Trust-manager ‘field not declared in schema’ error on fresh EKS + Ziti Controller setup
I started with a fresh EKS Cluster. Installed ziti-controller using the below commands & the values.yml
Commands
helm repo add openziti https://docs.openziti.io/helm-charts/
helm repo update
kubectl apply -f https://github.com/cert-manager/cert-manager/releases/latest/download/cert-manager.crds.yaml
kubectl apply -f https://raw.githubusercontent.com/cert-manager/trust-manager/v0.9.0/deploy/crds/trust.cert-manager.io_bundles.yaml
kubectl apply -f storageclass.yml
helm install --namespace ziti-controller --create-namespace ziti-controller-managed openziti/ziti-controller --values controller-values.yml
clientApi:
  advertisedHost: ziti-controller.example.com
  service:
    enabled: true
    type: ClusterIP
  ingress:
    enabled: true
    ingressClassName: "nginx"
    annotations:
      external-dns.alpha.kubernetes.io/hostname: "ziti-controller.example.com"
      service.beta.kubernetes.io/aws-load-balancer-internal: "false"  # Ensures the LB is public
      service.beta.kubernetes.io/aws-load-balancer-type: "nlb"
      service.beta.kubernetes.io/aws-load-balancer-security-groups: "sg-03fef4927363141b8"
      service.beta.kubernetes.io/aws-load-balancer-manage-backend-security-group-rules: "true"
ctrlPlane:
  containerPort: "{{ .Values.clientApi.containerPort }}"
  advertisedHost: "{{ .Values.clientApi.advertisedHost }}"
  advertisedPort: "{{ .Values.clientApi.advertisedPort }}"
  service:
    enabled: true
    type: ClusterIP
highAvailability:
  # -- Ziti controller HA mode
  mode: standalone
  # -- Ziti controller HA swarm replicas
  replicas: 1
persistence:
  enabled: true
  storageClass: "ebs-sc"
  accessMode: ReadWriteOnce
cert-manager:
  enabled: true
  enableCertificateOwnerRef: true
  installCRDs: false
trust-manager:
  enabled: true
  app:
    trust:
      namespace: "ziti-controller"
  crds:
    enabled: false
ingress-nginx:
  enabled: true
  controller:
    extraArgs:
      enable-ssl-passthrough: "true"
    service:
      annotations:
$ kubectl get pods -n ziti-controller
NAME                                                              READY   STATUS    RESTARTS   AGE
trust-manager-589b9df4d7-wmzj6                                    1/1     Running   0          4m56s
ziti-controller-managed-5fc599bddb-hpwwh                          1/1     Running   0          4m56s
ziti-controller-managed-cert-manager-9d9997797-bz9jf              1/1     Running   0          4m56s
ziti-controller-managed-cert-manager-cainjector-665dc9f48ftp5kl   1/1     Running   0          4m56s
ziti-controller-managed-cert-manager-webhook-5c665ddc4f-4sgt7     1/1     Running   0          4m56s
ziti-controller-managed-ingress-nginx-controller-f7b8784cdgvt2s   1/1     Running   0          4m56s
storageclass.yml
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
provisioner: ebs.csi.aws.com
parameters:
  type: gp3
  fsType: ext4
reclaimPolicy: Delete
volumeBindingMode: WaitForFirstConsumer
secrets & configmap
$ kubectl get secrets -n ziti-controller
NAME                                                        TYPE                 DATA   AGE
sh.helm.release.v1.ziti-controller-managed.v1               helm.sh/release.v1   1      17m
trust-manager-tls                                           kubernetes.io/tls    3      16m
ziti-controller-managed-admin-client-secret                 kubernetes.io/tls    3      15m
ziti-controller-managed-admin-secret                        Opaque               2      17m
ziti-controller-managed-cert-manager-webhook-ca             Opaque               3      17m
ziti-controller-managed-ctrl-plane-client-identity-secret   kubernetes.io/tls    3      16m
ziti-controller-managed-ctrl-plane-identity-secret          kubernetes.io/tls    3      16m
ziti-controller-managed-ctrl-plane-intermediate-secret      kubernetes.io/tls    3      16m
ziti-controller-managed-ctrl-plane-root-secret              kubernetes.io/tls    3      16m
ziti-controller-managed-edge-root-secret                    kubernetes.io/tls    3      16m
ziti-controller-managed-edge-signer-secret                  kubernetes.io/tls    3      16m
