When I try to reserve a token with zrok I get 401 unauthorized and I need to release shares in orter to reserve again. the problem is that my IPs change a lot and I release and then reserve again but the shares get stuck in the panel and I need to release them manually. Any help?
Curious what plan you are on. You are most likely hitting your plan's limit on the number of reserved shares you can have at once.
