Update: Looking around to get more information. It seems that system was rebooted and after that some services were working and some aren't in LAN.
I looked in Terminators (Manage Terminators) and some terminators went missing also. It should not happen if the system is rebooted! I added one and I was able to access the service locally. But still not able to enroll from WAN and the client already enrolled is not showing any service.
Controller Status
● ziti-controller.service - Ziti-Controller
     Loaded: loaded (/etc/systemd/system/ziti-controller.service; enabled; vendor preset: enabled)
     Active: active (running) since Mon 2023-09-18 07:11:14 UTC; 33min ago
   Main PID: 839 (ziti)
      Tasks: 9 (limit: 6970)
     Memory: 101.8M
        CPU: 16.585s
             └─839 /root/.ziti/quickstart/ztn/ziti-bin/ziti-v0.30.0/ziti controller run /root/.ziti/quickstart/ztn/ztn.yaml
Sep 18 07:44:10 ztn ziti[839]: {"_context":"ch{vQutsJRrHa}-\u003eu{classic}-\u003ei{O9qO}","error":"service 62D40l1tswENlw448sdPvZ has no terminators","file":"github.com/openziti/edge@v0.24.381/controller/handler_edge_ctrl/common.go:75","func":"github.com/openziti/edge/controller/handler_edge_ctrl.(*baseRequestHandler).returnError","level":"error","msg":"responded with error","operation":"create.circuit","routerId":"vQutsJRrHa","time":"2023-09-18T07:44:10.058Z","token":"7ad5570e-c992-47e7-b983-cd5b39751fdd"}
Sep 18 07:44:10 ztn ziti[839]: {"_context":"ch{vQutsJRrHa}-\u003eu{classic}-\u003ei{O9qO}","error":"service 62D40l1tswENlw448sdPvZ has no terminators","file":"github.com/openziti/edge@v0.24.381/controller/handler_edge_ctrl/common.go:75","func":"github.com/openziti/edge/controller/handler_edge_ctrl.(*baseRequestHandler).returnError","level":"error","msg":"responded with error","operation":"create.circuit","routerId":"vQutsJRrHa","time":"2023-09-18T07:44:10.314Z","token":"7ad5570e-c992-47e7-b983-cd5b39751fdd"}
Sep 18 07:44:10 ztn ziti[839]: {"_context":"ch{vQutsJRrHa}-\u003eu{classic}-\u003ei{O9qO}","error":"service 62D40l1tswENlw448sdPvZ has no terminators","file":"github.com/openziti/edge@v0.24.381/controller/handler_edge_ctrl/common.go:75","func":"github.com/openziti/edge/controller/handler_edge_ctrl.(*baseRequestHandler).returnError","level":"error","msg":"responded with error","operation":"create.circuit","routerId":"vQutsJRrHa","time":"2023-09-18T07:44:10.574Z","token":"7ad5570e-c992-47e7-b983-cd5b39751fdd"}
Sep 18 07:44:10 ztn ziti[839]: {"_context":"ch{vQutsJRrHa}-\u003eu{classic}-\u003ei{O9qO}","error":"service 62D40l1tswENlw448sdPvZ has no terminators","file":"github.com/openziti/edge@v0.24.381/controller/handler_edge_ctrl/common.go:75","func":"github.com/openziti/edge/controller/handler_edge_ctrl.(*baseRequestHandler).returnError","level":"error","msg":"responded with error","operation":"create.circuit","routerId":"vQutsJRrHa","time":"2023-09-18T07:44:10.828Z","token":"7ad5570e-c992-47e7-b983-cd5b39751fdd"}
