Error in ziti-edge-tunnel
I am trying to get an endpoint enrolled on my ziti network. Here are the steps taken -
1.Installed ziti-edge-tunnel from OpenZitiโ€™s RPM repo
2. Confirmed that systemd-resolved is working
3. Enrolled the endpoint ( got success )
4. Started ziti-edge-tunnel service
Aug 31 23:24:53 ip-10-10-10-10.us-west-2.compute.internal ziti-edge-tunnel[3447]: [      627.424]   ERROR ziti-sdk:channel.c:875 on_channel_connect_internal() ch[0] failed to connect [-3008/unknown node or service]
Also see following error -
Aug 31 23:34:53 ip-10-10-10-10.us-west-2.compute.internal ziti-edge-tunnel[3447]: [      732.424]   WARN ziti-sdk:connect.c:344 connect_timeout() conn[0.0/Connecting] connect timeout: no suitable edge router
Identities
~ > ziti edge list identities
โ•ญโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ฌโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ฌโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ฌโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ•ฎ
โ”‚ ID        โ”‚ NAME                             โ”‚ TYPE   โ”‚ ATTRIBUTES โ”‚
โ”œโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ค
โ”‚ AAAAAAAA  โ”‚ er1                              โ”‚ Router โ”‚ all-routersโ”‚
โ”‚ BBBBBBBB  โ”‚ ep1                              โ”‚ Device โ”‚ all-eps    โ”‚
โ”‚ CCCCCCCC  โ”‚ ep2                              โ”‚ Device โ”‚ all-eps    โ”‚
โ•ฐโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ•ฏ
Routers
~ > ziti edge list edge-routers
โ•ญโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ฌโ”€โ”€โ”€โ”€โ”€โ”€โ”ฌโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ฌโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ฌโ”€โ”€โ”€โ”€โ”€โ”€โ”ฌโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ•ฎ
โ”‚ ID        โ”‚ NAME โ”‚ ONLINE โ”‚ ALLOW TRANSIT โ”‚ COST โ”‚ ATTRIBUTES โ”‚
โ”œโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ค
โ”‚ AAAAAAAA  โ”‚ er1  โ”‚ true   โ”‚ true          โ”‚    0 โ”‚ all-routersโ”‚
โ•ฐโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ•ฏ
edge-router-policies
~ > ziti edge list edge-router-policies
โ•ญโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ฌโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ฌโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ฌโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ•ฎ
โ”‚ ID                     โ”‚ NAME                         โ”‚ EDGE ROUTER ROLES โ”‚ IDENTITY ROLES โ”‚
โ”œโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ผโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ค
โ”‚ xxxxxxxxxxxxxxxxxxxxxx โ”‚ erp-default-allow            โ”‚ #all-routers      โ”‚ #all-eps       โ”‚
โ”‚ AAAAAAAAA              โ”‚ edge-router-AAAAAAAA-system  โ”‚ @er1              โ”‚ @er1           โ”‚
โ•ฐโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”ดโ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ”€โ•ฏ
Went through troubleshooting steps and made sure there is no PKI setup issue. ( er.cert is the edge-router identity cert and identity.ca obtained from tunneler host enrollment )
 > verifyCertAgainstPool ./er.cert ./identity.ca
    Verifying that this certificate:
        - ./er.cert
    is valid for this ca pool:
        - ./identity.ca
./er.cert: OK
============      SUCCESS!      ============
What am I missing? :slight_smile:
TIA.
This seems to me that the endpoint is allowed to connect to an edge router (via policies, the endpoint is allowed to connect to a given router) but the edge router has an advertised address configured that isnโ€™t resolvable/addressable by the endpoint.
I am pretty sure thatโ€™s the issue. So verify the address advertised in listeners.options for the edge router
listeners:
  - binding: edge
    address: tls:0.0.0.0:8442
      advertise: ext_router_fqdn:8442 <-- is this address reachable by the endpoint?
Take a bow @TheLumberjack :slight_smile:
Everything else checked out NACL, SG, R53 record except there was a typo in the advertised url ( . instead of - )
I see both endpoints are online now.
Thank you! :slight_smile:
Nice!
Now on to the final frontier of service policies! :slight_smile:
