I am trying to crate an iframe component and share it with zrok.
I am self-hosting Zrok at the moment and would like to remove the 'interstitial' page that shows up on the front-end.
Is there a way to achieve this through the command line perhaps ?
Maybe when using --> zrok reserve public ??
I would like a back-end solution to this. Maybe there is a config file I can change ?
I looked into it at the Docs but I can't follow what is described there.
I am using zrok v1
You'll need the information in the help document that @TheLumberjack sent you above, and here's an example configuration YAML file for the zrok frontend. That's where you will configure a specific zrok frontend to present the interstial page for public shares it serves.
Thanks for letting us know which guide you're following. Since you're self-hosting everything and you followed the zrok (CLI binary) install guide for Linux, I'm guessing you might have also followed the self-hosting guide for Linux, i.e., for running a zrok controller or frontend or both on Linux. That will work! Still, if you're cloud-friendly, the available self-hosting help for Docker
and Kubernetes is substantially more developed and complete.
I only installed the binary and went on to create public/private shares...
Running zrok status gives me this output:
Config:
CONFIG VALUE SOURCE
apiEndpoint https://api-v1.zrok.io binary
defaultFrontend public binary
headless false binary
Which means that I'm running -- NETFoundry'szrokinstance correct?
Therefore I am using the default public frontend which included the interstitial page.
I need to run the zero controller and frontend locally to be fully self-hosted correct ?
Thanks a lot for this help. I am very new to this as you can tell.
Okay, you're a zrok.io user (NetFoundry's zrok-as-a-service) using zrok in Linux who wants to bypass the interstitial for a particular public share, not a zrok self-hosting user needing to configure your zrok frontend to never present interstitial pages for all public shares of zrok accounts.
TL;DR You can bypass the interstitial page when sending web requests to the public share by using a command-line client/user-agent, like cURL, or by including a special HTTP header, skip_zrok_interstitial.
Here's a blog post about the why and the what of interstitial pages: zrok is Growing Up
If you want to know more, here's how it works on the zrok frontend server side: Interstitial Pages | zrok
Is it not possible to disable the interstitial page using zrok.io without the need for headers? One use case of mine is to test Apple ID Oauth from a server running locally, and it is not possible to configure custom headers on the callback URL.
