ziti-sdk:ziti_enroll.c:88 ziti_enroll() Ziti C SDK version 1.0.6 @gee95018(HEAD) starting enrollment at (2024-08-22T21:47:10.251)
[2024-08-22T21:47:12.505Z] ERROR ziti-sdk:ziti_ctrl.c:164 ctrl_resp_cb() ctrl[ubuntu] request failed: -3008(unknown node or service)
[2024-08-22T21:47:12.505Z] ERROR ziti-sdk:ziti_enroll.c:222 well_known_certs_cb() D:/a/ziti-tunnel-sdk-c/ziti-tunnel-sdk-c/build/_deps/ziti-sdk-c-src/library/ziti_enroll.c:139 - ZITI_JWT_VERIFICATION_FAILED => -7 (JWT verification failed)
[2024-08-22T21:47:12.505Z] ERROR ziti-edge-tunnel:ziti-edge-tunnel.c:329 tunnel_enroll_cb() enrollment failed: CONTROLLER_UNAVAILABLE(-7)
[2024-08-22T21:47:12.505Z] INFO ziti-edge-tunnel:ziti-edge-tunnel.c:236 on_command_resp() resp[0,len=56] = {"Success":false,"Error":"enrollment failed","Code":500}
It'd be appreciated if you used code fences when posting logs and other formatted text.
Can you post the JWT here? Usually that's a really bad idea - JWT's are secret! but since this JWT is entirely local to your network, it's safe to post.
OR - can you open the jwt in jwt.io and show me the body?
@wahmad and I got this sorted outside of discourse. The problem was the windows machine could not resolve "ubuntu". As it's a test scenario, he tried to update the hosts file and inadvertently added ".txt" to the hosts file, which windows ignored.
The solution was to rename hosts.txt to hosts and he was able to enroll.
Just wanted to wrap this issue up. Thanks @wahmad -- happy ziti-ing!
