I have two VPS nodes:
- Node A (runs Vault-like service + ziti-edge-tunnel host)
- Node B (runs ziti-edge-tunnel client and should connect to Node A securely through Ziti)
Node A’s public address is vault.example.app:8200, but it should be accessed internally through Ziti with a proper certificate chain issued by Root CA.
However, when testing from Node B, I still see the old self-signed HashiCorp-style certificate even though DNS resolution points to Ziti.
What’s working
Node A side:
sudo openssl x509 -in /opt/vault/tls/vault.crt -noout -subject -issuer -enddate
subject=CN = vault.example.app
issuer=CN = Root CA
notAfter=Jan 16 10:10:31 2028 GMT
Node A ziti-edge-tunnel status:
sudo ziti-edge-tunnel tunnel_status | jq '.Data.Identities[0].Services | {Name, IsAccessible}'
vault-service: true
vault.example.app: true
Node B DNS resolution:
getent ahostsv4 vault.example.app
100.64.0.1 vault.example.app
dig @100.64.0.2 vault.example.app +short
100.64.0.3
cat /etc/hosts
100.64.0.3 vault.example.app
resolvectl:
DNS=100.64.0.2
Domains=~internal
The problem
From Node B:
echo | openssl s_client -4 -connect vault.example.app:8200 -servername vault.example.app -showcerts 2>/dev/null | openssl x509 -noout -subject -issuer
subject=O = HashiCorp, CN = Vault
issuer=O = HashiCorp, CN = Vault
So, even though DNS resolves correctly to 100.64.x.x, the TLS handshake still hits the public listener instead of the Ziti-hosted one.
Observations
- Ziti DNS resolution (via 100.64.0.2) is working fine.
- But
s_clientconnections still reach the public certificate. - Restarting
ziti-edge-tunnelon Node A drops SSH (expected). - After reconnecting, tunnel shows services as active, but traffic still isn’t being intercepted for port 8200.
Suspected root cause
Either:
- The Ziti tunnel on Node A is not actually binding the Vault service (port 8200) locally; or
- The Ziti edge-tunnel on Node B is not intercepting correctly for
vault.example.app; or - The DNS configuration on Node B intermittently bypasses the Ziti resolver.
What’s been tried
- Verified DNS through
getent,dig, and/etc/hosts. - Restarted both tunnels (
ziti-edge-tunnelservice). - Confirmed both services show
IsAccessible: true. - Still getting the public certificate when testing TLS.
Looking for guidance
What’s the correct way to ensure that:
- Ziti intercepts all traffic for
vault.example.appover the fabric, - Node A actually hosts/binds
tcp:127.0.0.1:8200through Ziti, and - TLS requests from Node B never touch the public network?
Any suggestions to verify or enforce the binding/intercept mapping would be appreciated.
