Hey,
I'm trying to configure an identity with Ziti Edge Desktop (on windows).
So I've enrolled my identity, but it doesn't detect any service.
On the services logs I have this error:
[2025-07-10T09:30:20.798Z] WARN ziti-sdk:ziti.c:2012 version_pre_auth_cb() ztx[0] failed to get controller version: CONTROLLER_UNAVAILABLE/software caused connection abort
[2025-07-10T09:30:20.798Z] WARN ziti-sdk:ziti_ctrl.c:177 ctrl_resp_cb() ctrl[https://overlay.mydomainname.com:1280] request failed: -4079(software caused connection abort)
[2025-07-10T09:30:20.798Z] INFO ziti-sdk:ziti_ctrl.c:180 ctrl_resp_cb() ctrl[https://overlay.mydomainname.com:1280] attempting to switch endpoint
[2025-07-10T09:30:20.798Z] WARN ziti-sdk:ziti_ctrl.c:600 ctrl_next_ep() ctrl[https://overlay.mydomainname.com:1280] no controllers are online
[2025-07-10T09:30:20.798Z] WARN ziti-sdk:ziti.c:673 ext_jwt_singers_cb() ztx[0] failed to get external auth providers: software caused connection abort
But https://overlay.mydomainname.com:1280 is accessible and I'm actually using it to configure the services, create the identity, etc.
I'm using Ziti Edge Desktop v2.6.5 with controller docker image version openziti/ziti-controller:1.6.2.
Tried v2.6.4 and it worked perfectly.
Any idea of what could be the issue ?
