Ziti edge tunnel: dial connections refused after ~5 minutes usage
It’s a weird bug. It’s hard to catch them.
Connections to Ziti services intermittently fail after ~5 minutes of stable connectivity. The issue is random and affects different services at different times. Restarting the Ziti Edge Desktop client temporarily resolves the problem.
What I have?
  • 3 public ziti-routers
  • ziti-edge-tunnel as DaemonSet in my EKS.
  • ~ 30 ziti services
  • ~ 30 ziti host v1
  • ~ 30 ziti dial
  • ~ 30 ziti bind
  • ~ 30 ziti intercept v1
  • ~ 30 ziti users identities for ziti edge desktop ( mac and windows )
Steps to Reproduce
  1. Connect to Ziti using Ziti Edge Desktop.
  2. Verify that services are reachable (Service A and Service B).
  3. Wait approximately 5 minutes.
  4. Observe random connection failures:
    • Example: Connection refused for Service A, Service B remains accessible.
  5. Restart Ziti Edge Desktop. All services become reachable again.
  6. Wait ~5 minutes. Another service may fail (e.g., Service B fails, Service A OK).
  7. Sometimes both services fail.
Note: The failures are random; no specific service consistently fails first.
Ziti edge desktop logs (TRACE)
(31125)[2026-01-02T12:27:37.500Z]   ERROR ziti-sdk:connect.c:1070 connect_reply_cb() conn[1.285/9K7-Ptrh/Connecting](hello.ziti) failed to connect, reason=invalid session
(31125)[2026-01-02T12:27:37.500Z] VERBOSE ziti-sdk:connect.c:129 conn_set_state() conn[1.285/9K7-Ptrh/Connecting](hello.ziti) transitioning Connecting => Disconnected
(31125)[2026-01-02T12:27:37.500Z]   DEBUG ziti-sdk:connect.c:323 complete_conn_req() conn[1.285/9K7-Ptrh/Disconnected](hello.ziti) Disconnected failed: connection is closed
(31125)[2026-01-02T12:27:37.500Z] VERBOSE ziti-sdk:connect.c:129 conn_set_state() conn[1.285/9K7-Ptrh/Disconnected](hello.ziti) transitioning Disconnected => Disconnected
(31125)[2026-01-02T12:27:37.500Z]   TRACE ziti-sdk:channel.c:461 ziti_channel_send() ch[3] => ct[StateClosedType] seq[1226] len[0]
(31125)[2026-01-02T12:27:37.500Z]   TRACE ziti-sdk:channel.c:435 ziti_channel_send_message() ch[3] => ct[StateClosedType] seq[1226] len[0]
(31125)[2026-01-02T12:27:37.500Z]   TRACE ziti-sdk:channel.c:405 on_channel_send() ch[3] write delay = 0.000d q=1 qs=32
(31125)[2026-01-02T12:27:37.500Z] VERBOSE tunnel-cbs:ziti_tunnel_cbs.c:93 on_ziti_connect() on_ziti_connect status: -24
(31125)[2026-01-02T12:27:37.500Z]   ERROR tunnel-cbs:ziti_tunnel_cbs.c:103 on_ziti_connect() ziti dial failed: connection is closed
(31125)[2026-01-02T12:27:37.500Z] VERBOSE ziti-sdk:connect.c:129 conn_set_state() conn[1.285/9K7-Ptrh/Disconnected](hello.ziti) transitioning Disconnected => Closed
(31125)[2026-01-02T12:27:37.500Z]   TRACE ziti-sdk:connect.c:810 flush_connection() conn[1.285/9K7-Ptrh/Closed](hello.ziti) starting flusher
(31125)[2026-01-02T12:27:37.500Z]   TRACE ziti-sdk:channel.c:932 on_channel_data() ch[3] read no data
(31125)[2026-01-02T12:27:37.500Z]   TRACE tlsuv:tlsuv.c:418 finished reading after 2 iterations
(31125)[2026-01-02T12:27:37.500Z]   DEBUG ziti-sdk:connect.c:893 flush_to_client() conn[1.285/9K7-Ptrh/Closed](hello.ziti) no data_cb: can't flush, 0 bytes available
