Is there a way to enable ECH for ziti network?
When a network is deployed behind OpenZITI it becomes invisible, Not reachable by IP, Not visible in port scans, Not discoverable by DNS. I think these features surpasses what Applying ECH over the ziti network offers. Correct me if I am wrong.
The goal is to protect the SNI (router’s name) in ClientHello messages using standardized solutions (ECH) so that connections reveal only that they are talking to an ECH‑enabled endpoint. Our ISP currently enforces a very restricted whitelist; could you advise which options you support (ECH or other approaches) to make the service reachable while preserving user privacy?
As much as I know OpenZITI doesn't natively support ECH in its standard deployment.
OpenZiti's Current Privacy Approach
TLS Encryption Throughout: OpenZiti encrypts all traffic end-to-end, but the initial ClientHello SNI is still visible (as with standard TLS)
IP-based Connections: You can configure OpenZiti edge routers to be accessed by IP address rather than hostname, which eliminates SNI entirely from the connection establishment
Wildcard Certificates: Using wildcard certs on edge routers means all services share the same SNI value, obscuring which specific service is being accessed
Options for Your Restricted ISP Environment
Option 1: IP-Only Access
# Configure edge router without hostname
advertise:
- tls:203.0.113.10:443
This eliminates SNI but requires whitelisting IP addresses.
Option 2: Generic SNI with Wildcard Cert
Use a generic domain like secure-gateway.example.com
Deploy wildcard certificate for *.example.com
All services share the same SNI, revealing only the gateway endpoint
Option 3: ECH via Reverse Proxy
Since OpenZiti doesn't support ECH directly, you could:
Place an ECH-capable reverse proxy (nginx with ECH patches, Cloudflare tunnel) in front of your edge router
The proxy handles ECH termination
Forwards decrypted connections to OpenZiti
Option 4: Request ISP Whitelist Addition
Whitelist your OpenZiti edge router's domain/IP
Justify based on business needs
This is the most straightforward if possible
We can support it. For a long time, the standard HTTP library didn’t support server-side ECH, but clients did. It looks like in Go 1.24, released this Feb, added it.
