Hello, I am hoping someone has seen this before but when running a docker compose I am getting this error from the docker container logs unable to load environment; did you 'zrok enable'?
My host is a windows machine that has the zrok environment enabled already since it has executed the command zrok enable <my-token>
I'm not sure why the environment is not being mounted onto the docker container the error message is inconclusive. Here is the guide I am using for setting up the docker container Getting Started with Docker | Zrok
Here is my compose.yaml:
Hi @HowdyEveryone, welcome to the community and to zrok (and OpenZiti)!
Does ${HOME} work on windows? Are you running docker from WSL or from docker desktop? I use WSL myself, not docker desktop but I'm thinking that ${HOME} is the culprit?
I can't test the theory myself, but that'd be my quick guess.
Hi @TheLumberjack thank you for the quick response and for welcoming me to the community!! I'm running docker from docker desktop - after removing ${HOME} I still see the same error but yes i believe ${HOME} is not supported by windows
Oh sorry, I should have said you should replace it with whatever your userprofile is. for example for me, it'd be c:/users/clint/.zrok
I assume you also have a c: but from any prompt you can just run:
echo %userprofile%\.zrok
-- or if powershell --
echo $env:USERPROFILE\.zrok
add that in there instead of $HOME
Hmmm adding that looks like this C:/Users/MyComputer/.zrok/.zrok:/.zrok and it is showing the same error I also tried C:/Users/MyComputer/.zrok:/.zrok just in case but still it also shows that it cannot load the environment
You have a doubled up .zrok there. It should be:
C:/Users/MyComputer/.zrok/:/.zrok
I can install docker desktop and try it out if taht doesn't solve it
I tried with the above path and see the same error
Heres a screenshot of my C:/Users/MyComputer/.zrok path contents
Alright. I'll see if I can install docker desktop and give it a try. It might not be tonight, gimme a bit
Absolutely and no rush I appreciate you even looking into this with me and how responsive you are, thank you!!!
Here's how you'd do it with Windows and Docker Desktop:
services:
zrok:
image: openziti/zrok
restart: unless-stopped
volumes:
- ${USERPROFILE}/.zrok:/home/ziggy/.zrok
environment:
PFXLOG_NO_JSON: "true"
#entrypoint: ""
#command: sleep 1000
command: share reserved "xi2r7950z3to" --headless
Key points:
- removed
user: "${UID}", windows doesn't have a UID...
- used
${USERPROFILE} to find the zrok user dir
- used the home folder of the user inside docker for the mount point:
- I ran
zrok reserve public https://google.com to get a reserved token: your reserved share token is 'xi2r7950z3to'
Hope that solve your problem. One thing to make sure of is that your docker container can resolve and get to whatever you "reserve/share". It's easy to make a share that doesn't work from inside docker
Oh, btw, I left:
#entrypoint: ""
in the compose file... You can uncomment those (and comment out the other command) to exec into the container to poke around:
C:\Users\clint>docker exec -it clint-zrok-1 bash
[ziggy@473944b2cda5 ~]$ ls $HOME/.zrok
environment.json identities metadata.json
When inside the container, the ziggy user will need to be able to read all the files in $HOME/.zrok, in case you need to debug anything.
@TheLumberjack Clint thank you so much for helping me out with this and for the extra snippets, comments, and screenshots sincerely appreciate it. I was able to get it working after your help thank you!!!!!!!!!!!!!!!!!!