(31125)[2026-01-02T12:27:37.500Z]   TRACE ziti-sdk:connect.c:879 flush_to_service() conn[1.285/9K7-Ptrh/Closed](hello.ziti) flushed 0 messages
(31125)[2026-01-02T12:27:37.500Z]   TRACE ziti-sdk:connect.c:803 on_flush() conn[1.285/9K7-Ptrh/Closed](hello.ziti) stopping flusher
(31125)[2026-01-02T12:27:37.500Z]   DEBUG ziti-sdk:connect.c:184 close_conn_internal() conn[1.285/9K7-Ptrh/Closed](hello.ziti) removing
(31125)[2026-01-02T12:27:37.500Z]   TRACE tunnel-cbs:ziti_tunnel_cbs.c:602 ziti_conn_close_cb() ziti_conn[0x12f711fc0] is closed
(31125)[2026-01-02T12:27:37.500Z]   DEBUG tunnel-sdk:ziti_tunnel.c:446 ziti_tunneler_close() closing connection: client[tcp:100.64.0.1:62188] service[hello.ziti]
(31125)[2026-01-02T12:27:37.500Z]   DEBUG tunnel-sdk:tunnel_tcp.c:252 tunneler_tcp_close() closing src[tcp:100.64.0.1:62188] dst[tcp:100.64.0.5:443] state[3/SYN_RCVD] flags[0x100] service[hello.ziti]
Ziti edge router logs
{"_context":"ch{edge}-\u003eu{classic}-\u003ei{ziti-sdk-c[4]@mac-pro-14.local/pVNP}","chSeq":275,"connId":373,"edgeSeq":0,"error":"invalid session","file":"github.com/openziti/ziti/router/xgress_edge/listener.go:199","func":"github.com/openziti/ziti/router/xgress_edge.(*edgeClientConn).processConnect","level":"warning","msg":"failed to dial fabric","time":"2026-01-02T12:46:00.039Z","token":"eyJhbGciOiJSUzI1NiIsImtpZCI6IjFhZWVjMmY5Mzc4MWMzZTMyOGI1ZjNhMzk2NDA3NmMwYWJmNzQxMmIiLCJ0eXAiOiJKV1QifQ.eyJpc3MiOiJodHRwczovL2VkZ2Uueml0aS5tYWd4LmFwcDo0NDMiLCJzdWIiOiIxRVVWUzJ4VlV5Q3A0bFk2dlJkUUV3IiwiYXVkIjpbIm9wZW56aXRpIl0sImV4cCI6MTc5ODg5MTkxOSwiaWF0IjoxNzY3MzU1OTE5LCJqdGkiOiJjbWp3dTJ6YW14ZDl6MGM4NjMxcmt1b2Z6Iiwiel9hc2lkIjoiY21qd3UycTh5eGQ4YTBjODZ2MDJvbzZ4cyIsInpfaWlkIjoibnRVdEk3Ull1Iiwiel90IjoicyIsInpfc3QiOiJEaWFsIiwiel9sZWciOnRydWV9.uvIGp7v8znaonP4BPQGBWTJOC8_LKPzF_Sl59lWqr4q4AOREIWs8gHdHv5SF3STEFC-igVOVRForNQU7QdijK1T-qmR7VhNM9-4mSlEGWRN7u_o-1skKABczNxJs-TYO5vGi8mrd2uVUphdn2TinEROcp_nE5vEaU1I_rYSvM_CcUficjmV9nsZWKCCrNovWXUbaVdU8A1ZE8cpj9kZNOXCD2CBTLRB7eH-5gNrMhwxVhTYEAkRGIbex7-aZXg1lz0p_SIHr_e6gC59RmgBE4tbH-CIqF_wKbZ-SrlMk7QjY1V6CDV86lW8oPw4OaPJkm-Jjs1HYGrV20KCH7N1cTaR0O8D0B-c-FrSbgpqgablZL6nOv7Pu-r_0IIgA_av4UoykTOYKN_iUEtJzuSsJiz554yVDbpOYCnchCqXWUrJxOz0WffVFmJOkvSPEXMcLCVTBeaWBE386JOa1RVWXRpqaW3DsHV4CqcS7AeTyqLlmue2mxTenvhqq0-dfqGQJivR97fOs1CcCidxHUJCPhCtMyxQXKzSsnWfJiLhzVkX4mcWWvAkpJfhPNlNjiOa3y-7wM-9u6JCaCjd8ZMD7QZCqf7HSaUdstasgAJwInBBIdFRG4P0nnNIIZ7g_VDmXq-hC70in5r4QtjfAHRPmRPl7wFGG2L24B_KcdfwX0xk","type":"EdgeConnectType"}
Ziti edge controller logs
{"error":"invalid session","file":"github.com/openziti/ziti/controller/handler_edge_ctrl/common.go:334","func":"github.com/openziti/ziti/controller/handler_edge_ctrl.(*baseSessionRequestContext).loadFromBolt","level":"error","msg":"invalid session","operation":"create.terminator","time":"2026-01-02T12:48:29.512Z"}
{"_context":"ch{geJiU9KJr}-\u003eu{classic}-\u003ei{geJiU9KJr/OvAd}","error":"invalid session","file":"github.com/openziti/ziti/controller/handler_edge_ctrl/create_terminator_v2.go:206","func":"github.com/openziti/ziti/controller/handler_edge_ctrl.(*createTerminatorV2Handler).returnError","level":"error","msg":"responded with error","routerId":"geJiU9KJr","terminatorId":"5NQobnMm964fdwJHHXK3Wo","time":"2026-01-02T12:48:29.512Z"}
