Communication between SDK and controller
What I want to know is how openziti knows the online status of its identity
Identity is considered online if it has one or more connections to edge routers
Is the identity itself reporting its own status to the controller or is the edge router reporting the identity status to the controller
Edge routers do that
Thank you for your reply
