I was new to Zrok and i need some assistance to create tcp tunnels using zrok. How to install and turn on the tcp tunnel and i should be disclose that i will connect the computer from different place different LAN networks i won’t be using on same Networks so localhost or something like 127.0.0.1 or anything related it won’t work for me so help me out on how to use and turn the tcp tunnels on using OpenZITI or Zrok or anything. And also please share me a single one direct command to turn on the server tcp tunnels without confirmations or anything straight to turn on the tunnel.
Hi again @saikub. Yes, you can do that! TCP tunnels are one of zrok’s private sharing modes and they work great. Here’s a short article about TCP tunnels (Sharing TCP and UDP Servers | zrok).
The best way to keep your TCP tunnel running is to use the zrok agent (Agent | zrok). You can set the agent to run in the background every time you reboot, so the TCP tunnel is always ready for other devices to run zrok access private. Those accessing devices can also use the agent, ensuring their remote access is always ready after a reboot.
What type of computer will be running your agent: Windows, macOS, or Linux? You can also use Docker/Podman on any of those OSs to run the agent on either end of the TCP tunnel.