ziti-controller-managed-ingress-nginx-admission             Opaque               3      17m
ziti-controller-managed-trust-domain                        Opaque               1      17m
ziti-controller-managed-web-client-identity-secret          kubernetes.io/tls    3      15m
ziti-controller-managed-web-identity-secret                 kubernetes.io/tls    3      15m
ziti-controller-managed-web-intermediate-secret             kubernetes.io/tls    3      16m
ziti-controller-managed-web-root-secret                     kubernetes.io/tls    3      16m
$ kubectl get configmap -n ziti-controller
NAME                                               DATA   AGE
kube-root-ca.crt                                   1      18m
ziti-controller-managed-config                     4      18m
ziti-controller-managed-ctrl-plane-cas             1      16m
ziti-controller-managed-ingress-nginx-controller   1      18m
When I checked the logs of trust-manager-589b9df4d7-wmzj6 pod, I found one ERROR
E0107 19:45:00.264993       1 controller.go:329] trust/manager "msg"="Reconciler error" "error"="failed to apply bundle status patch: failed to create typed patch object (/ziti-controller-managed-ctrl-plane-cas; trust.cert-manager.io/v1alpha1, Kind=Bundle): .status.target: field not declared in schema" "controller"="bundles" "name"="ziti-controller-managed-ctrl-plane-cas" "namespace"="" "reconcileID"="c797e6ed-e2c4-4ef9-b514-4dad7184b121"
For Reference I have uploaded the whole logfile of that pod.
trust-manager-pod-log.txt (43.9 KB)
Can someone help me to fix this error? Only these things are installed on the EKS Cluster nothing other than that not even routers.
That's a new one. Do you get the same error after downgrading to this version of the Bundle CRD?
https://raw.githubusercontent.com/cert-manager/trust-manager/v0.7.0/deploy/crds/trust.cert-manager.io_bundles.yaml
Thanks for reply @qrkourier
I tried this.. Still the same :frowning:
Here are the logs
trust-manager-pod-log2.txt (45.4 KB)
I think we need support from Trust Manager to understand this error reported by Trust Manager's "bundles" controller.go on line 329.
The error indicates TM is failing to patch the Bundle resource with a property that doesn't exist in the schema from the Bundle CRD, .status.target.
Since you're setting up a fresh cluster, will you try deleting the Helm release and TM CRDs, then starting with v0.7.0 CRD before re-creating the Helm release?
I tried that on another fresh cluster... I'm now installing both cert-manager & trust-manager manually and then testing it. It's just that we need both in the ziti-controller namespace right?
@qrkourier
So in another fresh EKS Cluster.. I Installed cert-manager & trust-manager using the below commands
helm install cert-manager jetstack/cert-manager \
  --namespace ziti-controller \
  --create-namespace \
  --version v1.16.2 \
  --set crds.enabled=true \
  --set crds.keep=false
helm upgrade trust-manager jetstack/trust-manager \
  --install \
  --version 0.14.0 \
  --set app.trust.namespace=ziti-controller \
  --wait
Later I installed the ziti-controller using the same above values.yml but I disabled cert-manager & trust-manager subcharts over there..
These are the logs of trust-manager, cert-manager & controller pods..
ziti-controller-log2.txt (5.5 KB)
cert-manager-pod-log.txt (67.1 KB)
trust-manager-pod-log4.txt (12.5 KB)
I guess the issue is resolved, what do you think?
Yes, and thank you for sharing the specific versions of CM and TM you used. There could be a problem with installing Trust Manager CRDs separately when enabling the subchart, and it's good to know that pre-installing Trust Manager for the correct namespace and disabling the subchart is a good solution.
Can I fix that subchart issue ? :sweat_smile:
Trust Manager and Cert Manager sub-charts are disabled by default, and it's unclear which conditions introduce the schema deviation you encountered. It's the first report, and I thank you for that. The automated test and my local test haven't triggered that problem, so it doesn't seem to be universal.
Okay.. I thought I got an first opportunity to contribute to opensource :sweat_smile:
