Python SDK with Postgres DB
I have the Java SDK Postgres example working.. and are now starting to try new things.. like use the Python SDK to connect to Postgres
One thing I noticed in the Java Postgres example, is that the JDBC driver does not need a port number.
I am curious to know how this works.. because you need a port number for all other end points.. is there something specific to this configuration?
The reason why I am exploring this.. because its the exact problem I have to with the Python SDK when attempting to connect to Postgres.
you need a port number.
Maybe I am doing something wrong..
Any tips to point me in the right direction?
I think I may have found a way forward… as there is a sockets sample… that can be used with a sockets db connector.
sock = openziti.socket(type = SOCK_STREAM)
sock.connect(('httpbin.ziti', 2000))
I am going to give this a go…
.. the answer is in how its configured
this creates the addressable URL for a specific port
ziti edge create config private-postgres-intercept.v1 intercept.v1 '{"protocols":["tcp"],"addresses":["zitified-postgres"], "portRanges":[{"low":5432, "high":5432}]}'
this makes links in the postgres database host
ziti edge create config private-postgres-host.v1 host.v1 '{"protocol":"tcp", "address":"postgres-db","port":5432 }'
this connects the two together
ziti edge create service private-postgres --configs private-postgres-intercept.v1,private-postgres-host.v1 -a "private-postgres-services"
In relation to the port number, I now think I see the connection, its using the default ports associated with the jdbc driver.. which is 5432 for postgres
https://jdbc.postgresql.org/documentation/head/connect.html
I found another way using the java sdk
I also found this option…
Quick note.. checking if anyone can help out here... I am close to being very stuck.
What I would like to clarify is
can you actually use a MonkeyPatch to connect to a Postgres DB?
I have explored how a MonkeyPatch could be used with the psycopg2 library, but I have not been able to get it work successfully.
For instance, this is what a standard connection would look like
psycopg2.connect(user="postgres",
                                  password="postgres",
                                  host="zitified-postgres",
                                  port="5432",
                                  database="simpledb")
Configuration #1 does not work
connection = openziti.monkeypatch()
                                  port="5432",
Configuration #2 does not work
connection = openziti.monkeypatch(psycopg2.connect(user="postgres",
                                  port="5432",
                                  database="simpledb"))
Configuration #3 does not work
connection = openziti.monkeypatch(psycopg2).connect(user="postgres",
                                  port="5432",
Configuration #4 does not work
with openziti.monkeypatch():
        connection = psycopg2.connect(user="postgres",
                                  port="5432",
What I have worked out is that I am missing something.
any tips on what I am doing wrong?
@TheLumberjack @ekoby @qrkourier
Small break through… as I did manage to have this code run without generating an error… but I still need to make it connect to the database and run a SQL query
import openziti
from socket import SOCK_STREAM,SHUT_WR
if __name__ == '__main__':
    print("Ziti SDK version = {0}".format(openziti.version()))
    sock.connect(('zitified-postgres', 5432))
    sock.shutdown(SHUT_WR)
    openziti.shutdown()
After some sleep.. and my mind doing its magic.. this is how I now view the problem of wanting to use the Python SDK to make a connection to a Postgres DB.
start in Gloang
then compile into C
make reference to the C library in Python
The inspiration of this came from the following article.. though I have no idea of how far I will get...
From what I understand, the MonkeyPatch does not work with Psycopg because of how the package is designed. Hence, the solution needs to be developed in a lower language such as C. You write C an integrate the C SDK, but I don't know C.. and have just started to use Gloang.
let me know if I have something wrong.
It looks like psycopg is written in C under the hood, fwiw psycopg2/psycopg at master · psycopg/psycopg2 · GitHub
