Hi, I followed the first service quickstart and I’m trying to connect with the ziti admin console locally.
Is there something else I need to do in order to get it to resolve correctly?
What happens if you curl to that controller address? In my local setup, my controller is https://localhost:1280 (I see you are pointing to similar, but HTTP and not HTTPS), and I see:
dave$ curl -ks https://localhost:1280/version | jq .
"data": {
"apiVersions": {
"edge": {
"v1": {
"apiBaseUrls": [
"https://dave-lt.local:1280/edge/client/v1"
"path": "/edge/client/v1"
"edge-client": {
"v1": {
"apiBaseUrls": [
"edge-management": {
"v1": {
"apiBaseUrls": [
"https://dave-lt.local:1280/edge/management/v1"
"path": "/edge/management/v1"
"buildDate": "2022-11-10T14:39:47Z",
"revision": "807dd591b1f5",
"runtimeVersion": "go1.19.2",
"version": "v0.26.11"
"meta": {}
I’m 99% that it’s the http vs https issue. Ziti will never provide a non-https endpoint. ZAC can, but it’ll still contact the controller via https. Also the ZAC quickstart/install will show you how to setup ZAC for TLS.
It indeed was just http vs https. When I used https it worked flawlessly. Thanks all.