Sep 18 07:44:11 ztn ziti[839]: {"_context":"ch{vQutsJRrHa}-\u003eu{classic}-\u003ei{O9qO}","error":"service 62D40l1tswENlw448sdPvZ has no terminators","file":"github.com/openziti/edge@v0.24.381/controller/handler_edge_ctrl/common.go:75","func":"github.com/openziti/edge/controller/handler_edge_ctrl.(*baseRequestHandler).returnError","level":"error","msg":"responded with error","operation":"create.circuit","routerId":"vQutsJRrHa","time":"2023-09-18T07:44:11.093Z","token":"7ad5570e-c992-47e7-b983-cd5b39751fdd"}
Sep 18 07:44:11 ztn ziti[839]: {"_context":"ch{vQutsJRrHa}-\u003eu{classic}-\u003ei{O9qO}","error":"service 62D40l1tswENlw448sdPvZ has no terminators","file":"github.com/openziti/edge@v0.24.381/controller/handler_edge_ctrl/common.go:75","func":"github.com/openziti/edge/controller/handler_edge_ctrl.(*baseRequestHandler).returnError","level":"error","msg":"responded with error","operation":"create.circuit","routerId":"vQutsJRrHa","time":"2023-09-18T07:44:11.339Z","token":"7ad5570e-c992-47e7-b983-cd5b39751fdd"}
Sep 18 07:44:11 ztn ziti[839]: {"_context":"ch{vQutsJRrHa}-\u003eu{classic}-\u003ei{O9qO}","error":"service 62D40l1tswENlw448sdPvZ has no terminators","file":"github.com/openziti/edge@v0.24.381/controller/handler_edge_ctrl/common.go:75","func":"github.com/openziti/edge/controller/handler_edge_ctrl.(*baseRequestHandler).returnError","level":"error","msg":"responded with error","operation":"create.circuit","routerId":"vQutsJRrHa","time":"2023-09-18T07:44:11.608Z","token":"7ad5570e-c992-47e7-b983-cd5b39751fdd"}
Sep 18 07:44:11 ztn ziti[839]: {"_context":"ch{vQutsJRrHa}-\u003eu{classic}-\u003ei{O9qO}","error":"service 62D40l1tswENlw448sdPvZ has no terminators","file":"github.com/openziti/edge@v0.24.381/controller/handler_edge_ctrl/common.go:75","func":"github.com/openziti/edge/controller/handler_edge_ctrl.(*baseRequestHandler).returnError","level":"error","msg":"responded with error","operation":"create.circuit","routerId":"vQutsJRrHa","time":"2023-09-18T07:44:11.862Z","token":"7ad5570e-c992-47e7-b983-cd5b39751fdd"}
Sep 18 07:44:12 ztn ziti[839]: {"_context":"ch{vQutsJRrHa}-\u003eu{classic}-\u003ei{O9qO}","error":"service 62D40l1tswENlw448sdPvZ has no terminators","file":"github.com/openziti/edge@v0.24.381/controller/handler_edge_ctrl/common.go:75","func":"github.com/openziti/edge/controller/handler_edge_ctrl.(*baseRequestHandler).returnError","level":"error","msg":"responded with error","operation":"create.circuit","routerId":"vQutsJRrHa","time":"2023-09-18T07:44:12.125Z","token":"7ad5570e-c992-47e7-b983-cd5b39751fdd"}
Sep 18 07:44:12 ztn ziti[839]: {"_context":"ch{vQutsJRrHa}-\u003eu{classic}-\u003ei{O9qO}","error":"service 62D40l1tswENlw448sdPvZ has no terminators","file":"github.com/openziti/edge@v0.24.381/controller/handler_edge_ctrl/common.go:75","func":"github.com/openziti/edge/controller/handler_edge_ctrl.(*baseRequestHandler).returnError","level":"error","msg":"responded with error","operation":"create.circuit","routerId":"vQutsJRrHa","time":"2023-09-18T07:44:12.379Z","token":"7ad5570e-c992-47e7-b983-cd5b39751fdd"}
Controller is unavailable!
[2023-09-18T07:27:34.991Z]    INFO ziti-sdk:utils.c:173 ziti_log_set_level() set log level: root=4/DEBUG
[2023-09-18T07:27:35.000Z]    INFO ziti-edge-tunnel:tun.c:171 tun_open() Wintun v0.13 loaded
[2023-09-18T07:27:35.000Z]    INFO ziti-edge-tunnel:tun.c:522 cleanup_adapters() Cleaning up orphan wintun adapters
[2023-09-18T07:27:35.289Z]    INFO ziti-edge-tunnel:tun.c:513 tun_delete_cb() Deleted wintun adapter ziti-tun0
[2023-09-18T07:27:35.290Z]    INFO ziti-edge-tunnel:tun.c:153 flush_dns() DnsFlushResolverCache succeeded
[2023-09-18T07:27:36.001Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 0, change = 3
[2023-09-18T07:27:36.001Z]    INFO ziti-edge-tunnel:tun.c:405 if_change_cb() default route is now via if_idx[20]
[2023-09-18T07:27:36.001Z]    INFO ziti-edge-tunnel:tun.c:411 if_change_cb() updating excluded routes
[2023-09-18T07:27:36.009Z]   DEBUG ziti-edge-tunnel:tun.c:377 tun_add_route() adding route: 100.64.0.0/10
[2023-09-18T07:27:36.009Z]   DEBUG ziti-edge-tunnel:windows-scripts.c:444 is_nrpt_policies_effective() Executing add test nrpt rule. powershell -Command "Add-DnsClientNrptRule -Namespace '.ziti.test' -NameServers '100.64.0.2' -Comment 'Added by ziti-edge-tunnel' -DisplayName 'ziti-edge-tunnel:.ziti.test'"
[2023-09-18T07:27:36.013Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 4, change = 0
[2023-09-18T07:27:36.139Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 4, change = 0
[2023-09-18T07:27:36.147Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 4, change = 0
[2023-09-18T07:27:37.663Z]   DEBUG ziti-edge-tunnel:windows-scripts.c:461 is_nrpt_policies_effective() test nrpt rule query returned 1 items
[2023-09-18T07:27:37.663Z]    INFO ziti-edge-tunnel:windows-scripts.c:469 is_nrpt_policies_effective() NRPT policies are effective in this system
[2023-09-18T07:27:37.663Z]   DEBUG ziti-edge-tunnel:windows-scripts.c:430 remove_single_nrpt_rule() Executing Remove nrpt rule: powershell -Command "Get-DnsClientNrptRule | where Namespace -eq '.ziti.test' | Remove-DnsClientNrptRule -Force -ErrorAction SilentlyContinue"
[2023-09-18T07:27:38.373Z]   DEBUG ziti-edge-tunnel:windows-scripts.c:435 remove_single_nrpt_rule() Removed nrpt rules
[2023-09-18T07:27:38.373Z]    INFO ziti-edge-tunnel:ziti-edge-tunnel.c:1553 run_tunnel() Setting interface metric to 255
[2023-09-18T07:27:38.373Z]   DEBUG ziti-edge-tunnel:windows-scripts.c:492 update_interface_metric() Executing Update Interface metric script :
[2023-09-18T07:27:38.373Z]   DEBUG ziti-edge-tunnel:windows-scripts.c:493 update_interface_metric() powershell -Command "$i=Get-NetIPInterface | Where -FilterScript {$_.InterfaceAlias -Eq "ziti-tun0"}
Set-NetIPInterface -InterfaceIndex $i.ifIndex -InterfaceMetric 255"
[2023-09-18T07:27:38.384Z]   DEBUG ziti-edge-tunnel:windows-scripts.c:499 update_interface_metric() Updated Interface metric
[2023-09-18T07:27:38.384Z]    INFO tunnel-sdk:ziti_tunnel.c:60 create_tunneler_ctx() Ziti Tunneler SDK (2.1.16)
[2023-09-18T07:27:38.389Z]   DEBUG ziti-edge-tunnel:tun.c:327 tun_setup_read() tun=00000230876f9490, adapter=0000023087b20860, session=0000023087b20cc0
[2023-09-18T07:27:38.389Z]    INFO tunnel-cbs:ziti_dns.c:168 seed_dns() DNS configured with range 100.64.0.0 - 100.127.255.255 (4194302 ips)
[2023-09-18T07:27:38.389Z]   DEBUG tunnel-sdk:ziti_tunnel.c:320 ziti_tunneler_intercept() intercepting address[udp:100.64.0.2/32:53] service[ziti:dns-resolver]
[2023-09-18T07:27:38.390Z]   DEBUG ziti-edge-tunnel:tun.c:377 tun_add_route() adding route: 100.64.0.2/32
[2023-09-18T07:27:38.390Z]    INFO ziti-edge-tunnel:ziti-edge-tunnel.c:1599 run_tunneler_loop() Loading identity files from C:\Windows\system32\config\systemprofile\AppData\Roaming/NetFoundry
[2023-09-18T07:27:38.390Z]   DEBUG ziti-edge-tunnel:ziti-edge-tunnel.c:1078 load_identities() skipping the configuration file: config.json
[2023-09-18T07:27:38.390Z]   DEBUG ziti-edge-tunnel:ziti-edge-tunnel.c:1081 load_identities() skipping the backup configuration file: config.json.backup
[2023-09-18T07:27:38.390Z]    INFO ziti-edge-tunnel:ziti-edge-tunnel.c:1093 load_identities() loading identity file: web-pc.json
[2023-09-18T07:27:38.390Z]   DEBUG ziti-edge-tunnel:ziti-edge-tunnel.c:1073 load_identities() skipping file in config dir as it's not the proper type. type: 2. file: ZitiUpdateService
[2023-09-18T07:27:38.392Z]   DEBUG ziti-edge-tunnel:windows-scripts.c:515 update_symlink() Executing update symlink script :
[2023-09-18T07:27:38.392Z]   DEBUG ziti-edge-tunnel:windows-scripts.c:516 update_symlink() powershell -Command "Get-Item -Path "C:\Program Files (x86)\NetFoundry Inc\Ziti Desktop Edge\/logs/service/ziti-tunneler.log" | Remove-Item
New-Item -Itemtype SymbolicLink -Path "C:\Program Files (x86)\NetFoundry Inc\Ziti Desktop Edge\/logs/service/ziti-tunneler.log" -Target "C:\Program Files (x86)\NetFoundry Inc\Ziti Desktop Edge\/logs/service/ziti-tunneler.log.202309180000.log""
[2023-09-18T07:27:38.405Z]   DEBUG ziti-edge-tunnel:windows-scripts.c:522 update_symlink() Updated symlink script
[2023-09-18T07:27:38.405Z]    INFO tunnel-cbs:ziti_tunnel_ctrl.c:864 load_ziti_async() attempting to load ziti instance from file[C:\Windows\system32\config\systemprofile\AppData\Roaming/NetFoundry/web-pc.json]
[2023-09-18T07:27:38.405Z]    INFO tunnel-cbs:ziti_tunnel_ctrl.c:871 load_ziti_async() loading ziti instance from C:\Windows\system32\config\systemprofile\AppData\Roaming\NetFoundry\web-pc.json
[2023-09-18T07:27:38.405Z]    INFO ziti-sdk:utils.c:173 ziti_log_set_level() set log level: root=4/DEBUG
[2023-09-18T07:27:38.405Z]   DEBUG ziti-sdk:config.c:73 load_config() trying to load config from file
[2023-09-18T07:27:38.407Z]    INFO ziti-edge-tunnel:ziti-edge-tunnel.c:1108 load_id_cb() identity[C:\Windows\system32\config\systemprofile\AppData\Roaming/NetFoundry/web-pc.json] loaded
[2023-09-18T07:27:38.410Z]   DEBUG ziti-edge-tunnel:instance-config.c:131 save_tunnel_status_to_file() Deleted backup config file C:\Windows\system32\config\systemprofile\AppData\Roaming/NetFoundry/config.json.backup
[2023-09-18T07:27:38.410Z]   DEBUG ziti-edge-tunnel:instance-config.c:134 save_tunnel_status_to_file() Copied config file to backup config file C:\Windows\system32\config\systemprofile\AppData\Roaming/NetFoundry/config.json.backup
[2023-09-18T07:27:38.411Z]   DEBUG ziti-edge-tunnel:instance-config.c:156 save_tunnel_status_to_file() Saved current tunnel status into Config file C:\Windows\system32\config\systemprofile\AppData\Roaming/NetFoundry/config.json
[2023-09-18T07:27:38.411Z]    INFO ziti-sdk:ziti.c:424 ziti_init_async() ztx[0] Ziti C SDK version 0.31.4 @68c3a76(HEAD) starting at (2023-09-18T07:27:38.411)
[2023-09-18T07:27:38.411Z]    INFO ziti-sdk:ziti.c:427 ziti_init_async() ztx[0] using tlsuv[<unknown>], tls[mbed TLS 3.2.1]
[2023-09-18T07:27:38.411Z]    INFO ziti-sdk:ziti.c:429 ziti_init_async() ztx[0] Loading ziti context with controller[https://openziti:8441]
[2023-09-18T07:27:38.411Z]    INFO ziti-sdk:ziti_ctrl.c:409 ziti_ctrl_init() ctrl[openziti] ziti controller client initialized
[2023-09-18T07:27:38.411Z]   DEBUG ziti-sdk:ziti.c:451 ziti_init_async() ztx[0] using metrics interval: 0
[2023-09-18T07:27:38.411Z]   DEBUG ziti-sdk:ziti.c:257 ziti_set_unauthenticated() ztx[0] setting api_session_state[0] to 0
[2023-09-18T07:27:38.411Z]   DEBUG ziti-sdk:ziti_ctrl.c:245 ziti_ctrl_clear_api_session() ctrl[openziti] clearing api session token for ziti_controller
[2023-09-18T07:27:38.411Z]   DEBUG ziti-sdk:ziti.c:918 ziti_re_auth() ztx[0] re-auth executing, transitioning to unauthenticated
[2023-09-18T07:27:38.411Z]   DEBUG ziti-sdk:ziti.c:288 is_api_session_expired() ztx[0] is_api_session_expired[TRUE] - api_session is null
[2023-09-18T07:27:38.411Z]    INFO ziti-sdk:ziti.c:865 ziti_re_auth_with_cb() ztx[0] starting to re-auth with ctlr[https://openziti:8441] api_session_status[0] api_session_expired[TRUE]
[2023-09-18T07:27:38.411Z]   DEBUG ziti-sdk:ziti.c:250 ziti_set_auth_started() ztx[0] setting api_session_state[0] to 1
[2023-09-18T07:27:38.411Z]   DEBUG ziti-sdk:ziti.c:322 ziti_stop_api_session_refresh() ztx[0] ziti_stop_api_session_refresh: stopping api session refresh
[2023-09-18T07:27:38.997Z]   DEBUG ziti-edge-tunnel:ziti-edge-tunnel.c:706 on_events_client() Received events client connection request, count: 1
[2023-09-18T07:27:38.997Z]   DEBUG ziti-edge-tunnel:ziti-edge-tunnel.c:755 send_events_message() Events Message => {"Op":"status","Status":{"Active":true,"Duration":4007,"StartTime":"2023-09-18T07:27:34.990631Z","Identities":[{"Name":"web-pc","Identifier":"C:\\Windows\\system32\\config\\systemprofile\\AppData\\Roaming/NetFoundry/web-pc.json","FingerPrint":"web-pc","Active":false,"Loaded":true,"Config":{"ztAPI":"https://openziti:8441"},"ControllerVersion":"v0.30.0","IdFileStatus":true,"MfaEnabled":false,"MfaNeeded":false,"Metrics":{"Up":0,"Down":0},"MfaMinTimeout":0,"MfaMaxTimeout":0,"MfaMinTimeoutRem":0,"MfaMaxTimeoutRem":0,"MinTimeoutRemInSvcEvent":0,"MaxTimeoutRemInSvcEvent":0,"Deleted":false,"Notified":false}],"IpInfo":{"Ip":"100.64.0.1","Subnet":"255.192.0.0","MTU":65535,"DNS":"100.64.0.2"},"LogLevel":"debug","ServiceVersion":{"Version":"2.1.16","BuildDate":"Tue-03/14/2023-20:18:12-+00"},"TunIpv4":"100.64.0.1","TunIpv4Mask":10,"AddDns":false,"ApiPageSize":25}}
[2023-09-18T07:27:38.997Z]   DEBUG ziti-edge-tunnel:ziti-edge-tunnel.c:662 on_cmd_client() Received IPC client connection request, count: 1
[2023-09-18T07:27:39.004Z]   DEBUG ziti-edge-tunnel:ziti-edge-tunnel.c:706 on_events_client() Received events client connection request, count: 2
[2023-09-18T07:27:39.004Z]   DEBUG ziti-edge-tunnel:ziti-edge-tunnel.c:755 send_events_message() Events Message => {"Op":"status","Status":{"Active":true,"Duration":4014,"StartTime":"2023-09-18T07:27:34.990631Z","Identities":[{"Name":"web-pc","Identifier":"C:\\Windows\\system32\\config\\systemprofile\\AppData\\Roaming/NetFoundry/web-pc.json","FingerPrint":"web-pc","Active":false,"Loaded":true,"Config":{"ztAPI":"https://openziti:8441"},"ControllerVersion":"v0.30.0","IdFileStatus":true,"MfaEnabled":false,"MfaNeeded":false,"Metrics":{"Up":0,"Down":0},"MfaMinTimeout":0,"MfaMaxTimeout":0,"MfaMinTimeoutRem":0,"MfaMaxTimeoutRem":0,"MinTimeoutRemInSvcEvent":0,"MaxTimeoutRemInSvcEvent":0,"Deleted":false,"Notified":false}],"IpInfo":{"Ip":"100.64.0.1","Subnet":"255.192.0.0","MTU":65535,"DNS":"100.64.0.2"},"LogLevel":"debug","ServiceVersion":{"Version":"2.1.16","BuildDate":"Tue-03/14/2023-20:18:12-+00"},"TunIpv4":"100.64.0.1","TunIpv4Mask":10,"AddDns":false,"ApiPageSize":25}}
[2023-09-18T07:27:39.004Z]   DEBUG ziti-edge-tunnel:ziti-edge-tunnel.c:662 on_cmd_client() Received IPC client connection request, count: 2
[2023-09-18T07:27:39.636Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 4, change = 0
[2023-09-18T07:27:40.106Z]    INFO ziti-edge-tunnel:ziti-edge-tunnel.c:635 on_cmd() received cmd <{"Data":{"OnOff":true,"Identifier":"C:\\Windows\\system32\\config\\systemprofile\\AppData\\Roaming/NetFoundry/web-pc.json"},"Command":"IdentityOnOff"}
[2023-09-18T07:27:40.106Z]    INFO ziti-edge-tunnel:ziti-edge-tunnel.c:221 on_command_resp() resp[0,len=65] = {"Success":false,"Error":"ziti context is not loaded","Code":500}
[2023-09-18T07:27:47.737Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 3, change = 0
[2023-09-18T07:27:53.418Z]   ERROR ziti-sdk:ziti_ctrl.c:155 ctrl_resp_cb() ctrl[openziti] request failed: -4039(connection timed out)
[2023-09-18T07:27:53.418Z]   ERROR ziti-sdk:ziti.c:1528 version_cb() ztx[0] failed to get controller version from https://openziti:8441 CONTROLLER_UNAVAILABLE(connection timed out)
[2023-09-18T07:27:53.418Z]    WARN ziti-sdk:ziti.c:1457 api_session_cb() ztx[0] failed to get api session from ctrl[https://openziti:8441] api_session_state[1] CONTROLLER_UNAVAILABLE[-15] connection timed out
[2023-09-18T07:27:53.418Z]   DEBUG ziti-sdk:ziti.c:1499 api_session_cb() ztx[0] unhandled error, setting api_session_timer to 5s
[2023-09-18T07:27:53.418Z]   DEBUG ziti-sdk:ziti.c:257 ziti_set_unauthenticated() ztx[0] setting api_session_state[1] to 0
[2023-09-18T07:27:53.418Z]   DEBUG ziti-sdk:ziti_ctrl.c:245 ziti_ctrl_clear_api_session() ctrl[openziti] clearing api session token for ziti_controller
[2023-09-18T07:27:53.418Z]   DEBUG ziti-sdk:ziti.c:327 ziti_schedule_api_session_refresh() ztx[0] ziti_schedule_api_session_refresh: scheduling api session refresh: 5000ms
[2023-09-18T07:27:53.418Z]    WARN tunnel-cbs:ziti_tunnel_ctrl.c:739 on_ziti_event() ziti_ctx controller connections failed: Ziti Controller is not available
[2023-09-18T07:27:53.418Z]    INFO ziti-edge-tunnel:ziti-edge-tunnel.c:1138 on_event() ztx[C:\Windows\system32\config\systemprofile\AppData\Roaming/NetFoundry/web-pc.json] context event : status is Ziti Controller is not available
[2023-09-18T07:27:53.418Z]   ERROR ziti-edge-tunnel:ziti-edge-tunnel.c:1193 on_event() ztx[C:\Windows\system32\config\systemprofile\AppData\Roaming/NetFoundry/web-pc.json] failed to connect to controller due to Ziti Controller is not available
[2023-09-18T07:27:53.418Z]   DEBUG ziti-edge-tunnel:ziti-edge-tunnel.c:755 send_events_message() Events Message => {"Op":"identity","Action":"added","Fingerprint":"web-pc","Id":{"Name":"web-pc","Identifier":"C:\\Windows\\system32\\config\\systemprofile\\AppData\\Roaming/NetFoundry/web-pc.json","FingerPrint":"web-pc","Active":false,"Loaded":true,"Config":{"ztAPI":"https://openziti:8441"},"ControllerVersion":"v0.30.0","IdFileStatus":true,"MfaEnabled":false,"MfaNeeded":false,"Metrics":{"Up":0,"Down":0},"MfaMinTimeout":0,"MfaMaxTimeout":0,"MfaMinTimeoutRem":0,"MfaMaxTimeoutRem":0,"MinTimeoutRemInSvcEvent":0,"MaxTimeoutRemInSvcEvent":0,"Deleted":false,"Notified":false}}
[2023-09-18T07:27:53.418Z]   DEBUG ziti-edge-tunnel:ziti-edge-tunnel.c:755 send_events_message() Events Message => {"Op":"controller","Action":"disconnected","Identifier":"C:\\Windows\\system32\\config\\systemprofile\\AppData\\Roaming/NetFoundry/web-pc.json","Fingerprint":"web-pc"}
[2023-09-18T07:27:58.432Z]   DEBUG ziti-sdk:ziti.c:839 api_session_refresh() ztx[0] api_session_refresh running
[2023-09-18T07:27:58.432Z]   DEBUG ziti-sdk:ziti.c:288 is_api_session_expired() ztx[0] is_api_session_expired[TRUE] - api_session is null
[2023-09-18T07:27:58.432Z]   DEBUG ziti-sdk:ziti.c:845 api_session_refresh() ztx[0] api_session_refresh re-auth due to no active api session[TRUE] or session expiration[TRUE]
[2023-09-18T07:27:58.432Z]   DEBUG ziti-sdk:ziti.c:918 ziti_re_auth() ztx[0] re-auth executing, transitioning to unauthenticated
[2023-09-18T07:27:58.432Z]   DEBUG ziti-sdk:ziti.c:257 ziti_set_unauthenticated() ztx[0] setting api_session_state[0] to 0
[2023-09-18T07:27:58.432Z]   DEBUG ziti-sdk:ziti_ctrl.c:245 ziti_ctrl_clear_api_session() ctrl[openziti] clearing api session token for ziti_controller
[2023-09-18T07:27:58.432Z]    INFO ziti-sdk:ziti.c:865 ziti_re_auth_with_cb() ztx[0] starting to re-auth with ctlr[https://openziti:8441] api_session_status[0] api_session_expired[TRUE]
[2023-09-18T07:27:58.432Z]   DEBUG ziti-sdk:ziti.c:250 ziti_set_auth_started() ztx[0] setting api_session_state[0] to 1
[2023-09-18T07:27:58.432Z]   DEBUG ziti-sdk:ziti.c:322 ziti_stop_api_session_refresh() ztx[0] ziti_stop_api_session_refresh: stopping api session refresh
[2023-09-18T07:27:58.800Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 3, change = 0
[2023-09-18T07:28:00.635Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 3, change = 0
[2023-09-18T07:28:03.944Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 20, change = 0
[2023-09-18T07:28:03.959Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 20, change = 0
[2023-09-18T07:28:04.060Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 20, change = 0
[2023-09-18T07:28:04.462Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 7, change = 0
[2023-09-18T07:28:04.726Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 7, change = 0
[2023-09-18T07:28:04.848Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 20, change = 0
[2023-09-18T07:28:05.885Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 3, change = 0
[2023-09-18T07:28:06.155Z]   DEBUG ziti-edge-tunnel:tun.c:401 if_change_cb() interface change: if_idx = 3, change = 0
[2023-09-18T07:28:07.272Z]   ERROR ziti-sdk:ziti_ctrl.c:155 ctrl_resp_cb() ctrl[openziti] request failed: -4079(software caused connection abort)
[2023-09-18T07:28:07.272Z]    WARN ziti-sdk:ziti.c:1457 api_session_cb() ztx[0] failed to get api session from ctrl[https://openziti:8441] api_session_state[1] CONTROLLER_UNAVAILABLE[-15] software caused connection abort
[2023-09-18T07:28:07.272Z]   DEBUG ziti-sdk:ziti.c:1499 api_session_cb() ztx[0] unhandled error, setting api_session_timer to 5s
[2023-09-18T07:28:07.272Z]   DEBUG ziti-sdk:ziti.c:257 ziti_set_unauthenticated() ztx[0] setting api_session_state[1] to 0
[2023-09-18T07:28:07.272Z]   DEBUG ziti-sdk:ziti_ctrl.c:245 ziti_ctrl_clear_api_session() ctrl[openziti] clearing api session token for ziti_controller
[2023-09-18T07:28:07.272Z]   DEBUG ziti-sdk:ziti.c:327 ziti_schedule_api_session_refresh() ztx[0] ziti_schedule_api_session_refresh: scheduling api session refresh: 5000ms
Trace Log
[2023-09-18T07:40:52.335Z]   TRACE ziti-edge-tunnel:tun.c:303 tun_read() starting read
[2023-09-18T07:40:52.335Z]   TRACE tunnel-sdk:tunnel_udp.c:183 recv_udp() received datagram 100.64.0.1:57143->100.64.0.1:5355
[2023-09-18T07:40:52.335Z]   TRACE tunnel-sdk:tunnel_udp.c:208 recv_udp() no intercepted addresses match udp:224.0.0.252:5355
[2023-09-18T07:40:52.335Z]   TRACE tunnel-sdk:tunnel_udp.c:183 recv_udp() received datagram FE80::D5A1:7544:4315:CEAD:56984->FE80::D5A1:7544:4315:CEAD:5355
[2023-09-18T07:40:52.335Z]   TRACE tunnel-sdk:tunnel_udp.c:208 recv_udp() no intercepted addresses match udp:FF02::1:3:5355
[2023-09-18T07:40:52.335Z]   TRACE tunnel-sdk:tunnel_udp.c:183 recv_udp() received datagram 100.64.0.1:56984->100.64.0.1:5355
[2023-09-18T07:40:52.693Z]   TRACE ziti-edge-tunnel:tun.c:303 tun_read() starting read
[2023-09-18T07:40:52.693Z]   TRACE tunnel-sdk:tunnel_udp.c:183 recv_udp() received datagram FE80::D5A1:7544:4315:CEAD:53912->FE80::D5A1:7544:4315:CEAD:3702
[2023-09-18T07:40:52.693Z]   TRACE tunnel-sdk:tunnel_udp.c:208 recv_udp() no intercepted addresses match udp:FF02::C:3702
[2023-09-18T07:40:52.753Z]   TRACE ziti-edge-tunnel:tun.c:303 tun_read() starting read
[2023-09-18T07:40:52.753Z]   TRACE tunnel-sdk:tunnel_udp.c:183 recv_udp() received datagram FE80::D5A1:7544:4315:CEAD:57143->FE80::D5A1:7544:4315:CEAD:5355
[2023-09-18T07:40:52.753Z]   TRACE tunnel-sdk:tunnel_udp.c:208 recv_udp() no intercepted addresses match udp:FF02::1:3:5355
[2023-09-18T07:40:52.753Z]   TRACE tunnel-sdk:tunnel_udp.c:183 recv_udp() received datagram FE80::D5A1:7544:4315:CEAD:56811->FE80::D5A1:7544:4315:CEAD:5355
[2023-09-18T07:40:52.753Z]   TRACE tunnel-sdk:tunnel_udp.c:183 recv_udp() received datagram FE80::D5A1:7544:4315:CEAD:52533->FE80::D5A1:7544:4315:CEAD:5355
[2023-09-18T07:40:52.753Z]   TRACE tunnel-sdk:tunnel_udp.c:183 recv_udp() received datagram 100.64.0.1:52533->100.64.0.1:5355
[2023-09-18T07:40:52.753Z]   TRACE tunnel-sdk:tunnel_udp.c:208 recv_udp() no intercepted addresses match udp:224.0.0.252:5355
[2023-09-18T07:40:52.753Z]   TRACE tunnel-sdk:tunnel_udp.c:183 recv_udp() received datagram 100.64.0.1:57143->100.64.0.1:5355
[2023-09-18T07:40:52.753Z]   TRACE tunnel-sdk:tunnel_udp.c:183 recv_udp() received datagram 100.64.0.1:56811->100.64.0.1:5355
[2023-09-18T07:40:52.753Z]   TRACE tunnel-sdk:tunnel_udp.c:183 recv_udp() received datagram FE80::D5A1:7544:4315:CEAD:56984->FE80::D5A1:7544:4315:CEAD:5355
[2023-09-18T07:40:52.753Z]   TRACE tunnel-sdk:tunnel_udp.c:183 recv_udp() received datagram 100.64.0.1:56984->100.64.0.1:5355
