I finish with installing ZITI and Admin console, and when I go to my url:1408, here is what i got
Any idsea how to fix this???
Hi @bojanbl, welcome to the community and to OpenZiti!
How did you install the Ziti Admin Console? This looks like what happens when ZAC has port 8443 (TLS) enabled and you access it over port :1408 (as you did).
There is some kind of redirect from 1408-->8443 issue that happens.
Can you try https://192.168.1.163:8443 ? (the tls endpoint). You'll get a self-signed certificate back which is fine... Similar to what I get when I try to access my home network controller:
