Issues with zrok share public using self-hosted Zrok+Ziti
Hi all,
I’m seeing issues when running zrok share public on a self-hosted Ziti + Zrok setup.
Setup:
  • Zrok router: Let’s Encrypt SSL
  • Zrok controller: self-signed certs (added to client CA store)
  • Ziti CLI: 1.0.7, Zrok CLI: 1.1.13
  • zrok enable xyz works, registration appears in Zrok UI, policy shows in Ziti UI
Observed errors:
Ziti CLI 1.0.7:
[0.489] DEBUG sdk-golang/ziti.(*ContextImpl).connectEdgeRouter: {router=[router6]} connection to edge router using api session token df25ed25-ef07-4a7c-b814-bb2cf5d1cc8b
[0.489] DEBUG channel/v4.(*classicDialer).CreateWithHeaders [tls:ziti-router.mydomain.com:443]: started
[0.489] DEBUG channel/v4.(*classicDialer).CreateWithHeaders [tls:ziti-router.mydomain.com:443]: Attempting to dial with bind:
[0.500] DEBUG channel/v4.(*classicDialer).CreateWithHeaders [tls:ziti-router.mydomain.com:443]: exited
[0.500] ERROR sdk-golang/ziti.(*ContextImpl).connectEdgeRouter: {router=[router6]} tls: failed to verify certificate: x509: certificate signed by unknown authority
[0.500] DEBUG sdk-golang/ziti.(*listenerManager).handleRouterConnectResult: {routerUrl=[tls:ziti-router.mydomain.com:443] router=[router6] serviceName=[8hhefkgqzsci] listenerCount=[0]} handling router connect result, success? false
→ seems like router SSL not trusted
Zrok CLI 1.1.13:
[0.643] DEBUG sdk-golang/edge-apis.errorIndicatesControllerSwap: {error=[[GET /controllers][401] listControllersUnauthorized &{Error:0xc000eea9c0 Meta:0xc000ec6880}]} checking for network errror on type (*controllers.ListControllersUnauthorized) and its wrapped errors
[0.643] DEBUG sdk-golang/edge-apis.(*ClientTransportPoolRandom).TryTransportForF: {error=[[GET /controllers][401] listControllersUnauthorized &{Error:0xc000eea9c0 Meta:0xc000ec6880}]} determined that error (*controllers.ListControllersUnauthorized) does not indicate controller swap, returning error
[0.643] ERROR sdk-golang/edge-apis.(*BaseClient[...]).ProcessControllers: {error=[[GET /controllers][401] listControllersUnauthorized &{Error:0xc000eea9c0 Meta:0xc000ec6880}]} error listing controllers, continuing with 1 default configured controller
[0.643] DEBUG sdk-golang/ziti.(*ContextImpl).refreshServices: refreshing services
[0.648] DEBUG sdk-golang/edge-apis.errorIndicatesControllerSwap: {error=[[GET /services][401] listServicesUnauthorized &{Error:0xc000eeacc0 Meta:0xc000ec6980}]} checking for network errror on type (*service.ListServicesUnauthorized) and its wrapped errors
[0.648] DEBUG sdk-golang/edge-apis.(*ClientTransportPoolRandom).TryTransportForF: {error=[[GET /services][401] listServicesUnauthorized &{Error:0xc000eeacc0 Meta:0xc000ec6980}]} determined that error (*service.ListServicesUnauthorized) does not indicate controller swap, returning error [ERROR]: unable to create proxy backend (error listening: failed to listen: no apiSession, authentication attempt failed: error for request sMG7XBE.Xq: UNAUTHORIZED: The request could not be completed. The session is not authorized or the credentials are invalid, caused by: error for request : UNHANDLED: UNAUTHORIZED: The request could not be completed. The session is not authorized or the credentials are invalid)
→ seems like controller authentication fails
Notes:
  • On the client machine, both router and controller certs are trusted.
  • Behavior differs between CLIs: router vs. controller trust issue.
Has anyone encountered this with self-hosted Ziti + Zrok? Could this be a cert chain issue or an API session problem?
Can you try with zrok 1.1.2? There might be an issue with 1.1.3.
Also, do you mean OpenZiti 1.6.7, or 1.0.7?
Hey, my mistake — it should be Zrok CLI: 1.0.7 and Zrok CLI: 1.1.13. You’re right: after downgrading to 1.1.12, it shows the same errors as 1.0.7.
The same issue also occurs with the recent Go SDK.
Thank you. Switched back, and it was much easier to solve the problem.
Apologies for posting in this solved thread but we’re looking into upgrading the zrok controller to 1.1.3 but this comment is holding us off. Any more information on this possible issue or has it been confirmed that 1.1.3 is stable?
The issue was with the ziti version used with zrok 1.1.3. If you stay away from ziti 1.6.7, and use 1.6.8, you should be fine.
