I saw this in the zssh cheat sheet.
intercept is not needed for zscp/zssh but make it for testing if you like
Can you further elaborate? not sure I understand
Thx
intercept.v1 configurations are generally used with tunneling applications like the ziti desktop edge for windows/mac. You MUST have an intercept.v1 or ziti-tunneler-client.v1 defined if you want to use a tunneling app provided by OpenZiti on the âclientâ side.
This config would allow someone to use âregularâ ssh (not zssh) to ssh to the same identity. The problem here though, is if youâre using addressable terminators youâll need to define a new intercept per endpoint. One of the things missing on that cheatsheet would be the âdialOptionâ to allow that service to work.
If you tried that right now youâll find you canât successfully ssh to the zssh server becasue the intercept is missing , "dialOptions": {"identity":"identityNameHere"}
Probably confusing - but thatâs what thatâs talking about
