Its been 2 days trying to fix this alone I used AI's to but they suck, I wanna use zrok so that I get server:port so I connect using VNC viewer the part I am stuck at is this :
zrok --help
zrok enable $3
zrok share private --backend-mode tcpTunnel localhost:5900
zrok status
and I just get this error :
Use "zrok [command] --help" for more information about a command.
91open /dev/tty: device not configured
92there was a problem enabling your environment!
93you are trying to use the zrok service at: https://api-v1.zrok.io
94you can change your zrok service endpoint using this command:
95$ zrok config set apiEndpoint
96(where newEndpoint is something like: https://some.zrok.io)/)
97Error: Process completed with exit code 1.
I just want it to echo the server:port so that I can connect to macos using VNC viewer.
