I hope you all are doing well.
I installed an edge client on another web server, details are below
IP: 192.168.20.x
OS: Ubuntu 18LTS
URL: erpaman.ziti:8069
The response of the web "erpaman.ziti" is slow whereas if accessing "erp.aman.lc" without ziti tunnel it's normal. The difference is around 10 seconds but sometimes it takes more time to load.
Note: OpenZiti Server IP 192.168.17.x OS: Ubuntu 22LTS. Controller: v0.30.0 ZAC: 2.8.7
Here's the output of the edge client on web server
Before restart service. (There were more than1 terminators for edge client.)
β ziti-edge-tunnel.service - Ziti Edge Tunnel
Loaded: loaded (/lib/systemd/system/ziti-edge-tunnel.service; enabled; vendor preset: enabled)
Drop-In: /lib/systemd/system/ziti-edge-tunnel.service.d
ββ10-run-as-root.conf
Active: active (running) since Tue 2023-12-05 12:59:10 +03; 3min 18s ago
Process: 2062 ExecStartPre=/opt/openziti/bin/ziti-edge-tunnel.sh (code=exited, status=0/SUCCESS)
Main PID: 2063 (ziti-edge-tunne)
Tasks: 9 (limit: 4915)
CGroup: /system.slice/ziti-edge-tunnel.service
ββ2063 /opt/openziti/bin/ziti-edge-tunnel run --verbose=2 --dns-ip-range=100.64.0.1/10 --identity-dir=/opt/openziti/etc/identities
05 12:59:10 odoo-prod systemd[1]: Starting Ziti Edge Tunnel...
05 12:59:10 odoo-prod ziti-edge-tunnel.sh[2062]: NOTICE: no new JWT files in /opt/openziti/etc/identities/*.jwt
05 12:59:10 odoo-prod systemd[1]: Started Ziti Edge Tunnel.
05 12:59:10 odoo-prod ziti-edge-tunnel[2063]: (2063)[ 0.042] WARN ziti-edge-tunnel:resolvers.c:317 set_systemd_resolved_link_setting() Attempted to call unknown method: SetLinkDNSOverTLS for link: (ziti0)
05 13:00:29 odoo-prod ziti-edge-tunnel[2063]: (2063)[ 78.472] WARN ziti-sdk:channel.c:337 on_channel_send() ch[0] write delay = 5.231 q=2 qs=19443
05 13:00:35 odoo-prod ziti-edge-tunnel[2063]: (2063)[ 84.804] WARN ziti-sdk:conn_bridge.c:305 on_ziti_data() br[0.5] closing bridge due to error: -21(connection to edge router terminated)
05 13:00:35 odoo-prod ziti-edge-tunnel[2063]: (2063)[ 84.804] WARN ziti-sdk:conn_bridge.c:305 on_ziti_data() br[0.3] closing bridge due to error: -21(connection to edge router terminated)
05 13:00:35 odoo-prod ziti-edge-tunnel[2063]: (2063)[ 84.804] WARN ziti-sdk:bind.c:346 on_message() binding failed: -21/connection to edge router terminated
05 13:00:44 odoo-prod ziti-edge-tunnel[2063]: (2063)[ 93.659] ERROR ziti-sdk:channel.c:637 hello_reply_cb() ch[0] failed to receive Hello response due to -21(connection to edge router terminated)
After restart service
Active: active (running) since Tue 2023-12-05 13:02:58 +03; 21min ago
Process: 2612 ExecStartPre=/opt/openziti/bin/ziti-edge-tunnel.sh (code=exited, status=0/SUCCESS)
Main PID: 2613 (ziti-edge-tunne)
ββ2613 /opt/openziti/bin/ziti-edge-tunnel run --verbose=2 --dns-ip-range=100.64.0.1/10 --identity-dir=/opt/openziti/etc/identities
05 13:05:54 odoo-prod ziti-edge-tunnel[2613]: (2613)[ 175.382] WARN ziti-sdk:conn_bridge.c:305 on_ziti_data() br[0.14] closing bridge due to error: -21(connection to edge router terminated)
05 13:05:54 odoo-prod ziti-edge-tunnel[2613]: (2613)[ 175.382] WARN ziti-sdk:conn_bridge.c:305 on_ziti_data() br[0.13] closing bridge due to error: -21(connection to edge router terminated)
05 13:05:54 odoo-prod ziti-edge-tunnel[2613]: (2613)[ 175.382] WARN ziti-sdk:bind.c:346 on_message() binding failed: -21/connection to edge router terminated
05 13:05:57 odoo-prod ziti-edge-tunnel[2613]: (2613)[ 178.800] ERROR ziti-sdk:channel.c:637 hello_reply_cb() ch[0] failed to receive Hello response due to -21(connection to edge router terminated)
05 13:07:56 odoo-prod ziti-edge-tunnel[2613]: (2613)[ 297.181] WARN ziti-sdk:channel.c:337 on_channel_send() ch[0] write delay = 5.765 q=2 qs=19426
05 13:08:19 odoo-prod ziti-edge-tunnel[2613]: (2613)[ 320.089] ERROR ziti-sdk:channel.c:595 latency_timeout() ch[0] no read/write traffic on channel since before latency probe was sent, closing channel
05 13:08:19 odoo-prod ziti-edge-tunnel[2613]: (2613)[ 320.089] WARN ziti-sdk:conn_bridge.c:305 on_ziti_data() br[0.24] closing bridge due to error: -20(operation did not complete in time)
05 13:08:19 odoo-prod ziti-edge-tunnel[2613]: (2613)[ 320.089] WARN ziti-sdk:conn_bridge.c:305 on_ziti_data() br[0.22] closing bridge due to error: -20(operation did not complete in time)
05 13:08:19 odoo-prod ziti-edge-tunnel[2613]: (2613)[ 320.089] WARN ziti-sdk:bind.c:346 on_message() binding failed: -20/operation did not complete in time
05 13:12:00 odoo-prod ziti-edge-tunnel[2613]: (2613)[ 541.321] WARN ziti-sdk:channel.c:337 on_channel_send() ch[0] write delay = 5.787 q=2 qs=19147
Thank you for your support
