Hello there!
I think I have encountered a bug with how ziti edge tunnel establishes connections.
Consider the following setup:
- An online ER with circuits and terminators created and working
- An offline ER
If you stop the online ER and immediately bring up the second ER that was offline prior to the shutdown of the first(online) one - ziti edge tunnel would be unable to dial a service using the newly brought up ER.
The issue is resolved if ziti-edge-tunnel is reloaded.
asciinema: untitled - asciinema.org
Here you could see at the top a demo echo server running. Right below it goes two edge routers, one is online, and the second being offline. Below it you could find the ziti-edge-tunnel running and at the bottom is where my curling happening.
