How to connect postgres db using zitify() decorator
im trying to connect to postgres DB using psycopg its not working, do i need to use pg8000? does it not support psycopg2?
@qrkourier @TheLumberjack Sorry i dont know who to ask for can some one help to use SDK to connect postgres db?
Hey there, Although we don’t have a pg-specific sample yet in ziti-sdk-py/sample/README.md at main · openziti/ziti-sdk-py · GitHub, there’s an excellent chance the client-side techniques demonstrated in those samples will also work with psycopg.
The most direct, concise guidance is in pydoc openziti.decor.
Important takeaways include you should decorate functions with @openziti.zitify() and wrap clients and servers with a context manager like with openziti.monkeypatch():.
If the Ziti Py SDK doesn’t handle the client socket with either of these techniques for some reason, the zitify shell wrapper might work. It uses the LD_PRELOAD to hijack LIBC’s TCP connect, which would almost certainly work with the LIBC wrapper used by psycopg.
Good luck and please let us know if you find a solution!
@qrkourier i made it work through socket proxy method, here is the sample code
#!/usr/bin/env python3
Simple script to get students count through OpenZiti
Uses the working proxy approach
import os
import socket
import threading
import time
import openziti
from dotenv import load_dotenv
load_dotenv()
class ZitiPostgreSQLProxy:
def __init__(self):
self.ztx = openziti.load('_local_dagster.json')
self.local_port = None
self.server_socket = None
self.running = False
def start(self):
# Get free port
temp_sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
temp_sock.bind(('127.0.0.1', 0))
self.local_port = temp_sock.getsockname()[1]
temp_sock.close()
# Start proxy
self.server_socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
self.server_socket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
self.server_socket.bind(('127.0.0.1', self.local_port))
self.server_socket.listen(1)
self.running = True
threading.Thread(target=self._run_proxy, daemon=True).start()
time.sleep(0.1)
return self.local_port
def _run_proxy(self):
while self.running:
try:
self.server_socket.settimeout(1)
client_socket, _ = self.server_socket.accept()
threading.Thread(target=self._handle_connection, args=(client_socket,), daemon=True).start()
except socket.timeout:
continue
except:
break
def _handle_connection(self, client_socket):
try:
            @openziti.zitify()
def create_ziti_connection():
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.connect(('_db_service', 5432))
return s
ziti_socket = create_ziti_connection()
# Forward data
def forward(src, dst):
try:
while self.running:
data = src.recv(4096)
if not data: break
dst.sendall(data)
except: pass
t1 = threading.Thread(target=forward, args=(client_socket, ziti_socket), daemon=True)
t2 = threading.Thread(target=forward, args=(ziti_socket, client_socket), daemon=True)
t1.start()
t2.start()
t1.join()
t2.join()
except Exception as e:
pass
finally:
try: ziti_socket.close()
except: pass
client_socket.close()
def stop(self):
if self.server_socket:
self.server_socket.close()
def get_students_count():
# Start proxy
print("🚀 Starting OpenZiti proxy...")
proxy = ZitiPostgreSQLProxy()
local_port = proxy.start()
print(f"âś… Proxy running on localhost:{local_port}")
try:
import psycopg
conn = psycopg.connect(
host='127.0.0.1',
port=local_port,
user=os.getenv('HOSPITAL_DATABASE_USERNAME'),
password=os.getenv('HOSPITAL_DATABASE_PASSWORD'),
dbname=os.getenv('HOSPITAL_DATABASE_SERVICE_NAME', 'postgres')
# Execute the query you need
cursor = conn.cursor()
cursor.execute("SELECT COUNT(*) FROM students")
count = cursor.fetchone()[0]
print(f"📊 students count: {count}")
conn.close()
proxy.stop()
return count
except ImportError:
print("❌ psycopg3 not installed: pip install 'psycopg[binary]'")
proxy.stop()
return None
print(f"❌ Query failed: {e}")
proxy.stop()
return None
if __name__ == "__main__":
count = get_students_count()
if count is not None:
print(f"\nâś… SUCCESS: {count} students found")
else:
print("\n❌ Failed to get count")
We cant use host url directly, it works only with ziti servcie name and not actual hostname,
Example: xxxx.ap-northeast-1.rds.amazonaws.com this wont work,
you need to use _db_service name from ziti services which has mapping to your host and intercept.
this one works for me. but if anyone know even simpler method please do share.
