Is there a handler supporting simple text format ?
https://openziti.io/docs/reference/configuration/controller/#events
Apr 30 15:08:29 ziti[26734]: {"file":"github.com/openziti/ziti/controller/events/dispatcher.go:217","func":"github.com/openziti/ziti/controller/events.(*Dispatcher).WireEventHandlers","level":"error","msg":"Unable to create event handler: invalid 'format' for event log output file: plain","time":"2025-04-30T15:08:29.351Z"}
Apr 30 15:08:29 ziti[26734]: panic: invalid 'format' for event log output file: plain
You could use the stdoutLogger
handler to include events in the stdout and use the "text" format.
events:
stdoutLogger:
subscriptions:
- type: entityChange
include:
- configTypes
- services
- authenticators
- configs
- revocations
- serviceEdgeRouterPolicies
- eventualEvents
- cas
- routers
- postureChecks
- apiSessions
- apiSessionCertificates
- postureCheckTypes
- routers
- externalJwtSigners
- servicePolicies
- terminators
- authPolicies
- edgeRouterPolicies
- identityTypes
- sessions
- routers
- mfas
- services
- controllers
- identities
- enrollments
handler:
type: stdout
format: json
ziti controller run config.yml --log-formatter=text
If you're using the Linux service, edit the service unit to add the argument.
systemctl edit ziti-controller.service
### Editing /etc/systemd/system/ziti-controller.service.d/override.conf
### Anything between here and the comment below will become the new contents of the file
[Service]
ExecStart=
ExecStart=/opt/openziti/bin/ziti controller run config.yml --log-formatter=text --verbose
### Lines below this comment will be discarded
The plain format was removed a while back. I added an issue to update the doc: Remove reference to 'plain' event format · Issue #1123 · openziti/ziti-doc · GitHub
One option might be to pipe the json through jq to get something simpler and more human readable.
Exactly. We are not fluent in json.
