ZET does not recover after prolonged controller/network outage once API session expires
I am seeing ziti-edge-tunnel fail to recover after controller and network connectivity are restored following a prolonged outage.
A short network interruption appears to be handled normally. The problem occurs when connectivity remains unavailable long enough for the existing API/OIDC session to expire.
Environment
  • ziti-edge-tunnel: using Ziti C SDK 1.18.4
  • Ziti Tunneler SDK: 1.18.5
  • Controller: v2.0.1
  • Edge Routers: v2.0.1
  • Authentication method: OIDC
  • Linux/systemd
The tunneler has one identity and normally connects successfully to the controller and two edge routers.
Observed behavior
At startup, the tunneler authenticates normally:
connected to controller https://<controller>:443 version v2.0.1
using OIDC authentication method
authorization successful
context event : status is OK
router <edge-router-1> connected
router <edge-router-2> connected
At approximately 18:00:48, network/controller connectivity was lost. Both edge-router channels disconnected and the controller became unavailable:
channel disconnected [-103/software caused connection abort]
disconnected from edge router[<edge-router-1>]
reconnecting in 5600ms
disconnected from edge router[<edge-router-2>]
request[/services/.../edge-routers] failed
no controllers are online
The tunneler continued retrying, which is the behavior I would expect.
After the outage had lasted approximately 27 minutes, the authentication session expired:
18:27:33 WARN ziti-sdk:ziti.c:236 ztx_set_unauthenticated()
ztx[1] auth error: session token has expired
WARN tunnel-cbs:ziti_tunnel_ctrl.c:1056 on_ziti_event()
ziti_ctx controller connections failed: not authorized
Shortly afterward, the SDK detected that there was no longer an API session and attempted to re-authenticate:
WARN ziti-sdk:ziti_ctrl.c:750 verify_api_session()
ctrl[https://<controller>:443] no API session
ERROR ziti-sdk:ziti.c:1756 update_identity_data()
ztx[1] failed to get identity_data:
no api session token set for ziti_controller[UNAUTHORIZED]
WARN ziti-sdk:ziti.c:1758 update_identity_data()
ztx[1] api session is no longer valid. Trying to re-auth
ztx[1] auth error: no api session token set for ziti_controller
OIDC refresh attempts also continued failing:
WARN ziti-sdk:oidc.c:726 oidc_refresh_cb()
oidc[internal] OIDC token refresh failed (...), attempt 5
The edge-router connection logic then delayed reconnecting because the Ziti context was no longer authenticated:
INFO ziti-sdk:channel.c:934 reconnect_cb()
ch[0] ztx[1] is not fully authenticated (auth_state[0]), delaying re-connect
Failure to recover
After network and controller connectivity were restored, the existing ziti-edge-tunnel process did not recover.
It remained in the same state for many hours:
no API session
The OIDC refresh counter eventually reached more than 6,800 attempts. Near the end I also observed:
OIDC token refresh failed (-103/software caused connection abort), attempt 6871
OIDC token refresh failed (-9/bad file descriptor), attempt 6872
OIDC token refresh failed (-9/bad file descriptor), attempt 6873
The process itself remained running, so systemd did not automatically restart it.
Restart immediately restores connectivity
When ziti-edge-tunnel was restarted, it recovered immediately.
The new process:
  1. Initialized the controller.
  2. Initialized the OIDC provider.
  3. Requested a token.
  4. Reported authorization successful.
  5. Connected to the controller.
  6. Reloaded the services.
  7. Connected to both edge routers.
For example:
ziti_ctx[...] connected to controller
Normal hosted-service connections then resumed.
This suggests that underlying network connectivity, controller availability, identity configuration, and router/service policies were valid once connectivity was restored. Reinitializing the tunneler/OIDC state by restarting the process was sufficient to recover.
Expected behavior
I would expect ziti-edge-tunnel to recover automatically when:
  1. Controller/network connectivity is lost.
  2. The API/OIDC session expires during the outage.
  3. Network connectivity is later restored.
If the previous API session can no longer be refreshed, I would expect the SDK to establish a new authenticated session rather than remain indefinitely in the unauthenticated state.
Possible reproduction
I believe this may be reproducible by:
  1. Start ziti-edge-tunnel and verify successful controller and edge-router connections.
  2. Block network access to the controller and edge routers.
  3. Leave connectivity blocked long enough for the existing authentication/API session to expire.
  4. Restore network access.
  5. Observe whether the tunneler creates a new authenticated API session and reconnects to the edge routers.
In my test, the important transition occurred after roughly 27 minutes of outage, when the log changed from CONTROLLER_UNAVAILABLE to:
not authorized
no API session
Trying to re-auth
After that transition, the process never recovered on its own.
Thanks for the report! We've seen similar behavior with our internal testing of ziti-edge-tunnel v1.18.5 (which uses ziti-sdk-c 1.18.4). So we're looking into this and won't mark a release that uses this version of ziti-sdk-c as stable until we fix this.
Do you know if this started occurring for you with ziti-edge-tunnel v1.18.5? Were you running ziti-edge-tunnel v1.18.4 previously?
I just reported the issue, but I’ve been encountering it (and had noticed it) since at least mid-June, if not earlier.
I've created a test environment that catches a re-connect failure. I'm not sure that it's the same issue that you're seeing though, because I only see it with builds of ziti-edge-tunnel that use ziti-sdk-c 1.18.4+. ziti-sdk-c 1.18.3 and earlier have been recovering from network outages in my test environment.
Do you have any logs (ideally DEBUG level or higher) that span the period of the initial disconnection until the point when the network was restored (and zet is fails to recover)? Logs from any version of ziti-edge-tunnel would be helpful to see if there's a different path to reconnect failures than the one I've been focused on.
I’m attaching a log from today that illustrates the problem. The ZET version is 1.18.6.
zet-1.18.6-sanitized.log (5.4 MB)
We made pre-release v1.18.7 last week, which fixes all of the disconnect/retry issues that we've been able to reproduce. Can you let me know if you still see your issue with it?
I've tested pre-release v1.18.7 over night and can confirm that the endpoint successfully recovered connectivity.
Moreover, I no longer see any report -9 or -103.
