One thing i noticed, When i do sudo apt upgrade it is changing the active to false from older version to latest
then i have to do manually change this to true as your above command
@qrkourier @TheLumberjack The latest version of the Edge Tunnel (v1.2.3) has a bug. After upgrading using sudo apt upgrade ziti-edge-tunnel, the identity starts, but I'm unable to use SSH with Ziti. However, rolling back to v1.2.2 resolves the issue, and SSH works as expected.
Yeah, 1.2.4 has already been released. I expect it'll resolve the issue.
Thanks for the quick fix, let me check.
