Following the ziti router as lan gateway example
I am trying to follow Using an OpenZiti router as a LAN Gateway but running into error.
These are the steps I have taken -
  1. Created the router with option -t
  2. Enrolled the router ( success )
  3. Started systemd-resolved and symlinked /etc/resolv.conf → /run/systemd/resolve/stub-resolv.conf
  4. started router, it came up fine ( tunneler binding mode=host )
Now to use it as LAN Gateway -
5. Modified router config for tunnel binding as followed
listeners:
  - binding: tunnel
      svcPollRate: 15s
      resolver: udp://10.10.10.10:53
      dnsSvcIpRange: 100.64.0.1/10
      lanIf: eth0
restarted the router and it errors out with following message -
[   2.650]    INFO edge/tunnel/dns.NewDnsServer: dns server running at 10.10.10.10:53
[   2.650]    INFO edge/tunnel/dns.(*resolver).AddHostname: adding ziti-tunnel.resolver.test = 19.65.28.94 to resolver
[   2.652]   FATAL edge/tunnel/dns.NewDnsServer: system resolver test failed: failed to resolve ziti-tunnel.resolver.test: lookup ziti-tunnel.resolver.test on 127.0.0.53:53: no such host
ziti-tunnel runs an internal DNS server which must be first in the host's
resolver configuration. On systems that use NetManager/dhclient, this can
be achieved by adding the following to /etc/dhcp/dhclient.conf:
    prepend domain-name-servers 10.10.10.10:53;
I tried doing that ( editing /etc/dhcp/dhclient.conf ) but it didnt help.
What am I missing here? TIA.
Do you have port 53 open on TCP and UDP?
Looks like the self test is using 127.0.0.53 but the message told you to bind on 10.10.10.10. I wonder if there’s already a resolver on that loopback address. Try using 127.0.0.53 in the config and see what happens? If it doesn’t work can you give me the is version you’re using?
Hi av-dev:
the demo was setup on VMs running ubuntu 22.04. Ubuntu uses systems-resolved for name resolution
If you are running with similar setup you may have missed these two steps:
sudo sh -c ‘echo DNS=10.10.10.10 >> /etc/systemd/resolved.conf’
sudo systemctl restart systemd-resolved
Which injects the local lan IP in to the system-resolved global resolvers list.
I did that part. And its like chicken-egg situation. If I add that in /etc/systemd/resolved.conf then edge router does not come up ( dns resolution fails )
and if I remove it, edge router prints the message as above.
I am doing this on RHEL8 with systemd-resolved as well.
Did you verify the DNS=10.10.10.10 entry in /etc/systemd/resolved.conf
Although one thing I noticed, when I run resolvectl the eth0 interface does not show DNS in “Current scope” of Link2 ( eth0)
You should see this in global section if not then DNS entry probably not in /etc/systemd/resolved.conf
Global
Protocols: -LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported
resolv.conf mode: stub
DNS Servers: 10.10.10.10
Ii noticed a typo in our commands doc its missing single quotes around echo DNS= >> /etc/systemd/resolved.conf if you copy and pasted it would fail.
yeah I do see it in the “Global” DNS servers
@TheLumberjack If i add 127.0.0.53 in config then edge-router gives following error -
[   0.758]   FATAL edge/tunnel/dns.NewDnsServer: dns server failed to start: listen udp 127.0.0.53:53: bind: address already in use
Yes I did and to make sure edge-router comes up I had to add my local DNS servers as subsequent entries so what I have in /etc/systemd/resolved.conf is -
DNS=10.10.10.10 10.10.10.11 10.10.10.12 10.10.10.13
here is output from newly installed ubuntu 22.04 server with lan ip 10.250.50.78 before and after setting DNS in resolved.conf. As you can see we see the issue that you have prior to setting the DNS= and restarting systemd-resolved but works as expected after.
ziggy@testbox:~$ ip add
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: ens33: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:0c:29:5d:c7:2a brd ff:ff:ff:ff:ff:ff
altname enp2s1
inet 10.250.50.78/24 metric 100 brd 10.250.50.255 scope global dynamic ens33
valid_lft 84199sec preferred_lft 84199sec
inet6 fe80::20c:29ff:fe5d:c72a/64 scope link
ziggy@testbox:~$
ziggy@testbox:~$
ziggy@testbox:~$ resolvectl
Global
Link 2 (ens33)
Current Scopes: DNS
Protocols: +DefaultRoute +LLMNR -mDNS -DNSOverTLS DNSSEC=no/unsupported
Current DNS Server: 10.250.50.254
DNS Servers: 10.250.50.254
ziggy@testbox:~$
ziggy@testbox:~$
ziggy@testbox:~$ cat /etc/systemd/resolved.conf
[Resolve]
#DNS=
#FallbackDNS=
#Domains=
#DNSSEC=no
#DNSOverTLS=no
#MulticastDNS=no
#LLMNR=no
#Cache=no-negative
#CacheFromLocalhost=no
#DNSStubListener=yes
#DNSStubListenerExtra=
#ReadEtcHosts=yes
#ResolveUnicastSingleLabel=no
ziggy@testbox:~$
ziggy@testbox:~$
ziggy@testbox:~$ sudo ./ziti-router run config.yml
An update with v0.26.5 is available for ziti-router v0.25.10 from
[ 0.324] INFO ziti/ziti-router/subcmd.run: {configFile=[config.yml] routerId=[P5xIkiIbE6] build-date=[2022-05-24T19:19:48Z] revision=[a32a117f9472] os=[linux] arch=[amd64] version=[v0.25.10] go-version=[go1.18.2]} starting ziti-router
[ 0.324] WARNING edge/router/internal/edgerouter.(*Config).LoadConfigFromMap: Invalid heartbeat interval [0] (min: 60, max: 10), setting to default [60]
[ 0.324] INFO fabric/router/forwarder.(*Faulter).run: started
[ 0.325] INFO fabric/router/forwarder.(*Scanner).run: started
[ 0.325] INFO fabric/router.(*Router).showOptions: ctrl = {“OutQueueSize”:4,“MaxQueuedConnects”:1,“MaxOutstandingConnects”:16,“ConnectTimeout”:1000000000,“DelayRxStart”:false,“WriteTimeout”:0}
[ 0.325] INFO fabric/router.(*Router).showOptions: metrics = {“ReportInterval”:60000000000,“MessageQueueSize”:10}
[ 0.325] INFO fabric/router.(*Router).initializeHealthChecks: starting health check with ctrl ping initially after 15s, then every 30s, timing out after 15s
[ 0.325] INFO fabric/router.(*Router).startXlinkDialers: started Xlink dialer with binding [transport]
[ 0.325] INFO edge/router/xgress_edge.(*listener).Listen: {address=[tls:0.0.0.0:443]} starting channel listener
[ 0.325] INFO fabric/metrics.GoroutinesPoolMetricsConfigF.func1.1: {maxWorkers=[100] idleTime=[10s] poolType=[pool.listener.xgress_edge] minWorkers=[1] maxQueueSize=[50]} starting goroutine pool
[ 0.325] INFO fabric/router.(*Router).startXgressListeners: created xgress listener [edge] at [tls:0.0.0.0:443]
[ 0.325] INFO fabric/router.(*Router).startXgressListeners: created xgress listener [tunnel] at
[ 0.326] INFO edge/router/xgress_edge.(*Acceptor).Run: starting
[ 0.558] INFO fabric/metrics.GoroutinesPoolMetricsConfigF.func1.1: {minWorkers=[0] maxWorkers=[32] maxQueueSize=[1000] idleTime=[30s] poolType=[pool.link.dialer]} starting goroutine pool
[ 0.558] INFO fabric/metrics.GoroutinesPoolMetricsConfigF.func1.1: {maxWorkers=[128] maxQueueSize=[1000] poolType=[pool.route.handler] idleTime=[30s] minWorkers=[0]} starting goroutine pool
[ 0.558] INFO edge/router/fabric.(*StateManagerImpl).StartHeartbeat: heartbeat starting
[ 0.558] INFO edge/router/xgress_edge.(*CertExpirationChecker).Run: waiting 8591h42m56.432572551s to renew certificates
[ 0.559] WARNING edge/tunnel/dns.flushDnsCaches: {error=[exec: “systemd-resolve”: executable file not found in $PATH]} unable to find systemd-resolve in path, consider adding a dns flush to your restart process
[ 0.559] INFO edge/tunnel/dns.NewDnsServer: starting dns server…
[ 0.560] INFO edge/router/handler_edge_ctrl.(*helloHandler).HandleReceive.func1: received server hello, replying
[ 0.630] INFO edge/router/handler_edge_ctrl.(*apiSessionAddedHandler).instantSync: {strategy=[instant]} first api session syncId [cl7s4i676x4uiemh017ju9ie2], starting
[ 0.630] INFO edge/router/handler_edge_ctrl.(*apiSessionSyncTracker).Add: received api session sync chunk 0, isLast=true
[ 0.809] INFO fabric/router/handler_ctrl.(*dialHandler).handle |link, linkDialer|: {linkProtocol=[tls] routerVersion=[v0.25.13] linkId=[4WMo3WUGRhvdEY60KjKyIP] routerId=[pmBQvi6oE6] address=[tls:152.67.235.29:80]} dialing link
[ 0.809] INFO fabric/router/handler_ctrl.(*dialHandler).handle |link, linkDialer|: {routerVersion=[v0.25.13] linkId=[7SSEoeL3dfIp5xpv6oCFnx] routerId=[cuKiosjbE6] address=[tls:150.230.46.39:80] linkProtocol=[tls]} dialing link
[ 1.042] INFO fabric/router/handler_link.(*bindHandler).BindChannel: {routerId=[pmBQvi6oE6] routerVersion=[v0.25.13] linkId=[4WMo3WUGRhvdEY60KjKyIP]} link destination support heartbeats
[ 1.058] INFO fabric/router/handler_link.(*bindHandler).BindChannel: {linkId=[7SSEoeL3dfIp5xpv6oCFnx] routerId=[cuKiosjbE6] routerVersion=[v0.25.13]} link destination support heartbeats
[ 1.272] INFO fabric/router/handler_link.(*bindHandler).BindChannel: {routerVersion=[v0.25.13] linkId=[4WMo3WUGRhvdEY60KjKyIP] routerId=[pmBQvi6oE6]} link destination support heartbeats
[ 1.272] INFO fabric/router.(*xlinkAccepter).Accept: accepted new link [l/4WMo3WUGRhvdEY60KjKyIP]
[ 1.272] INFO fabric/router/handler_ctrl.(*dialHandler).handle |link, linkDialer|: {routerVersion=[v0.25.13] linkId=[4WMo3WUGRhvdEY60KjKyIP] routerId=[pmBQvi6oE6] address=[tls:152.67.235.29:80] linkProtocol=[tls]} link registered
[ 1.272] INFO fabric/router/handler_ctrl.(*dialHandler).handle |link, linkDialer|: {address=[tls:162354cb-06b0-4953-bc2a-1b10267ad4f4.production.netfoundry.io:6262] linkProtocol=[tls] routerVersion=[v0.25.13] linkId=[5YE7PZL8kHQXS27K47ypF0] routerId=[5xnOn.aTq]} dialing link
[ 1.301] INFO fabric/router/handler_link.(*bindHandler).BindChannel: {linkId=[7SSEoeL3dfIp5xpv6oCFnx] routerId=[cuKiosjbE6] routerVersion=[v0.25.13]} link destination support heartbeats
[ 1.301] INFO fabric/router.(*xlinkAccepter).Accept: accepted new link [l/7SSEoeL3dfIp5xpv6oCFnx]
[ 1.301] INFO fabric/router/handler_ctrl.(*dialHandler).handle |link, linkDialer|: {linkProtocol=[tls] routerVersion=[v0.25.13] linkId=[7SSEoeL3dfIp5xpv6oCFnx] routerId=[cuKiosjbE6] address=[tls:150.230.46.39:80]} link registered
[ 1.508] INFO fabric/router/handler_link.(*bindHandler).BindChannel: {linkId=[5YE7PZL8kHQXS27K47ypF0] routerId=[5xnOn.aTq] routerVersion=[v0.25.13]} link destination support heartbeats
[ 1.631] INFO edge/router/handler_edge_ctrl.(*apiSessionAddedHandler).applySync: finished sychronizing api sessions [count: 5, syncId: cl7s4i676x4uiemh017ju9ie2, duration: 121.999µs]
[ 1.760] INFO fabric/router/handler_link.(*bindHandler).BindChannel: {linkId=[5YE7PZL8kHQXS27K47ypF0] routerId=[5xnOn.aTq] routerVersion=[v0.25.13]} link destination support heartbeats
[ 1.760] INFO fabric/router.(*xlinkAccepter).Accept: accepted new link [l/5YE7PZL8kHQXS27K47ypF0]
[ 1.760] INFO fabric/router/handler_ctrl.(*dialHandler).handle |link, linkDialer|: {address=[tls:162354cb-06b0-4953-bc2a-1b10267ad4f4.production.netfoundry.io:6262] linkProtocol=[tls] routerVersion=[v0.25.13] linkId=[5YE7PZL8kHQXS27K47ypF0] routerId=[5xnOn.aTq]} link registered
[ 2.560] INFO edge/tunnel/dns.NewDnsServer: dns server running at 10.250.50.78:53
[ 2.560] INFO edge/tunnel/dns.(*resolver).AddHostname: adding ziti-tunnel.resolver.test = 19.65.28.94 to resolver
[ 2.609] FATAL edge/tunnel/dns.NewDnsServer: system resolver test failed: failed to resolve ziti-tunnel.resolver.test: lookup ziti-tunnel.resolver.test: no such host
ziti-tunnel runs an internal DNS server which must be first in the host’s
** prepend domain-name-servers 10.250.50.78:53;**
ziggy@testbox:~$ sudo sh -c ‘echo DNS=10.250.50.78 >> /etc/systemd/resolved.conf’
ziggy@testbox:~$
ziggy@testbox:~$
[Resolve]
#DNS=
#FallbackDNS=
#Domains=
#DNSSEC=no
#DNSOverTLS=no
#MulticastDNS=no
#LLMNR=no
#Cache=no-negative
#ReadEtcHosts=yes
DNS=10.250.50.78
ziggy@testbox:~$
ziggy@testbox:~$
ziggy@testbox:~$
ziggy@testbox:~$ sudo systemctl restart systemd-resolved.service
ziggy@testbox:~$
ziggy@testbox:~$
Global
DNS Servers: 10.250.50.78
Link 2 (ens33)
Current Scopes: DNS
ziggy@testbox:~$
ziggy@testbox:~$
[ 0.311] INFO ziti/ziti-router/subcmd.run: {go-version=[go1.18.2] configFile=[config.yml] revision=[a32a117f9472] os=[linux] arch=[amd64] routerId=[P5xIkiIbE6] build-date=[2022-05-24T19:19:48Z] version=[v0.25.10]} starting ziti-router
[ 0.311] WARNING edge/router/internal/edgerouter.(*Config).LoadConfigFromMap: Invalid heartbeat interval [0] (min: 60, max: 10), setting to default [60]
[ 0.311] INFO fabric/router.(*Router).showOptions: ctrl = {“OutQueueSize”:4,“MaxQueuedConnects”:1,“MaxOutstandingConnects”:16,“ConnectTimeout”:1000000000,“DelayRxStart”:false,“WriteTimeout”:0}
[ 0.311] INFO fabric/router.(*Router).showOptions: metrics = {“ReportInterval”:60000000000,“MessageQueueSize”:10}
[ 0.311] INFO fabric/router.(*Router).initializeHealthChecks: starting health check with ctrl ping initially after 15s, then every 30s, timing out after 15s
[ 0.311] INFO fabric/router.(*Router).startXlinkDialers: started Xlink dialer with binding [transport]
[ 0.311] INFO edge/router/xgress_edge.(*listener).Listen: {address=[tls:0.0.0.0:443]} starting channel listener
[ 0.311] INFO fabric/metrics.GoroutinesPoolMetricsConfigF.func1.1: {minWorkers=[1] maxWorkers=[100] idleTime=[10s] maxQueueSize=[50] poolType=[pool.listener.xgress_edge]} starting goroutine pool
[ 0.311] INFO fabric/router.(*Router).startXgressListeners: created xgress listener [edge] at [tls:0.0.0.0:443]
[ 0.311] INFO fabric/router.(*Router).startXgressListeners: created xgress listener [tunnel] at
[ 0.312] INFO fabric/router/forwarder.(*Faulter).run: started
[ 0.312] INFO fabric/router/forwarder.(*Scanner).run: started
[ 0.312] INFO edge/router/xgress_edge.(*Acceptor).Run: starting
