Hi there!
I'm currently testing Ziti with a local Docker installation but am encountering issues with the edge router. The intercepts are showing up, but I'm unable to access the resources. Interestingly, when I docker exec into the edge router container, it has access to the remote connection.
Here's the config I am currently using
services:
ziti-controller:
healthcheck:
test: curl -m 1 -s -k -f https://${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS:-ziti-edge-controller}:${ZITI_CTRL_EDGE_ADVERTISED_PORT:-1280}/edge/client/v1/version
interval: 1s
timeout: 3s
retries: 99
env_file:
- ./.env
ports:
- ${ZITI_INTERFACE:-0.0.0.0}:${ZITI_CTRL_EDGE_ADVERTISED_PORT:-1280}:${ZITI_CTRL_EDGE_ADVERTISED_PORT:-1280}
- ${ZITI_INTERFACE:-0.0.0.0}:${ZITI_CTRL_ADVERTISED_PORT:-6262}:${ZITI_CTRL_ADVERTISED_PORT:-6262}
environment:
- ZITI_PWD=${ZITI_PWD}
networks:
ziti:
aliases:
- ziti-edge-controller
volumes:
- ziti-fs:/persistent
entrypoint:
depends_on:
ziti-controller:
condition: service_healthy
environment:
env_file:
- ./.env
networks:
ziti:
volumes:
entrypoint:
command:
ziti-edge-router:
env_file:
- ./.env
depends_on:
ziti-controller:
ports:
- ${ZITI_INTERFACE:-0.0.0.0}:${ZITI_ROUTER_LISTENER_BIND_PORT:-10080}:${ZITI_ROUTER_LISTENER_BIND_PORT:-10080}
environment:
- ZITI_ROUTER_ROLES=public
networks:
- ziti
volumes:
entrypoint: /bin/bash
ziti-console:
image: openziti/zac
working_dir: /usr/src/app
environment:
- ZAC_SERVER_CERT_CHAIN=/persistent/pki/${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS:-ziti-edge-controller}-intermediate/certs/${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS:-ziti-edge-controller}-server.cert
- ZAC_SERVER_KEY=/persistent/pki/${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS:-ziti-edge-controller}-intermediate/keys/${ZITI_CTRL_EDGE_ADVERTISED_ADDRESS:-ziti-edge-controller}-server.key
- PORTTLS=8443
depends_on:
ziti-controller:
ports:
- ${ZITI_INTERFACE:-0.0.0.0}:8443:8443
volumes:
networks:
- ziti
networks:
ziti:
volumes:
ziti-fs:
# OpenZiti Variables
ZITI_VERSION=latest
ZITI_USER=admin
ZITI_PWD=admin
ZITI_INTERFACE=0.0.0.0
ZITI_CTRL_EDGE_ADVERTISED_ADDRESS=ziti.server.lan
ZITI_CTRL_ADVERTISED_ADDRESS=ziti.server.lan
#ZITI_CTRL_EDGE_IP_OVERRIDE=10.10.10.10
#ZITI_CTRL_EDGE_ADVERTISED_PORT=8441
#ZITI_CTRL_ADVERTISED_PORT=8440
ZITI_ROUTER_NAME=ziti-edge-router
ZITI_ROUTER_ADVERTISED_ADDRESS=ziti-edge-router
#ZITI_ROUTER_PORT=8442
#ZITI_ROUTER_LISTENER_BIND_PORT=8444
