Hiya, I have a question about Terminators.
I have a HA Ziti system consisting of 3 Controllers and 2 public Edge Routers. I'm running v1.5.0 on the infrastructure and ZET v1.5.4.
In my POC system i am seeing Terminators created but under specific scenarios they are not deleted which seems to result in old/stale terminators remaining on the system seemingly indefinitely.
One way i can reproduce this behaviour is by applying a new piece of configuration on a Controller.
To begin with i have a single ZET client connected with a terminator on one of my 2 Edge Routers.
root@ziti-controller-3:~# ziti edge list terminators 'limit 500'
│ ID │ SERVICE │ ROUTER │ BINDING │ ADDRESS │ IDENTITY │ COST │ PRECEDENCE │ DYNAMIC COST │
│ 2Elzi7EeaSVko56JXaKeH │ lifeboat.ssh │ edge-router-detof │ edge │ 2Elzi7EeaSVko56JXaKeH │ user1.lifeboat.controller │ 0 │ default │ 0 │
results: 1-1 of 1
If i update my host.v1 configuration on a Controller, it triggers an update across the system and new terminators are created.
ziti edge update config ...
Now i have a new terminator for the same identity.
│ Ei67QOcmkbeBzvMbEHYmB │ lifeboat.ssh │ edge-router-detof │ edge │ Ei67QOcmkbeBzvMbEHYmB │ user1.lifeboat.controller │ 0 │ default │ 0 │
results: 1-2 of 2
The original terminator with ID 2Elzi7EeaSVko56JXaKeH i assume is now stale/old but it never seems to be deleted. Is this a problem ?
