I'm trying to set up a standalone CUPS print server in a dedicated printer VLAN, where the admin web interface is only accessible via a Ziti service routing to port 631. I’ve configured the Ziti bind policy to route traffic to 127.0.0.1 on port 631 and am running the CUPS server as standalone, so it only listens on localhost.
The problem is that CUPS checks the Host header in requests. It expects localhost but instead sees factory-printers-cups.ziti, and then it rejects the request with an error:
E [07/Nov/2024:09:58:39 -0600] [Client 282] Request from "localhost" using invalid Host: field "factory-printers-cups.ziti".
I tried modifying the /etc/hosts file to include the ziti domain, but this didn't seem to work either.
127.0.0.1 localhost factory-printers-cups.ziti
Instead of running it as local standalone, I could enable the remote printing and remote admin features with:
sudo cupsctl --remote-admin
But then it's insecure so I'd need to set up additional firewall rules to block direct traffic on port 631. Plus, it'd be nice to not have to specify a static IP (I have a printnode client running on this server, so I don't need any users to connect to it).
Using OpenZiti’s offloading to localhost would be perfect if it could keep the Host header as localhost as well. Is there a way to configure the Ziti service so that it rewrites the Host header to localhost when offloading to 127.0.0.1? Or, any other suggestions on how to handle this kind of setup without opening up additional network exposure?
The only other solution I can think of is spinning up an nginx server and modifying the header, and make the ziti service offload onto the nginx port, but it feels like overkill.
server {
listen 8631; # NGINX listens on this port
server_name factory-printers-cups.ziti;
location / {
proxy_pass http://127.0.0.1:631; # Forward to CUPS on port 631
proxy_set_header Host localhost; # Rewrite Host header to 'localhost'
Any advice or recommendations would be much appreciated if there's a way to do this with ziti alone!
