How do we authenticate a client identity using two factors?
I am trying to experiment with 2FA for client authentication: The X509 certificate is used as the first factor and an ext-jwt-signer as the second factor.
The authentication policy I am using is as follows:
./bin/ziti edge create auth-policy auth0-okta-policy \
    --primary-cert-allowed \
    --secondary-req-ext-jwt-signer <auth0-okta-id>
I authenticate with the x509 certificate as:
curl -s -X POST -H "Accept: application/json" \
    --cert pki/certs/2faclient.cert \
    --key pki/keys/2faclient.key \
    --cacert pki/certs/2faclient.pem \
    https://localhost:8441/edge/client/v1/authenticate?method=cert | jq -r '.data.token' > etc/2faclient.tok
The /edge/client/v1/current-api-session endpoint then shows a pending ext-jwt request under authQueries.
I then attempt the following:
curl -s -X GET -H "Accept: application/json" \
    -H "zt-session: $(cat etc/2faclient.tok)" \
    -H "Authorization: Bearer $(cat etc/okta.jwt)" \
    https://localhost:8441/edge/client/v1/current-api-session
I get the following error in the controller log:
[5021.704]   ERROR ziti/controller/model.(*AuthModuleExtJwt).process: {externalJwtSignerId=[7iqzZZ2maqJOE3K6mQ5EMP] claimsIssuer=[https://identity.oraclecloud.com/] idClaimProperty=[sub] authMethod=[ext-jwt]} external jwt authentication on auth policy is disabled
I have looked through the documentation on API session but cannot seem to make any headway in figuring out what I might be doing wrong:
Would appreciate any guidance.
Thanks in advance.
You want to have two forms of auth, but you're not using one of our SDKs nor tunnelers right? You're looking to do this with curl alone?
Correct @TheLumberjack.
I am not using the SDK. And AFAIK the tunnellers currently do not support ext-jwt-signer as the second factor.
So I am just experimenting with curl.
You need to use the authenticate url to obtain a session. Then use the session/cert/bearer. I think this will be enough for you, but if not lemme know
zt_session=$(curl -s -X POST -H "Accept: application/json" \
    --cert zsshSvcClient.cert \
    --key zsshSvcClient.key \
    --cacert zsshSvcClient.ca \
    -H "Authorization: Bearer ${tok}" \
    https://localhost:1280/edge/client/v1/authenticate?method=cert \
	| jq -r .data.token)
curl -v -s -X GET -H "Accept: application/json" \
    -H "zt-session: $zt_session" \
    https://localhost:1280/edge/client/v1/current-api-session
I tried that too @TheLumberjack . It still fails:
    -H "Authorization: Bearer $(cat etc/idcs.jwt)" \
Followed by:
    https://localhost:8441/edge/client/v1/current-api-session | jq
Get the same error after each command:
[ 108.975]   ERROR ziti/controller/model.(*AuthModuleExtJwt).process: {authMethod=[ext-jwt] externalJwtSignerId=[7iqzZZ2maqJOE3K6mQ5EMP] claimsIssuer=[https://identity.oraclecloud.com/] idClaimProperty=[sub]} external jwt authentication on auth policy is disabled
And the AuthQueries list shows EXT-JWT as pending.
I tested it all locally before sending it to you. I'm pretty certain it works. I'd expect you haven't created and assigned the auth policy quite right then. I used the zssh commands to setup my identity. You might want to check that out and see what I did differently. You can find the commands here GitHub - openziti-test-kitchen/zssh: Ziti SSH
You'll want to use the "....-identity-and-oidc" one. Created by:
identity_and_oidc=$(ziti edge create auth-policy "${service_name}.${auth_policy_name}-identity-and-oidc" \
--primary-cert-expired-allowed \
--secondary-req-ext-jwt-signer "${ext_jwt_signer_id}")
echo "identity_and_oidc created with id: ${identity_and_oidc}"
You have created an identity with an external id that matches the sub field of your jwt and issuer ? I can make a short video demonstrating how I did this with keycloak and the zssh stuff found on that page if you need it, but it won't be for a while. it's quite late here local time :slight_smile:
Thank you @TheLumberjack .
I will go over the video. So sorry to keep you up so late :frowning:
I think I have got the auth-policy correct. In fact exactly the same command as yours except for the --primary-cert-expired-allowed option. And things do work if I make the ext-jwt-signer as primary on the auth-policy.
However, to be sure I am on v1.1.7. So I will try and upgrade as well.
Here you go.
Commands issued:
ziti cli commands shown
ziti edge quickstart
ziti edge create identity --admin curladmin -o curladmin.jwt
ziti edge enroll curladmin.jwt
ziti ops unwrap curladmin.jwt
chmod 700 curladmin.*
get a JWT from the IdP, set it into $bearer
bearer="token here"
authenticate to get a zt-session
    --cert curladmin.cert \
    --key curladmin.key \
    --cacert curladmin.ca \
    -H "Authorization: Bearer ${bearer}" \
    https://localhost:1280/edge/management/v1/authenticate?method=cert \
	| jq -r .data.token)
echo $zt_session
use the session to list identities:
    https://localhost:1280/edge/management/v1/identities \
	| jq .data[].name
use it to call the client API
Thanks a ton @TheLumberjack for your help.
@TheLumberjack
Confirming that the error is not observed with ziti v1.1.11.
2FA works properly and services are accessible.
Surprisingly the glibc issue is also resolved and I can continue to work with OracleLinux 8 :slight_smile:
Thank you again for your help with this.
