I'm currently setting up a self-hosted version of zrok to work on top of my already working openziti network, but something isn't right. I'm following the self-hosted guide and I was able to run the zrok admin bootstrap config.yml command without any issues.
However, when I'm trying to create a public frontend with the command zrok admin create frontend {token} public https://{token}.your.dns.name, I received the following 401 error:
I tried to skip the create frontend step and run the zrok controller which it is working, but I can't go any further on the configuration process which involves creating an account with zrok admin create account <email> <password> which also gives me a 401.
Did you skip the section about setting up ZROK_ADMIN_TOKEN and putting an admin token in your zrok controller config? The admin commands use an "admin token" for authentication. You need to ensure that you've added a unique admin token to your controller config, and then have set the ZROK_ADMIN_TOKEN environment variable to match.
The admin token was previous defined and match with the same value passed to the export ZROK_ADMIN_TOKEN command, however I missed the export ZROK_API_ENDPOINT command which was causing the error.
Thank you for the help and sorry about the incovenience!
