I did follow the linux installation way: Deploying on Linux | OpenZiti
However, the console seems not to work whatever i try.
Via /zac Endpoint in the controller config there comes a CGK Error.
I also tried the docker container - without success.
Also when searching for the console install guide in the ziti docs, each area doing things different, skipping things or not. I cant see any consistency here...
Maybe its just me, but can someone share there config / install steps?
Thanks
Welcome back, @berndinox. I'll keep responding about your Linux console issue in the GitHub issue you raised: Docker settings.json issue · Issue #345 · openziti/ziti-console · GitHub.
Here, I'll post a speed run through the Linux docs. I hope that will accomplish two things: reveal the missing step for your setup, and help me find the gap in the docs.
Here's a speed run through installing the controller and console on Linux: https://www.twitch.tv/videos/2150701233
and this one is about configuring a separate certificate for the console: https://www.twitch.tv/videos/2150850175
