Hey team,
I’ve been setting up OpenZiti on EKS and everything is working great for TCP-based services. Now I’m trying to test a UDP workload between two EC2 instances connected via OpenZiti tunnelers, and I have some questions.
Setup Overview
I have two EC2 instances acting as identities:
EC2-udp-app: runs a UDP-based appEC2-GS: needs to connect toEC2-udp-appover UDP
1. Identities
ziti edge create identity device EC2-udp-app --role-attributes "EC2-udp-app" -o EC2-udp-app.jwt
ziti edge enroll EC2-udp-app.jwt -o EC2-udp-app.json
ziti edge create identity device EC2-GS --role-attributes "EC2-GS" -o EC2-GS.jwt
ziti edge enroll EC2-GS.jwt -o EC2-GS.json
Tunnelers are running on both EC2s:
screen ziti-edge-tunnel run -i EC2-udp-app.json
screen ziti-edge-tunnel run -i EC2-GS.json
2. UDP Service Definition
ziti edge create config udp-app-intercept intercept.v1 '{
"protocols": ["udp"],
"addresses": ["10.100.100.111"],
"portRanges": [{"low": 61880, "high": 61880}]
ziti edge create config udp-app-host host.v1 '{
"protocol": "udp",
"address": "127.0.0.1",
"port": 61880
ziti edge create service UDPAPP \
--configs udp-app-intercept,udp-app-host \
--role-attributes 'counter-strike'
3. Policies
ziti edge create service-policy all-service-dial-policy Dial \
--service-roles '#counter-strike' \
--identity-roles '#EC2-udp-app'
ziti edge create service-policy all-service-bind-policy Bind \
--identity-roles '#EC2-GS'
ziti edge create service-edge-router-policy all-services-all-router \
--edge-router-roles '#all' \
--service-roles '#all'
TCP Works Great
When I use this setup for TCP-based workloads, it works perfectly. The edge routers are exposed via AWS NLB, and I just allow inbound TCP 443 in the security group — tunnelers connect fine and services are reachable.
Questions Regarding UDP
Now that I’m trying to use a UDP service:
- Does
ziti-edge-tunnelcurrently support UDP services? - If yes, where do I expose the UDP port in the router Helm chart?
- Should I define UDP ports under
linkListenersoredgesections? - Should I open UDP in the NLB's security group?
- Or is
ziti-edge-tunnellimited to TCP only? - Is there any way at all to work with UDP-based services using OpenZiti right now? Even with SDKs?
Would really appreciate any guidance on how to approach UDP workloads in Ziti. Thanks in advance!
