Router repeatedly logs failed to set write deadline, connection is fully closed when short-lived client connections (ProxySQL health checks) close
Describe the bug
Our edge routers emit an error every ~15 seconds:
{"error":null,"file":"github.com/openziti/ziti/router/xgress_common/connection.go:222","func":"github.com/openziti/ziti/router/xgress_common.(*XgressConn).ReadPayload","level":"error","msg":"failed to set write deadline, connection is fully closed"}
This correlates with short-lived connections created by ProxySQL health checks. When we stop ProxySQL monitoring, the router errors stop immediately. Business traffic is unaffected, but the router logs are noisy and make operational alerting harder.
Environment
  • Controller: v1.7.1 (Docker)
  • Routers:
    • 1× Docker router (openziti/ziti-router:1.7.1)
    • 1× Linux binary router (ziti-router), version: 1.7.1
What happened
  • ProxySQL monitoring (default or similar intervals) opens short connections to database backends that traverse Ziti.
  • On the router, we see the error above every ~15s (aligned with cleanup/health intervals).
  • Stopping ProxySQL monitoring removes the error entirely. Restarting it brings the error back.
Hi @charmpeach welcome to OpenZiti! I see you deleted your post, just checking in that you solved the issue?
Note that there's a PR up to drop this error to debug: connect events test by plorenz · Pull Request #3347 · openziti/ziti · GitHub
Thx for reply! I recover the post.
Seems a bug that proxysql monitor connect and quit will cause a error in ziti.
