Zrok agent: [POST /share][409] shareConflict
Hello, first of all thanks for this project :heart_eyes:
I am having the following issue, maybe I am not doing it properly or misunderstood something about the agent.
My workflow is the following i create a name:
zrok2 create name git
I start the agent:
zrok2 agent start
Then i do the share:
zrok2 share public 127.0.0.1:8181 -n public:git --headless
That works without issues, my problem is, i have a .service that starts zrok2 agent starton boot
and after reboot i get this error, the only fix so far is do the process all over again, delete name -> create name -> share with the name.
I assume i am doing this wrong? what is the proper way of doing this?
Basically what i want is to always re-share the tunnels on reboot
zrok2 v2.0.4 [6ff92039]
I would take a look at your shutdown behavior. This is the symptom you get when your share has an unclean shutdown or crash without a proper sigterm. If this is a docker container, docker doesn't care about clean shutdowns if you stop the container, you need to issue the zrok command to stop the share before shutdown.
