I’ve recently experienced problems every once in a while when trying to access a web application via the MAC Ziti Edge Client.
Suddenly, the service behind the overlay doesn’t send a response back anymore.
Here are the logs. Any ideas what’s wrong (or what I might be doing wrong)
[2023-07-08T09:17:54:826Z] INFO PacketTunnelProvider:ZitiTunnelDelegate.swift:222 tunnelEventCallback() ZitiTunnelEvent: <CZiti.ZitiTunnelContextEvent: 0x146240db0>
identity: dm_mb:"ABCDEFG"
status: OK
version: v0.26.10
controller:
code: 0
[2023-07-08T09:17:54:832Z] INFO PacketTunnelProvider:UserNotifications.swift:100 post() Attempting to post Info notification, subitile:Optional("Controller: Available"), body:Optional("dm_mb\nhttps://zt.mydomain.com:8441"), zid:Optional("dm_mb")
(72753)[2023-07-08T09:17:54.891Z] INFO ziti-sdk:ziti.c:1422 ziti_set_api_session() ztx[0] api session set, setting api_session_timer to 1740s
(72753)[2023-07-08T09:17:54.917Z] INFO ziti-sdk:channel.c:733 reconnect_channel() ch[0] reconnecting NOW
(72753)[2023-07-08T09:17:55.058Z] INFO ziti-sdk:channel.c:631 hello_reply_cb() ch[0] connected. EdgeRouter version: v0.26.10|72978b5aa932|2022-10-13T15:31:04Z|linux|amd64
(72753)[2023-07-08T09:17:55.058Z] INFO tunnel-cbs:ziti_tunnel_ctrl.c:801 on_ziti_event() ztx[dm_mb] router zt-edge-router@tls://zt.mydomain.com:8442 connected
(72753)[2023-07-08T09:18:28.844Z] ERROR ziti-sdk:channel.c:488 dispatch_message() ch[0] received message without conn_id or for unknown connection ct[ED71] conn_id[9108]
(72753)[2023-07-08T09:18:30.000Z] ERROR ziti-sdk:channel.c:488 dispatch_message() ch[0] received message without conn_id or for unknown connection ct[ED71] conn_id[9112]
(72753)[2023-07-08T09:18:50.256Z] INFO tunnel-cbs:ziti_dns.c:500 format_resp() found record[100.64.0.5] for query[1:gl01.mydomain.com]
(72753)[2023-07-08T09:20:47.651Z] INFO tunnel-cbs:ziti_dns.c:500 format_resp() found record[100.64.0.5] for query[1:gl01.mydomain.com]
(72753)[2023-07-08T09:23:18.252Z] INFO tunnel-cbs:ziti_dns.c:500 format_resp() found record[100.64.0.5] for query[1:gl01.mydomain.com]
(72753)[2023-07-08T09:24:32.792Z] INFO tunnel-cbs:ziti_dns.c:500 format_resp() found record[100.64.0.5] for query[1:gl01.mydomain.com]
(72753)[2023-07-08T09:25:53.251Z] INFO tunnel-cbs:ziti_dns.c:500 format_resp() found record[100.64.0.5] for query[1:gl01.mydomain.com]
(72753)[2023-07-08T09:27:50.248Z] INFO tunnel-cbs:ziti_dns.c:500 format_resp() found record[100.64.0.5] for query[1:gl01.mydomain.com]
Best regards
Dominik