Observed Behavior
  • Connections work for a short period (~5 minutes).
  • After ~5 minutes, connections randomly fail with invalid session.
  • Restarting the Ziti Edge Desktop client temporarily restores connectivity.
  • Failures can affect different services each time; sometimes multiple services fail simultaneously.
I don’t know why it’s working only for ~5 minutes?
This bug makes it hard to maintain stable connectivity to services through Ziti Edge Tunnel. Further investigation into session management and possible race conditions in the Ziti Edge SDK or Router is needed.
Controller: v1.7.1 ZAC: 3.12.4
Ziti Desktop Edge Version 2.52 (551)
Hi @zhilyaev, 5 minutes is a strange timeout to me. It doesn't align with any of the defaults that I know of at this time which makes me wonder if there's something else causing an issue. Based on the version number it looks like that's a MacOS version (not Windows). You didn't change any of the configuration down to 5 minutes did you? Also are you using ext-jwt-signers for auth? Snippets of logs are sometimes helpful, but it's also sometimes not quite the full picture for us to know what's going on.
If you can tolerate it, I can see you're on a version newer than the github declared 'latest' (1.6.12). Usually if you're going to be on a version that's newer than our latest I'd say you should first update the controller and routers to the actual latest version which right now is 1.8.0-pre4.
After that, I think you'll have to wait for someone else to have a look at this and see if anything sticks out for them. I'll mention this to the team to see if anyone has any ideas.
Hi @TheLumberjack , thanks for the quick reply.
The ~5-minute timeout is approximate - sometimes it's 10 minutes, other times 2. I've noticed setting MTU to 1500 reduces the chances of hitting this bug, though it doesn't eliminate it entirely.
I'm using fully default Ziti configurations – no ext-jwt-signers or any config tweaks. I can provide Helm values / ziti-router’s configs if needed.
I've tested this on Windows, Android across various versions, always trying to stay on the latest stable releases. The issue persisted on both older controller and client versions, which prompted the upgrades – but as you can see from this thread, updating didn't resolve it.
This isn't isolated to me; any user with Ziti Edge Tunnel, Desktop, or Mobile on Windows, Linux, macOS, Android, etc., encounters the same problem.
I have the same issue with my Ziti installation (Controller: v1.7.2, ZAC: 3.12.4, ziti-edge-tunnel 1.9.5 as DaemonSet, ziti-router 1.7.2). It’s also not related to specific user/device/OS and I also don’t have ext-jwt signers configured for this installation.
And the strangest part of the issue is that I also have some permanent traffic in the Ziti network (vector sending logs from one cluster to another) and as I could see there are no outages at all. But other connections sometimes experience this issue.
