Hiya.
I've been working on an OpenZiti project with some good success so far but i'm new to Ziti and finding it tricky to configure exactly as i require. At the moment this i'm just POC'ing.
I have many Ubuntu servers running on networks behind firewalls. I'm hoping to build a Ziti network where the remote Ubuntu servers expose their SSH service on TCP22 to the Ziti network and i am able to SSH into them from my workstation specific identity also connected to the Ziti network. The Ubuntu servers should not be able to SSH between each other.
My current Ziti configuration achieves this however i've got a few questions about the data flows.
I've got four VM's running on my local network, there are no firewalls to worry about for now.
The Ziti Controller is running on VM ziti-controller:443 and an edge router running on VM ziti-router:443.
Then i've got a ziti-edge-tunnel running on a two separate VM's called ziti-client-a ziti-client-b. They use identities called ziti-client-a.example.ziti and ziti-client-b.example.ziti
The controller and router are speaking to each other. I can enrol the two ziti-edge-tunnel VM''s. Everything is "online".
I use an identity called user_1.example.ziti on my workstation which i connect to the Ziti network with another ziti-edge-tunnel.
My intercept, host and and service policy configurations allow me to SSH from my workstation to ziti-client-a or ziti-client-b via the Ziti network by using their identity names as the subdomain of the FQDN. like so...
ssh user@ziti-client-a.example.ziti
All good so far.
I'm a little confused about the data flows. When i run a tcpdump on one of my servers running ziti-edge-tunnel i can see that it's speaking to both the ziti controller and ziti router on 443. Is that expected ? What i was expecting/hoping is that ziti-edge-tunnel connects to only one public FQDN. Is that possible/logical ?
Following is my Controller install script...
#!/bin/bash
# A script to install OpenZiti controller and router on a VM
# https://openziti.io/docs/guides/deployments/linux/controller/deploy
# https://openziti.io/docs/guides/deployments/linux/router/deploy
# https://openziti.io/docs/guides/deployments/linux/console
_ZITI_CONTROLLER_NAME="ziti-controller"
_ZITI_ROUTER_NAME="ziti-router"
_ZITI_CONTROLLER_LISTEN_PORT=443
_ZITI_ROUTER_LISTEN_PORT=443
_ZITI_USER="admin"
_ZITI_PWD="password"
# OneLiner Ziti Controller installer
curl -sS https://get.openziti.io/install.bash | sudo bash -s openziti-controller
# Install Ziti console.
apt-get update
apt-get install -y openziti-console
# Write the Ziti Controller config
tee /opt/openziti/etc/controller/bootstrap.env &> /dev/null << EOF
ZITI_CTRL_ADVERTISED_ADDRESS='${_ZITI_CONTROLLER_NAME}'
ZITI_CTRL_ADVERTISED_PORT='${_ZITI_CONTROLLER_LISTEN_PORT}'
ZITI_USER='${_ZITI_USER}'
ZITI_PWD='${_ZITI_PWD}'
ZITI_BOOTSTRAP_CONFIG_ARGS=''
EOF
# Run the Ziti controller configure script
/opt/openziti/etc/controller/bootstrap.bash
# Not sure if required....
ziti create config controller
ziti create config environment
systemctl enable --now ziti-controller.service
echo
echo "Run router installer on ziti-router then press enter to continue..."
echo
read
# Set up policies, services, etc
ziti edge login -u ${_ZITI_USER} -p ${_ZITI_PWD} ${_ZITI_CONTROLLER_NAME}:${_ZITI_CONTROLLER_LISTEN_PORT} --yes
ziti edge create service-edge-router-policy all --service-roles '#all' --edge-router-roles '#all'
ziti edge create edge-router-policy all --edge-router-roles '#all' --identity-roles '#all'
ziti edge create config example.ssh.cfg.intercept intercept.v1 '{
"addresses": ["*.example.ziti"],
"protocols": ["tcp"],
"portRanges": [ {"low":22,"high":22} ],
"dialOptions": { "identity": "$dst_hostname" }
ziti edge create config example.ssh.cfg.host host.v1 '{
"address": "127.0.0.1",
"protocol": "tcp",
"port": 22,
"listenOptions": { "identity": "$tunneler_id.name" }
ziti edge create service example.ssh \
--configs example.ssh.cfg.intercept,example.ssh.cfg.host \
--role-attributes admin,ssh
ziti edge create service-policy example.ssh.dial Dial --identity-roles "#example,#admin" --service-roles "@example.ssh"
ziti edge create service-policy example.ssh.bind Bind --identity-roles "#example,#ssh" --service-roles "@example.ssh"
# Create "identities"
# Create an Admin user identity that can do everything.
ziti edge create identity user_1.example.ziti --role-attributes example,ssh,admin -o user_1.example.ziti.jwt
# Create some device identities.
ziti edge create identity ziti-client-a.example.ziti --role-attributes example,ssh -o ziti-client-a.example.ziti.jwt
ziti edge create identity ziti-client-b.example.ziti --role-attributes example,ssh -o ziti-client-b.example.ziti.jwt
And here is my router config...
#!/bin/bash
# A script to install OpenZiti router on a VM
_ZITI_USER="admin"
# OneLiner Ziti Router installer
curl -sS https://get.openziti.io/install.bash | sudo bash -s openziti-router
# Router setup https://openziti.io/docs/guides/deployments/linux/router/cli-mgmt/#create-a-router
# Create an edge-router
ziti edge create edge-router "ssh-edge-router" --jwt-output-file ssh-edge-router.jwt --tunneler-enabled
tee /opt/openziti/etc/router/bootstrap.env &>/dev/null <<EOF
ZITI_CTRL_ADVERTISED_PORT='443'
ZITI_ROUTER_ADVERTISED_ADDRESS='${_ZITI_CONTROLLER_NAME}'
ZITI_ROUTER_PORT='${_ZITI_ROUTER_LISTEN_PORT}'
ZITI_ENROLL_TOKEN='/root/ssh-edge-router.jwt'
EOF
# SystemD override
tee /etc/systemd/system/ziti-router.service.d/override.conf &>/dev/null <<EOF
[Service]
CapabilityBoundingSet=CAP_NET_BIND_SERVICE
AmbientCapabilities=CAP_NET_BIND_SERVICE
EOF
systemctl daemon-reload
# Run the Ziti Router configure script
/opt/openziti/etc/router/bootstrap.bash
systemctl enable --now ziti-router.service
Thanks in advance for your help!
