Integrate my own policy engine to Openziti
If I want to write my own policy engine (that is more flexible to allow automation) into the OpenZiti Github code, where can I start? Should I be looking at replacing the "controller" directory with my own?
Thanks,
Anita
Welcome, Anita!
Would it meet your needs to have an API implementation for managing policies and perhaps other entities? If so, what programming language? I may be able to local additional resources.
Here is the management API reference: Edge Management API Reference | OpenZiti
FYI: in case of confusion, these "edge" SDKs, they implement the "client" API, not the management API.
Thank you for the reference, Ken.
Would this API allow me to add policies that allow/deny access to certain devices/users/applications.
Example, I want to add a policy like:
Source/Destination/AllowOrDeny
IP_Address_1:Port_1/Resource_1/Deny
IP_Address_2:Port_2/Resource_2/Allow
Identity_1/Resource_1/Deny
etc
Yes, that's exactly what it's for. A quick way to orient to the management API is to explore the sub-commands of the ziti edge CLI, which implements Ziti's management API's operations.
❯ ziti edge
Manage the Edge components of a Ziti network using the Ziti Edge REST API
Usage:
  ziti edge [command]
Available Commands:
  create         creates various entities managed by the Ziti Edge Controller
  db             Database management operations for the Ziti Edge Controller
  delete         deletes various entities managed by the Ziti Edge Controller
  enroll         enroll an identity
  list           Lists various entities managed by the Ziti Edge Controller
  login          logs into a Ziti Edge Controller instance
  logout         logs out of a Ziti Edge Controller instance
  policy-advisor runs sanity checks on various policy related entities managed by the Ziti Edge Controller
  quickstart     runs a Controller and Router in quickstart mode
  re-enroll      re-enrolls various entities managed by the Ziti Edge Controller
  show           displays various entities managed by the Ziti Edge Controller
  trace          manages tracing by the Ziti Edge Controller
  traceroute     runs a traceroute on the service
  update         updates various entities managed by the Ziti Edge Controller
  use            changes which saved login to use with a Ziti Edge Controller instance
  validate       validate model data
  verify         verifies various entities managed by the Ziti Edge Controller
  version        Returns the version information reported by the edge controller
Flags:
  -h, --help   help for edge
Use "ziti edge [command] --help" for more information about a command.
In my opinion, this is the best introduction to the expressiveness of Ziti policies: Policies | OpenZiti
TL;DR Three types of policies and entities form an authorization triangle that must be completed for traffic to flow. You can set permissive router policies if you don't need geofencing or traffic steering and control access exclusively with service policies.
Another wy to describe it, we inside NetFoundry do not give our engineers access to customer resources, unless a customer opens a support ticket and the assigned engineer gets services defined only for the duration the ticket is open - Business Rule Driven Just-in-Time Network Access - all via the API @qrkourier describes.
Ken,
Are there test codes that implement the Edge Management API, specifically the Policy Engine / Controller APIs?
I am going to be using Python for my scripts.
Thank you,
Anita
Yes, but due to API changes, the Python-generated API client for the management API will probably need to be regenerated.
blog: OpenAPI Python Clients
mgmt API client: GitHub - openziti-test-kitchen/openziti-edge-management-python: Python library for the Ziti Management API