@rndmit I have experienced pretty much same but after hours and because of it, I have downgraded ziti-edge-tunnels on linux back to version 1.7.12 and it works. Could you test that?
Mine is single controller running on docker not in kubernetes but contolle and router version are same.
I have also test env but haven’t encountered problems there.
And in production looks like probem arises when dial/intercept part is ziti-edge-tunnel 1.9.x, but on other end (bind/host) ziti-edge-tunnel 1.9.x works…
Haven’t tested yet v1.10.3 pre-versions.
Hello, thanks for your answer.
I’ve tried to downgrade ZET to 1.7.12 and looks like it works better. But I still see errors in desktop edge logs:
(80684)[2026-01-05T13:27:31.928Z]   ERROR ziti-sdk:connect.c:1070 connect_reply_cb() conn[1.6/BD0ZK6I9/Connecting](grafana) failed to connect, reason=invalid session
(80684)[2026-01-05T13:27:31.928Z]   ERROR tunnel-cbs:ziti_tunnel_cbs.c:103 on_ziti_connect() ziti dial failed: connection is closed
(80684)[2026-01-05T13:27:32.634Z]   ERROR ziti-sdk:connect.c:1070 connect_reply_cb() conn[1.7/tHOdafSc/Connecting](grafana) failed to connect, reason=invalid session
(80684)[2026-01-05T13:27:32.634Z]   ERROR tunnel-cbs:ziti_tunnel_cbs.c:103 on_ziti_connect() ziti dial failed: connection is closed
(80684)[2026-01-05T13:27:33.633Z]   ERROR ziti-sdk:connect.c:1070 connect_reply_cb() conn[1.8/a3-7H_yU/Connecting](grafana) failed to connect, reason=invalid session
(80684)[2026-01-05T13:27:33.633Z]   ERROR tunnel-cbs:ziti_tunnel_cbs.c:103 on_ziti_connect() ziti dial failed: connection is closed
(80684)[2026-01-05T13:27:35.117Z]   ERROR ziti-sdk:connect.c:1070 connect_reply_cb() conn[1.9/5aAH2A9b/Connecting](grafana) failed to connect, reason=invalid session
(80684)[2026-01-05T13:27:35.117Z]   ERROR tunnel-cbs:ziti_tunnel_cbs.c:103 on_ziti_connect() ziti dial failed: connection is closed
(80684)[2026-01-05T13:27:37.283Z]   ERROR ziti-sdk:connect.c:1070 connect_reply_cb() conn[1.10/YpdkkJck/Connecting](grafana) failed to connect, reason=invalid session
(80684)[2026-01-05T13:27:37.283Z]   ERROR tunnel-cbs:ziti_tunnel_cbs.c:103 on_ziti_connect() ziti dial failed: connection is closed
(80684)[2026-01-05T13:27:40.509Z]   ERROR ziti-sdk:connect.c:1070 connect_reply_cb() conn[1.11/6n5gJH9o/Connecting](grafana) failed to connect, reason=invalid session
(80684)[2026-01-05T13:27:40.509Z]   ERROR tunnel-cbs:ziti_tunnel_cbs.c:103 on_ziti_connect() ziti dial failed: connection is closed
(80684)[2026-01-05T13:27:45.509Z]   ERROR ziti-sdk:connect.c:1070 connect_reply_cb() conn[1.12/4PIKEFcm/Connecting](grafana) failed to connect, reason=invalid session
(80684)[2026-01-05T13:27:45.509Z]   ERROR tunnel-cbs:ziti_tunnel_cbs.c:103 on_ziti_connect() ziti dial failed: connection is closed
And it’s definitely closing connections as I could see notifications in Grafana saying about connectivity issues. Though now it’s not breaking all the Ziti connections untill reconnecting. IMHO, this downgrade does not fix the problem but makes it less annoying: I still need to press some buttons twice, but it’s no more like “open desktop tunnel → press turn Ziti off → press turn Ziti on”.
UPD. Oops, I’ve got the same issue after ~20 minutes. It’s again: “curl: (7) Failed to connect to port 443 after 52 ms: Couldn't connect to server”. And it works again after reconnecting. Nothing new in tunnel logs but only “failed to connect, reason=invalid session” errors as before.
