I can't open the OpenZiti documentation. I don't know what I need. I would like to have the procedure for deploying the Ziti Edge Tunel urgently, please.
Docs work for me - Tunnelers | OpenZiti. If you cannot access the page, its probably something with your internet. Try a VPN to circumvent any possible controls on your local ISP.
thanks i will try again
It still doesn't work please can you copy the procedure and send it to me? It's really urgent please
Sounds to me like a DNS type issue. Exactly what is happening is probably not something we can help with I'm afraid.
You could always try generating the doc locally as well. Clone the ziti-doc repo and run 'gendoc.sh' (a script at the root of the project)
Can you view the source by going to ziti-doc/docusaurus/docs/reference/tunnelers/60-linux/index.mdx at main · openziti/ziti-doc · GitHub ?
