Zrok Controller certificate error when using public CAs on openziti controller
Hello! I have(had) a working zrok self-hosted setup but needed to switch over to using a public CA (Let’s Encrypt) on my openziti controller. Now I am getting this trying to start the controller:
INFO zrok/controller.inspectZiti: inspecting ziti controller configuration
panic: error getting ziti edge client: Post "https://<redacted>:1280/edge/management/v1/authenticate?method=password": x509: certificate signed by unknown authority
The certificate is sound and ziti-router doesn’t have any connection issues.
Also blew everything away for zrok and cleaned out the openziti configurations for ctrl and frontend. Tried to re-run the bootstrap and same error.
I’m going through this process myself in order to answer this question better… Hoping to get through that today. I’ll reply shortly if nobody else hops in
Another piece of the puzzle, attempting to enroll a new identity now
{"level":"info","msg":"http: TLS handshake error from <ip.ip.ip.ip>:64324: remote error: tls: unknown certificate authority","time":"2023-02-10T13:56:31.175Z"}
Feels like another public CA (Let’s Encrypt certs) issue. Some things playing nice, others not so much.
This specific error reminds me of a past problem that I have experienced.
Have you added the public certificate authority to the ziti controller?
There is a video that @TheLumberjack did a while ago.. and includes all of the instructions.. I would be interested to know if this resolves your problem.
I went through all the steps from start to finish enabling zrok in a letsencrypt-enabled openziti. As usual here's a walkthrough video along with all the commands I ran
YouTube Video:
Commands
Prerequisites
  • follow the full quickstart from the openziti docs
  • purchase/provision wildcard DNS entry and verify it resolves
  • obtain a keypair from letsencrypt. example:
    sudo certbot certonly -d '*.clint.demo.openziti.org' --manual --preferred-challenges dns
  • follow the openziti alt server guide
    • controller config, address fields
    • controller config, web.identity section key/server_cert
    • router config, and add alt_server_certs
    • sudo systemctl restart ziti-controller
    • sudo systemctl restart ziti-router
Run as root
currently zrok will end up wanting to find $HOME/.zrok
if you don't want to run as root, keep this in mind
sudo -i
establish a bunch of variables.
I put this into root's .bashrc
export ZROK_ROOT=$HOME/.zrok
export PATH=$PATH:$ZROK_ROOT/bin
export ZROK_CTRL_PORT=18444
export ZROK_FRONTEND_PORT=8080
export ZROK_NGINX_PORT=8445
export ZROK_ZITI_CTRL_WILDCARD=clint.demo.openziti.org
export ZROK_API_ADDRESS="api.${ZROK_ZITI_CTRL_WILDCARD}"
export ZROK_API_ENDPOINT=http://localhost:${ZROK_CTRL_PORT}
export ZROK_ADMIN_TOKEN=my_zrok_admin_token
Nginx
install nginx
sudo apt install nginx -y
backup config file if you want
sudo mv /etc/nginx/nginx.conf /etc/nginx/nginx.conf.orig
create a new "zrok-only" config file for nginx
sudo tee /etc/nginx/nginx.conf > /dev/null << HERE
events {
http {
  server {
      listen              ${ZROK_NGINX_PORT} ssl;
      server_name         ${ZROK_API_ADDRESS};
      ssl_certificate     /etc/letsencrypt/live/${ZROK_ZITI_CTRL_WILDCARD}/fullchain.pem;
      ssl_certificate_key /etc/letsencrypt/live/${ZROK_ZITI_CTRL_WILDCARD}/privkey.pem;
      ssl_protocols       TLSv1.2;
      ssl_ciphers         HIGH:!aNULL:!MD5;
      location / {
        proxy_pass      http://127.0.0.1:${ZROK_CTRL_PORT};
        error_log       /var/log/nginx/zrok-controller.log;
  server {
      server_name         *.${ZROK_ZITI_CTRL_WILDCARD};
      location / {
        proxy_pass       http://127.0.0.1:${ZROK_FRONTEND_PORT};
        proxy_set_header Host \$host;
        error_log        /var/log/nginx/zrok-frontend.log;
        proxy_busy_buffers_size   512k;
        proxy_buffers    4 512k;
        proxy_buffer_size   256k;
HERE
sudo nginx -t
sudo systemctl restart nginx
LetsEncrypt work
add the letsencrypt certificate chain to the ca bundle
cat /etc/letsencrypt/live/${ZROK_ZITI_CTRL_WILDCARD}/fullchain.pem >> $HOME/.ziti/quickstart/ip-172-31-11-231/pki/cas.pem
echo "verify the controller works properly using the browser and navigating to"
echo ""
echo "  https://ctrl.${ZROK_ZITI_CTRL_WILDCARD}:${ZITI_EDGE_CONTROLLER_PORT}"
echo ""
Logging into ziti
use this command to login to ziti:
export ZITI_EDGE_CTRL_ADVERTISED_HOST_PORT=ctrl.${ZROK_ZITI_CTRL_WILDCARD}:${ZITI_EDGE_CONTROLLER_PORT}
ziti edge login ${ZITI_EDGE_CTRL_ADVERTISED_HOST_PORT} -u $ZITI_USER -p $ZITI_PWD -y
Prep for zrok
mkdir -p $ZROK_ROOT/bin
cd $ZROK_ROOT/bin
wget https://github.com/openziti/zrok/releases/download/v0.3.1/zrok_0.3.1_linux_amd64.tar.gz
tar zxvf zrok_0.3.1_linux_amd64.tar.gz
output the ctrl.yml using the variables:
cat > $ZROK_ROOT/ctrl.yml << HERE
v:                  2
admin:
  secrets:
    -               $ZROK_ADMIN_TOKEN
endpoint:
  host:             0.0.0.0
  port:             $ZROK_CTRL_PORT
store:
  path:             zrok.db
  type:             sqlite3
ziti:
  api_endpoint:     "https://${ZITI_EDGE_CTRL_ADVERTISED_HOST_PORT}"
  username:         "${ZITI_USER}"
  password:         "${ZITI_PWD}"
HERE
boostrap zrok
zrok admin bootstrap $ZROK_ROOT/ctrl.yml
ZROK_FRONTEND_TOKEN
look at the logs, find and then set the token
ZROK_FRONTEND_TOKEN="j.mUrwBGrp"
zrok controller service
sudo tee /etc/systemd/system/zrok-controller.service > /dev/null << HERE
[Unit]
Description=zrok-controller
After=network.target
[Service]
User=root
WorkingDirectory=$ZROK_ROOT
ExecStart="$ZROK_ROOT/bin/zrok" controller "$ZROK_ROOT/ctrl.yml"
Restart=always
RestartSec=2
LimitNOFILE=65535
[Install]
WantedBy=multi-user.target
HERE
sudo systemctl daemon-reload
sudo systemctl enable --now zrok-controller
create the frontend
zrok admin create frontend ${ZROK_FRONTEND_TOKEN} public https://{token}.${ZROK_ZITI_CTRL_WILDCARD}:${ZROK_NGINX_PORT}
frontend config file
cat > $ZROK_ROOT/http-frontend.yml << HERE
host_match: ${ZROK_ZITI_CTRL_WILDCARD}
address: 0.0.0.0:${ZROK_FRONTEND_PORT}
HERE
sudo tee /etc/systemd/system/zrok-frontend.service > /dev/null << HERE
[Unit]
Description=zrok-frontend
[Service]
User=root
ExecStart="$ZROK_ROOT/bin/zrok" access public "$ZROK_ROOT/http-frontend.yml"
Restart=always
RestartSec=2
LimitNOFILE=65535
[Install]
HERE
sudo systemctl enable --now zrok-frontend
Do an invite
zrok invite
(enter your email and submit)
use journalctl to get the registration token:
journalctl -fu zrok-controller
use echo to output some instructions:
export ZROK_REGISTRATION_TOKEN="UrxepUAxiEyk"
echo "To finish the invitation, direct your browser to:"
echo ""
echo "    https://${ZROK_API_ADDRESS}:${ZROK_NGINX_PORT}/register/${ZROK_REGISTRATION_TOKEN}"
echo ""
'enable' zrok
get your enable token from the UI and use it to enable a shell somewhere
ZROK_ENABLE_TOKEN="UIFZ3NeMvFiU"
echo "in a target environment:"
echo "  - disable zrok if needed:"
echo "    zrok disable"
echo ""
echo "  - set the zrok apiEndpoint using the following:"
echo "    zrok config set apiEndpoint https://${ZROK_API_ADDRESS}:${ZROK_NGINX_PORT}"
echo ""
echo "  - enable the zrok env:"
echo "    zrok enable ${ZROK_ENABLE_TOKEN}"
I hope that shows you all the steps, and is clear/easy to follow
I forgot to mention in the long list of steps that you need to add the letsencrypt certs to the ca bundle specified in the controller identity.ca. It's this one step in the list:
There were other things along the way which caught me a little bit off guard, which was why I decided to just write down all the steps I took.
That is the one that got me, adding the certs to the bundle!
Thanks @TheLumberjack, you are my hero
