CVE-2026-45576
Summary
Alice runs zrok2 copy from a WebDAV or zrok drive controlled by Bob into a local filesystem target. Bob returns a DAV href such as /../outside.txt. The sync pipeline stores that path in the source inventory and passes it to FilesystemTarget.WriteStream, which joins it with the target root and creates the file outside Alice's selected directory.
Impact
Users given access to a zrok share may be able to traverse the directory tree arbitrarily with the sharing users' credentials, allowing for sensitive information to be overwritten.
Package
zrok
Affected versions
>= 0.4.23, < 2.0.3
Patched versions
2.0.3
CVSS:4.0/AV:N/AC:L/AT:N/PR:N/UI:A/VC:N/VI:H/VA:N/SC:H/SI:H/SA:N
Thanks go to aisafe-bot for reporting this issue.
