Environment
OpenZiti version
Controller:
1.1.15 -
Routers:
1.1.15
Platform
Google Kubernetes Engine (GKE)
Node type:
e2-standard-2 -
Controller and router are running as separate pods (same node in some cases)
Scale
~200 identities
Multiple services and terminators
Problem Summary
We are seeing intermittent control-plane disconnections between routers and the controller.
At the time of the incident:
routers lose the controller connection
they reconnect automatically after ~1–2 minutes
during this window, clients experience service failures and the routers log:
service <id> has no online terminators
and
unable to ping (use of closed network connection)
rx error. closed peer and starting reconnection process
EOF
{"_context":"ch{edge}-\u003eu{classic}-\u003ei{QEmR}","chSeq":23175,"connId":126,"edgeSeq":0,"error":"service 3Zwpeo9QSKNGDkiqYLI6MX has no online terminators for instanceId ","file":"github.com/openziti/ziti/router/xgress_edge/listener.go:199","func":"github.com/openziti/ziti/router/xgress_edge.(*edgeClientConn).processConnect","level":"warning","msg":"failed to dial fabric","time":"2026-01-30T14:53:00.339Z","token":"2f6ccfa7-102d-4d57-86e4-3efff6910def","type":"EdgeConnectType"}
This happens even though:
CPU usage is low
memory usage is low
node conntrack usage is low
node file descriptor usage is low
We can provide Grafana metrics if needed.
Observed Router Logs
Example log lines from router:
_context":"u{reconnecting}->i{KMeD} @tls:ziti-ctrl.zzz.zzz:443
msg":"unable to ping (use of closed network connection)"
msg":"rx error. closed peer and starting reconnection process"
error":"EOF"
After this, routers reconnect and services recover.
At the same time, routers log:
service <service-id> has no online terminators
Controller Connectivity
Routers connect to the controller using:
Internally the controller listens on:
tls:0.0.0.0:1280
Helm Values Used for Controller
# /tmp/controller-values.yml
ctrlPlane:
advertisedHost: ziti-ctrl.zzz.zzz
advertisedPort: 443
service:
type: ClusterIP
ingress:
enabled: true
ingressClassName: nginx
annotations:
nginx.ingress.kubernetes.io/secure-backends: "true"
clientApi:
advertisedHost: ziti-controller.zzzz.zzz
advertisedPort: 443
service:
type: ClusterIP
ingress:
enabled: true
annotations:
Ingress is backed by nginx ingress controller with SSL passthrough.
Important Observations
The router is not crashing.
The controller is not crashing.
The connection is being closed and re-established.
Multiple services lose terminators at the same time.
The issue is reproducible and visible in metrics and logs.
Questions / Clarification Requested
Could running controller and router on the same node (but different pods) contribute to this behavior, or is that unrelated?
Are there any known issues or recommended settings for running OpenZiti 1.1.15 control-plane traffic behind an ingress?
Do you recommedn to run controller and roiuter on seperate node not on same node and use little higher configuration? does e2-standard-2 is recommeded?
Additional Context
We are running ~200 identities.
We do not observe CPU, memory, conntrack, or file descriptor pressure at the node level.
We can provide Grafana screenshots and Kubernetes events if needed.