[ 0.582] INFO fabric/metrics.GoroutinesPoolMetricsConfigF.func1.1: {idleTime=[30s] poolType=[pool.link.dialer] maxQueueSize=[1000] minWorkers=[0] maxWorkers=[32]} starting goroutine pool
[ 0.582] INFO fabric/metrics.GoroutinesPoolMetricsConfigF.func1.1: {idleTime=[30s] poolType=[pool.route.handler] minWorkers=[0] maxQueueSize=[1000] maxWorkers=[128]} starting goroutine pool
[ 0.582] INFO edge/router/fabric.(*StateManagerImpl).StartHeartbeat: heartbeat starting
[ 0.582] INFO edge/router/xgress_edge.(*CertExpirationChecker).Run: waiting 8591h39m16.736026379s to renew certificates
[ 0.585] INFO edge/router/handler_edge_ctrl.(*helloHandler).HandleReceive.func1: received server hello, replying
[ 0.586] WARNING edge/tunnel/dns.flushDnsCaches: {error=[exec: “systemd-resolve”: executable file not found in $PATH]} unable to find systemd-resolve in path, consider adding a dns flush to your restart process
[ 0.586] INFO edge/tunnel/dns.NewDnsServer: starting dns server…
[ 0.657] INFO edge/router/handler_edge_ctrl.(*apiSessionAddedHandler).instantSync: {strategy=[instant]} first api session syncId [cl7s4mvpvx50lemh05unarpr5], starting
[ 0.658] INFO edge/router/handler_edge_ctrl.(*apiSessionSyncTracker).Add: received api session sync chunk 0, isLast=true
[ 0.833] INFO fabric/router/handler_ctrl.(*dialHandler).handle |link, linkDialer|: {linkProtocol=[tls] routerVersion=[v0.25.13] linkId=[70Qlj2VeYhzLiODY2pwiZb] routerId=[pmBQvi6oE6] address=[tls:152.67.235.29:80]} dialing link
[ 0.834] INFO fabric/router/handler_ctrl.(*dialHandler).handle |link, linkDialer|: {routerVersion=[v0.25.13] linkId=[4hHaFVrii0Ye5rDnDrmdYW] routerId=[cuKiosjbE6] address=[tls:150.230.46.39:80] linkProtocol=[tls]} dialing link
[ 1.067] INFO fabric/router/handler_link.(*bindHandler).BindChannel: {linkId=[4hHaFVrii0Ye5rDnDrmdYW] routerId=[cuKiosjbE6] routerVersion=[v0.25.13]} link destination support heartbeats
[ 1.076] INFO fabric/router/handler_link.(*bindHandler).BindChannel: {linkId=[70Qlj2VeYhzLiODY2pwiZb] routerId=[pmBQvi6oE6] routerVersion=[v0.25.13]} link destination support heartbeats
[ 1.295] INFO fabric/router/handler_link.(*bindHandler).BindChannel: {routerVersion=[v0.25.13] linkId=[4hHaFVrii0Ye5rDnDrmdYW] routerId=[cuKiosjbE6]} link destination support heartbeats
[ 1.295] INFO fabric/router.(*xlinkAccepter).Accept: accepted new link [l/4hHaFVrii0Ye5rDnDrmdYW]
[ 1.295] INFO fabric/router/handler_ctrl.(*dialHandler).handle |link, linkDialer|: {routerVersion=[v0.25.13] linkId=[4hHaFVrii0Ye5rDnDrmdYW] routerId=[cuKiosjbE6] address=[tls:150.230.46.39:80] linkProtocol=[tls]} link registered
[ 1.295] INFO fabric/router/handler_ctrl.(*dialHandler).handle |link, linkDialer|: {linkId=[5q2jdteIEC7dEMJO07qBu5] routerId=[5xnOn.aTq] address=[tls:162354cb-06b0-4953-bc2a-1b10267ad4f4.production.netfoundry.io:6262] linkProtocol=[tls] routerVersion=[v0.25.13]} dialing link
[ 1.300] INFO fabric/router/handler_link.(*bindHandler).BindChannel: {linkId=[70Qlj2VeYhzLiODY2pwiZb] routerId=[pmBQvi6oE6] routerVersion=[v0.25.13]} link destination support heartbeats
[ 1.300] INFO fabric/router.(*xlinkAccepter).Accept: accepted new link [l/70Qlj2VeYhzLiODY2pwiZb]
[ 1.300] INFO fabric/router/handler_ctrl.(*dialHandler).handle |link, linkDialer|: {address=[tls:152.67.235.29:80] linkProtocol=[tls] routerVersion=[v0.25.13] linkId=[70Qlj2VeYhzLiODY2pwiZb] routerId=[pmBQvi6oE6]} link registered
[ 1.532] INFO fabric/router/handler_link.(*bindHandler).BindChannel: {linkId=[5q2jdteIEC7dEMJO07qBu5] routerId=[5xnOn.aTq] routerVersion=[v0.25.13]} link destination support heartbeats
[ 1.658] INFO edge/router/handler_edge_ctrl.(*apiSessionAddedHandler).applySync: finished sychronizing api sessions [count: 5, syncId: cl7s4mvpvx50lemh05unarpr5, duration: 11.085µs]
[ 1.768] INFO fabric/router/handler_link.(*bindHandler).BindChannel: {linkId=[5q2jdteIEC7dEMJO07qBu5] routerId=[5xnOn.aTq] routerVersion=[v0.25.13]} link destination support heartbeats
[ 1.768] INFO fabric/router.(*xlinkAccepter).Accept: accepted new link [l/5q2jdteIEC7dEMJO07qBu5]
[ 1.768] INFO fabric/router/handler_ctrl.(*dialHandler).handle |link, linkDialer|: {address=[tls:162354cb-06b0-4953-bc2a-1b10267ad4f4.production.netfoundry.io:6262] linkProtocol=[tls] routerVersion=[v0.25.13] linkId=[5q2jdteIEC7dEMJO07qBu5] routerId=[5xnOn.aTq]} link registered
[ 2.587] INFO edge/tunnel/dns.NewDnsServer: dns server running at 10.250.50.78:53
*[ 2.588] INFO edge/tunnel/dns.(resolver).AddHostname: adding ziti-tunnel.resolver.test = 19.65.28.94 to resolver
*[ 2.619] INFO edge/tunnel/dns.(resolver).RemoveHostname: removing ziti-tunnel.resolver.test from resolver
[ 4.652] INFO edge/tunnel/intercept.SetDnsInterceptIpRange: dns intercept IP range: 100.64.0.1 - 100.127.255.254
Thanks @rcsoleng
I will try on another host and see if that makes a difference. Also if the lan ip is a public ip would it make a difference? Since in the end state, I would like to use this edge router as a way to get onto ziti network where others servers from RFC1918 address space would be able to use this router without needing Network Address Translation.
If you were going to run a public Ip I would suggest using two interface the private one facing your private Lan clients and the public one facing the internet (This is a similar config to most home router/firewalls. Using a public IP would not change the DNS operation discussed above.
@rcsoleng I tried on a diff host and ran into the same problem. Would it be possible for you to do this using CentOS 8 by any chance? I am wondering if this is some behavior difference of systemd-resolved on Ubuntu vs CentOS/RHEL.
I am neither able to see Current Scopes: DNS on my network interface nor any DNS Servers for it. I am not sure how I can configure DNS resolver at the network interface level.
TIA.
I was able to configure link level resolver explicitly using
sudo resolvectl dns <link> <DNS1> <DNS2>
while having router’s own ip in /etc/systemd/resolved.conf and router came up as intended.
I’m following along, but I’m not sure, does this mean you got it all figured out now? If not, I was gonna reach out to @rcsoleng and see if he had additional guidance
Getting there :slightly_smiling_face:
I was not able to get the router up and running, now with the change mentioned below -
router is up and running. Now I am following rest of the setup to use this router to talk to my service.
Hi av-dev just checking in. Do you have any pending questions/issues or are you ok for now?
