Hi @lzt ,
If you haven’t yet, check out the controller events: Controller Configuration Reference | OpenZiti
Circuit events have most of what you need. You can tie them together with session events to get the identity for the dialing side and the terminator host id for the hosting side. There are also usage events, which will give you information on how much data is flowing across each circuit, bucketed by minute, for each router. The usage information is already tagged with the client and host identities. I’m going to try and do the same for circuits, so you don’t have to correlate anything, I’ll post a follow up with the results of that experiment.
Below is the events configuration I’m using to generate the events, including the commented out bits to show what other things are available, as well as some example events. Released versions of ziti can emit events to a file, the rolling of which is configurable. The next release of ziti will also support pushing to an AMQP broker. While it’s not directly related to your questions, we’re also adding entity change events in the next release, both for auditing and for external systems integrations.
If you have any questions, let me know,
events:
jsonLogger:
subscriptions:
# - type: entityChange
# include:
# - services
# - identities
- type: fabric.circuits
# - type: fabric.links
# - type: fabric.routers
# - type: fabric.terminators
# - type: metrics
# sourceFilter: .*
# metricFilter: .*
- type: edge.sessions
- type: edge.apiSessions
- type: fabric.usage
# - type: services
# - type: edge.entityCounts
# interval: 5s
handler:
type: file
format: json
path: /tmp/ziti-events.log
Here are some sample events:
ApiSession Create
"namespace": "edge.apiSessions",
"event_type": "created",
"id": "clgx1gwl3001897gdu4h0vzl6",
"timestamp": "2023-04-25T21:50:15.544107122-04:00",
"token": "3d3d0c13-b30b-48a2-95f9-677e740ee162",
"identity_id": "fms1RWfjA4",
"ip_address": "127.0.0.1"
Session Create
"namespace": "edge.sessions",
"session_type": "Dial",
"id": "clgx1gwl8001a97gd0i8xylui",
"timestamp": "2023-04-25T21:50:15.549266686-04:00",
"token": "93c23214-26e5-4297-be7a-3022f6e9ef58",
"api_session_id": "clgx1gwl3001897gdu4h0vzl6",
"service_id": "5Vidy7TwqzDfpuWgcDLZVQ"
Circuit Create
"namespace": "fabric.circuits",
"version": 2,
"circuit_id": "2vC5NSD1S",
"timestamp": "2023-04-25T21:50:15.58601573-04:00",
"client_id": "clgx1gwl8001a97gd0i8xylui",
"service_id": "5Vidy7TwqzDfpuWgcDLZVQ",
"terminator_id": "27UOJs90gCjDDrYK3I1gk",
"instance_id": "",
"creation_timespan": 955013,
"path": {
"nodes": [
"U7OwPtfjg"
"links": null,
"ingress_id": "Oev2",
"egress_id": "216R"
"link_count": 0,
"path_cost": 262140
Usage
"namespace": "fabric.usage",
"version": 2,
"event_type": "usage.ingress.tx",
"source_id": "U7OwPtfjg",
"usage": 47,
"interval_start_utc": 1682473800,
"interval_length": 60,
"tags": {
"clientId": "fms1RWfjA4",
"hostId": "m7bVDWI5A4",
"serviceId": "5Vidy7TwqzDfpuWgcDLZVQ"
"version": 2,
"event_type": "usage.ingress.rx",
"usage": 47,
"tags": {
"version": 2,
"event_type": "usage.egress.tx",
"usage": 47,
"tags": {
"version": 2,
"event_type": "usage.egress.rx",
"usage": 47,
"tags": {
