Ziti Edge Tunnel --refresh interval
Hi Again.
I've got a question about the Ziti Edge Tunnel --refresh CLI argument. I couldn't find the answer in docs or code.
Is the value of the --refresh option strictly only used to control the frequency of the polling interval ? Is it used to control or affect any other timers, E.G reconnection attempts ?
The reason i ask is because reducing the polling frequency obviously reduces client load on the Controllers but i want to be sure it doesn't have any other unknown effects. In my use case the default polling interval of 10s is unnecessarily short.
Yes, that's its purpose. It doesn't affect reconnection attempts at this time. The default polling interval should be sufficient for a large numer of identities (many, many thousands if not more), until the controller exhibits prolonged CPU usage from the polling, it isn't something I would worry about in general. Where the polling time is very valuable is on battery-powered devices. Those devices benefit greatly from a reduced poll window, at the expense of not noticing changes as quickly.
Thanks @TheLumberjack !
