So i have a setup where i have 2 devices
both devices are running ziti-host, compose files:
services:
ziti-host:
container_name: ziti-edge-tunnel
image: docker.io/openziti/ziti-host
restart: unless-stopped
network_mode: host
privileged: true
volumes:
- /home/user/ziti:/ziti-edge-tunnel
environment:
ZITI_ENROLL_TOKEN: <token>
i can see both devices in zac as registered and online
i’m exposing thru a service port 22 on device A(Debian 12), and allowing device B(Debian 12) to dial it.
basically i want to be able to ssh from device B to A
when doing it i get ssh: Could not resolve hostname backup.ziti: Name or service not known
if i try to ssh into device A from my machine(after adding the role to the identity) i manage to connect to it, the main difference being that on my machine i installed the tunneler directly not by running the ziti-host container
is it possible to have this kind of setup where ziti works from a container in both client and server?
i assume there might be a need to change some dns settings somewhere
