Hi so I tried running the proxy example in zrok/sdk/python/examples/proxy/proxy.py at main · openziti/zrok · GitHub and encountered the following error: TypeError: (<openziti.context.ZitiContext object at 0x7cc2c35fdeb0>, 0) is not a ZitiContext or str instance
For context heres the full stack trace:
$ python proxy_test.py ``http://127.0.0.1:3000
2026-03-13 20:59:25,750 - main - INFO - === Starting proxy server ===
2026-03-13 20:59:25,750 - main - INFO - Target URL: ``http://127.0.0.1:3000
2026-03-13 20:59:25,750 - main - INFO - Share mode: public
2026-03-13 20:59:29,837 - main - INFO - Access proxy at: ``https://is25s1nl69lh.share.zrok.io
File "/home/milselarch/projects/zrok_startup/proxy_test.py", line 66, in
main()
File "/home/milselarch/projects/zrok_startup/proxy_test.py", line 62, in main
proxy_share.run()
File "/home/milselarch/projects/zrok_startup/venv/lib/python3.12/site-packages/zrok/proxy.py", line 193, in run
run_server()
File "/home/milselarch/projects/zrok_startup/venv/lib/python3.12/site-packages/zrok/decor.py", line 31, in zrockified
func(*args, **kwargs)
File "/home/milselarch/projects/zrok_startup/venv/lib/python3.12/site-packages/zrok/proxy.py", line 191, in run_server
serve(self._app, port=DUMMY_PORT, _quiet=True)
File "/home/milselarch/projects/zrok_startup/venv/lib/python3.12/site-packages/waitress/init.py", line 13, in serve
server = _server(app, **kw)
File "/home/milselarch/projects/zrok_startup/venv/lib/python3.12/site-packages/waitress/server.py", line 78, in create_server
last_serv = TcpWSGIServer(
File "/home/milselarch/projects/zrok_startup/venv/lib/python3.12/site-packages/waitress/server.py", line 243, in init
self.bind_server_socket()
File "/home/milselarch/projects/zrok_startup/venv/lib/python3.12/site-packages/waitress/server.py", line 364, in bind_server_socket
self.bind(sockaddr)
File "/home/milselarch/projects/zrok_startup/venv/lib/python3.12/site-packages/waitress/wasyncore.py", line 374, in bind
return self.socket.bind(addr)
File "/home/milselarch/projects/zrok_startup/venv/lib/python3.12/site-packages/openziti/zitisock.py", line 97, in bind
ztx = context.get_context(cfg['ztx'], timeout=cfg.get('timeout', 0))
File "/home/milselarch/projects/zrok_startup/venv/lib/python3.12/site-packages/openziti/context.py", line 119, in get_context
raise TypeError(f'{ztx} is not a ZitiContext or str instance')
2026-03-13 20:59:39,158 - zrok.proxy - INFO - Share is25s1nl69lh released
Python version: 3.12.3
Operating System: Ubuntu 24.04
zrok library version: 1.1.11
